Discuss
Heat Cuts off too Soon
 in
Dryer Repair
I have a Roper electric dryer that takes 3-4 cycles to dry clothes. It seems like the heat is cutting
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heat Cuts off too Soon
  #1 (permalink)
Old 09-11-2013, 07:46 AM
Junior Member
AlexW is on a distinguished road
Default Heat Cuts off too Soon
Brand: Roper   Age: 5 - 10 years
I have a Roper electric dryer that takes 3-4 cycles to dry clothes. It seems like the heat is cutting off too soon. The issue is more noticeable on low, but it takes at least 2 cycles to dry the clothing on high.
I get correct resistance at all of the thermostats and fuses. I went ahead and replaced the cycling thermostat anyway, but it did not help.
Any suggestions?
  #2 (permalink)
Old 09-11-2013, 07:35 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Whats the model number and is it gas or electric? Also check the venting leaving the unit and going out to the wall it should be like you have a blowdryer 3 from your hand if it's not fully blowing you have vent clogging and it needs to be cleaned.
  #3 (permalink)
Old 09-16-2013, 09:10 AM
Junior Member
Default
It's electric. Sorry, I don't have the model number right now, need to find the manual. I double checked the vent and it's clear all the way from behind the dryer out the house. It also blows hot air pretty hard from a good distance away.
Last night, it shut off after running timed dry on high for about 10 minutes. I tried starting it again both last night and this morning, and it won't start. I'll test all the thermostats/fuses tonight and report back. I'll also provide a part #.
  #4 (permalink)
Old 09-16-2013, 08:01 PM
Junior Member
Default
The dryer cut off due to the breaker tripping. I reset it, and it tripped again after 10 minutes. This is the first time I have had this happen. I haven't been able to locate a part number. I'd appreciate any advice you might have about how to proceed.
From some research online, I see that frequent breaker tripping may be due to a heating element short. I read 11 ohms when testing the element, which is within spec.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer heat cuts out after 3 minutes vandersen Dryer Repair 0 06-07-2012 08:09 AM
heat cuts off after a short time Big Ron Dryer Repair 4 06-06-2012 01:18 PM
Frigidaire Not heat cuts out john3931 Dryer Repair 0 05-11-2011 08:14 AM
Dryer runs with no heat but cuts out with heat on nicholas521 Dryer Repair 6 01-27-2011 05:19 PM
Whirlpool Gas Dryer - Heat Cuts Out jlindsey Dryer Repair 0 07-08-2010 09:07 PM
