Can't get a flame. Ignitor glows, stays on for ~30 seconds, you hear that "click" and it turns off. Over and over. Before this, I would sometimes get a flame on the first ignition cycle, but not after that. Now I get no flame ever.
So far: I checked continuity on thermal fuse, radiant heat sensor, cycling thermostat, hi-limit thermostat. All good.
Propane tank is full and all valves open. Dryer exhaust hose is clean and clear. Ignitor is in good condition.
I've now replaced the thermal fuse, the heat sensor and the valve coils. Still not working.
I don't know what else to do other than try replacing the entire burner assembly, though the one listed on this site for my dryer appears to be for natural gas only (279894 - ap3094285). I'm even having the propane company come out to verify that I'm getting gas to the dryer- I doubt this is the problem though. Thoughts? HELP!!
