Discuss
Roper dryer won't start
 in
Dryer Repair
My Roper dryer won't start. My wife had just finished drying a load and put another load in to dry
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper dryer won't start
  #1 (permalink)
Old 09-16-2013, 10:21 AM
Junior Member
JeffBrannon is on a distinguished road
Default Roper dryer won't start
Model Number: RES6745pqo   Brand: Roper   Age: 5 - 10 years
My Roper dryer won't start. My wife had just finished drying a load and put another load in to dry and it wouldn't start. When you turn the timer to a setting you do hear some clicks but it won't start up.
I turned the timer on around, when it got to the fluff setting it did come on. When I took my hand off of the timer it kinda clicked back a notch maybe and stopped. It would repeat this action but only on fluff setting.
I haven't tested anything yet.
What should I check first?
Thanks!
Related Models
Roper RES7646JQ0 ELECTRIC DRYER
Roper RES7646KQ0 DRYER
Roper RES7646KQ1 DRYER
Roper RES7646KQ2 DRYER
Roper RES7646KQ3 29"ELECTRIC DRYER
Roper RES7648EN0 ELECTRIC DRYER
Roper RES7648EN1 DRYERS
Roper RES7648EN2 ELECTRIC DRYER
Roper RES7648EQ0 ELECTRIC DRYER
Roper RES7648EQ2 ELECTRIC DRYER
Roper RES7648EW0 ELECTRIC DRYER
Roper RES7648EW1 DRYERS
Roper RES7648EW2 ELECTRIC DRYER
Roper RES7648JQ0 ELECTRIC DRYER
Roper RES7648KQ0 DRYER
Roper RES7648KQ1 DRYER
Roper RES7745PQ0 29"ELECTRIC DRYER
Roper RES7745RQ0 29"ELECTRIC DRYER
Roper RES7745RQ1 29"ELECTRIC DRYER
 RESF3330DB RANGE- S/C F/S ELE
 RESF3330DW RANGE- S/C F/S ELE
 RESF5330DT RANGE- S/C F/S ELE
Roper REX2614LQ0 29"ELECTRIC DRYER
Roper REX3514PQ0 29"ELECTRIC DRYER
Roper REX3514RQ0 29"ELECTRIC DRYER
Roper REX3514RQ1 29"ELECTRIC DRYER
Roper REX3519PQ0 29" ELECTRIC DRYER
Roper REX3614JW0 ELECTRIC DRYER
Roper REX3614KW0 RESIDENTIAL DRYER
Roper REX3614KW1 DRYER
Roper REX3614KW2 29" ELECTRIC DRYER
Roper REX3614PW0 29" ELECTRIC DRYER
Whirlpool REX3614PW1 29" ELECTRIC DRYER
Roper REX3614PW2 29" ELECTRIC DRYER
Roper REX3615EW0 ELECTRIC DRYER
Roper REX3615EW1 DRYERS
Roper REX3615EW2 ELECTRIC DRYER
Roper REX4625EN0 ELECTRIC DRYER
Roper REX4625EW0 ELECTRIC DRYER
Roper REX4625EW1 DRYERS
Roper REX4625EW2 ELECTRIC DRYER
Roper REX4634JQ0 ELECTRIC DRYER
Roper REX4634KQ0 RESIDENTIAL DRYER
Roper REX4634KQ1 DRYER
Roper REX4634KQ2 29" ELECTRIC DRYER
Roper REX4635EN0 ELECTRIC DRYER
Roper REX4635EN1 DRYERS
Roper REX4635EN2 ELECTRIC DRYER
Roper REX4635EQ0 ELECTRIC DRYER
Roper REX4635EQ1 DRYERS
Roper REX4635EQ2 ELECTRIC DRYER
Roper REX4635EW0 ELECTRIC DRYER
Roper REX4635EW1 DRYERS
Roper REX4635EW2 ELECTRIC DRYER
Roper REX5634JQ0 ELECTRIC DRYER
Roper REX5634KQ0 RESIDENTIAL DRYER
Roper REX5634KQ1 DRYER
Roper REX5634KQ2 29" ELECTRIC DRYER
Roper REX5634PQ0 29" ELECTRIC DRYER
Roper REX5634PQ1 29" ELECTRIC DRYER
Roper REX5634RQ0 29" ELECTRIC DRYER
Roper REX5635EN0 ELECTRIC DRYER
Roper REX5635EN1 DRYERS
Roper REX5635EN2 ELECTRIC DRYER
