Discuss
MayTag Dryer LDE9306ACE
 in
Dryer Repair
I took the front off the dryer to clean out the dryer vent tube and related parts. When I removed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » MayTag Dryer LDE9306ACE
  #1 (permalink)
Old 09-06-2013, 06:02 PM
Junior Member
mickeyd819 is on a distinguished road
Default MayTag Dryer LDE9306ACE
Model Number: LDE9306ACE   Brand: Maytag   Age: More than 10 years
I took the front off the dryer to clean out the dryer vent tube and related parts. When I removed the thermostat cover it fell across one of the cut off T pigtails and the dryer cabinet. Since I had forgotten to unplug the dryer, (I know, two college degrees, much electrical experience, etc.), it arced and melted part of the cover and the Cut Off T slide on connector. After unplugging the dryer and cleaning the parts I needed to clean, I reassembled the dryer, reconnected the Cut Off T, and tried to start it. It does not run. I checked continuity across the Cut Off T and had none. I figure the Cut Off T needs to be replaced. When watching the repair video, it said that the Cut Off T needs to be replaced if the dryer runs and does not heat. Mine won't start. Any suggestions on how to get me up and running again. I learned another valuable lesson today and hope you can help me get my dryer to run. I want to order all the parts needed at the same time. Thanks...
Related Models
Maytag LDE9306ACE DRYER- ELE
Maytag LDE9306ACM DRYER- ELE
Maytag LDE9306ADE DRYER- ELE
Maytag LDE9306ADM DRYER- ELE
Maytag LDE9306AEE DRYER- ELE
Maytag LDE9314ACE DRYER- ELE
Maytag LDE9314ACL DRYER- ELE
Maytag LDE9314ACM DRYER- ELE
Maytag LDE9314ADE DRYER- ELE
Maytag LDE9316ACE DRYER- ELE
Maytag LDE9316ACM DRYER- ELE
Maytag LDE9316ADE DRYER- ELE
Maytag LDE9334ACE DRYER- ELE
Maytag LDE9334ACL DRYER- ELE
Maytag LDE9334ACM DRYER- ELE
Maytag LDE9334ADE DRYER- ELE
Maytag LDE9606ACE DRYER- ELE
Maytag LDE9606ACM DRYER- ELE
Maytag LDE9606ADE DRYER- ELE
Maytag LDE9606ADM DRYER- ELE
Maytag LDE9606AEE DRYER- ELE
Maytag LDE9700 DRYER- ELE
Maytag LDE9700ACL DRYER- ELE
Maytag LDE9700ACW DRYER- ELE
Maytag LDE9700ADL DRYER- ELE
Maytag LDE9700ADW DRYER- ELE
Maytag LDE9701ACL DRYER- ELE
Maytag LDE9701ACW DRYER- ELE
Maytag LDE9701ADL DRYER- ELE
Maytag LDE9701ADW DRYER- ELE
Maytag LDE9800 DRYER- ELE
Maytag LDE9800ACL DRYER- ELE
Maytag LDE9800ACW DRYER- ELE
Maytag LDE9800ADL DRYER- ELE
Maytag LDE9800ADW DRYER- ELE
Maytag LDE9801ACL DRYER- ELE
Maytag LDE9801ACW DRYER- ELE
Maytag LDE9801ADL DRYER- ELE
Maytag LDE9801ADW DRYER- ELE
Maytag LDE9804ACE DRYER- ELE
Maytag LDE9804ACL DRYER- ELE
Maytag LDE9804ACM DRYER- ELE
Maytag LDE9804ADE DRYER- ELE
Maytag LDE9804ADL DRYER- ELE
Maytag LDE9804ADM DRYER- ELE
Maytag LDE9804AEE DRYER- ELE
Maytag LDE9806ACE DRYER- ELE
Maytag LDE9806ACM DRYER- ELE
Maytag LDE9806ADE DRYER- ELE
Admiral LDE9806GGE DRYER- ELE
Maytag LDE9814ACE DRYER- ELE
Maytag LDE9814ACL DRYER- ELE
