| » dryer squeals suspect drum bearing |
Model Number: dbxr453et5ww Brand: GE Age: More than 10 years
Do I have to pull the back to get the top of the dryer off
If you open the door you should see some screws in the top inside jam which hold the top of the dryer to the cabinet. Take them out and the top should come off. You can now take off the front by unscrewing the two screws that hold it on, and be sure to mark how the lid switch wiring and any other wiring goes. If you take out the back service panel you can now release the belt, and then the drum comes out which will get you to the rear bearing assembly.
Good luck.
__________________
| Display Modes | |
| GE dryer drum bearing glides | kevin ulmer | Dryer Repair | 1 | 02-25-2010 02:20 PM |
| Dryer Front Drum Bearing Glides | Robert70 | Dryer Repair | 1 | 01-24-2010 12:52 PM |
| GE Dryer Front Drum Bearing Slides/Glides | osubuki | Dryer Repair | 1 | 06-29-2009 07:11 PM |
| replacing front drum bearing on GE dryer | Maryanne Daniel | Dryer Repair | 0 | 03-10-2009 05:54 AM |
| dryer drum squeals | Fuzzer | Dryer Repair | 3 | 09-28-2008 11:24 AM |