Roper REX5635EQ0 ELECTRIC DRYER
Roper REX5635EQ1 DRYERS
Roper REX5635EQ2 ELECTRIC DRYER
Roper REX5635EW0 ELECTRIC DRYER
Roper REX5635EW1 DRYERS
Roper REX5635EW2 ELECTRIC DRYER
Roper REX5636AL1 ELECTRIC DRYER
Roper REX5636AL2 ELECTRIC DRYER
Roper REX5636AW0 Residential Dryer
Roper REX5636AW1 ELECTRIC DRYER
Roper REX5636AW2 ELECTRIC DRYER
Roper REX6634PQ0 29" ELECTRIC DRYER
Roper REX6634RQ0 29" ELECTRIC DRYER
Roper REX6634RQ1 29" ELECTRIC DRYER
Roper REX6646AL1 ELECTRIC DRYER
Roper REX6646AL2 ELECTRIC DRYER
Roper REX6646AL3 ELECTRIC DRYER
Roper REX6646AQ2 ELECTRIC DRYER
Roper REX6646AQ3 ELECTRIC DRYER
Roper REX6646AW0 Residential Dryer
Roper REX6646AW1 ELECTRIC DRYER
Roper REX6646AW2 ELECTRIC DRYER
Roper REX6646AW3 ELECTRIC DRYER
Whirlpool RF0100XKW0 Ranges, Electric*
Whirlpool RF0100XKW1 Ranges, Electric*
Whirlpool RF0100XRN8 Ranges, Electric*
Whirlpool RF0100XRW0 Ranges, Electric*
Whirlpool RF0100XRW1 Ranges, Electric*
Whirlpool RF0100XRW2 Ranges, Electric*
Whirlpool RF0100XRW3 Ranges, Electric*
Whirlpool RF0100XRW4 Ranges, Electric*
Whirlpool RF0100XRW5 Ranges, Electric*
Whirlpool RF0100XRW7 Ranges, Electric*
Whirlpool RF0100XRW8 Ranges, Electric*
Whirlpool RF0100XRW9 Ranges, Electric*
Whirlpool RF010ESPW0 Ranges, Electric*
Whirlpool RF010EXPW0
Whirlpool RF010EXRW0 Ranges, Electric*
Whirlpool RF010EXRW1 Ranges, Electric*
Whirlpool RF010EXRW2 Ranges, Electric*
Whirlpool RF014PXRW0 Ranges, Electric*
Whirlpool RF110AXSQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXSQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXSQ2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXSQ3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXST0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXST1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXST2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
  #2 (permalink)
Old 09-17-2013, 04:03 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Roper RES6745PQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Since the unit will start in air fluff the start switch, motor and thermal fuse are OK.
Sounds like a timer problem.
Set the timer to a problem area.
Unplug the unit.
Check BK to BU on the timer, should be 0 ohms.
Check T to W, should be 0 ohms.
It is a good idea to disconnect one side of the contact set you are checking. This ensures that you do not read an alternate/parallel circuit path.
Also use the most sensitive meter scale and short the meter leads together before starting. This will tell you if there is a zero offset in the meter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Dryer Won't Start jfemal Dryer Repair 9 04-27-2014 06:58 AM
Roper Dryer won't start timothy3784 Dryer Repair 1 08-08-2012 12:12 PM
Roper Dryer - no start Dorene Dryer Repair 7 03-26-2010 01:56 PM
Roper Dryer will not start Dennis Baca Dryer Repair 2 06-15-2009 05:43 AM
Roper Dryer won't start... deanna08 Dryer Repair 1 12-18-2008 03:55 PM