Maytag LDE9814ACM DRYER- ELE
Maytag LDE9814ADE DRYER- ELE
Maytag LDE9824ACE DRYER- ELE
Maytag LDE9824ACL DRYER- ELE
Maytag LDE9824ACM DRYER- ELE
Maytag LDE9824ADE DRYER- ELE
Maytag LDE9900 DRYER- ELE
Maytag LDE9900ACL DRYER- ELE
Maytag LDE9900ACW DRYER- ELE
Maytag LDE9900ADL DRYER- ELE
Maytag LDE9900ADW DRYER- ELE
Maytag LDE9900BCL DRYER- ELE
Maytag LDE9900BCW DRYER- ELE
Maytag LDE9900BDL DRYER- ELE
Maytag LDE9900BDW DRYER- ELE
Maytag LDE9904ACE DRYER- ELE
Maytag LDE9904ACL DRYER- ELE
Maytag LDE9904ACM DRYER- ELE
Maytag LDE9904ADE DRYER- ELE
Admiral LDEA100ACL DRYER- ELE
Admiral LDEA100ACW DRYER- ELE
Admiral LDEA100BCE DRYER- ELE
Admiral LDEA100BCM DRYER- ELE
Admiral LDEA200ACE DRYER- ELE
Admiral LDEA200ACL DRYER- ELE
Admiral LDEA200ACM DRYER- ELE
Admiral LDEA200ACW DRYER- ELE
Admiral LDEA300AGE DRYER- ELE
Admiral LDEA300AGL DRYER- ELE
Admiral LDEA300AGW DRYER- ELE
Admiral LDEA300AKE DRYER- ELE
Admiral LDEA400ACE DRYER- ELE
Admiral LDEA400ACL DRYER- ELE
Admiral LDEA400ACM DRYER- ELE
Admiral LDEA400ACW DRYER- ELE
Admiral LDEA500ACE DRYER- ELE
Admiral LDEA500ACL DRYER- ELE
Admiral LDEA500ACM DRYER- ELE
Admiral LDEA500ACW DRYER- ELE
Hoover LDEH200ACV DRYER- ELE
Hoover LDEH200AGV DRYER- ELE
Hoover LDEH200AKV DRYER- ELE
 LDF6810BB Dishwasher
 LDF6810ST Dishwasher
 LDF6810WW Dishwasher
 LDF6920BB Dishwasher
 LDF6920ST Dishwasher
 LDF6920WW Dishwasher
 LDF7810BB Dishwasher
 LDF7810ST Dishwasher
 LDF7810WW Dishwasher
 LDF7811BB Dishwasher
 LDF7811ST Dishwasher
 LDF7811WW Dishwasher
 LDF7932ST Dishwasher
 LDF8812ST Dishwasher
 LDF9810ST Dishwasher
 LDF9932ST Dishwasher
Admiral LDG1000AAE DRYER- GAS
Maytag LDG110 DRYER- GAS
Maytag LDG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG18CT MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag LDG19CS MANUAL, PARTS (DRYER GAS)
Maytag LDG19CT MANUAL, PARTS (DRYER GAS)
Maytag LDG210 DRYER- GAS
  #2 (permalink)
Old 09-07-2013, 05:07 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag LDE9306ACE - AppliancePartsPros.com
It includes a wiring layout.
Here is a link to a service manual.
It has a wiring diagram.
You will have to join the site to be able to download the manual.
http://appliancejunk.com/forums/inde...a=view;down=53
This dryer is wired differently than most.
The thermal cut-off (thermal fuse - heater) and the thermal fuse (blower) are both wired into the motor circuit.
Could be that the cut-off is your only problem Though I would check the blower fuse just to be sure it is OK.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer Boogirl927 Dryer Repair 1 06-25-2012 04:40 PM
How do you open up the Maytag Electric Dryer cabinet to get to the dryer drum belt? Darrel Hedman Dryer Repair 1 05-13-2011 07:18 PM
maytag dryer dannyf@sweetwater.net Oven Repair (including Ranges and Cooktops) 1 01-14-2011 09:38 PM
maytag dryer help bowhunter1 Dryer Repair 3 11-23-2009 05:12 AM
Maytag Dryer Roncf Dryer Repair 3 10-21-2009 09:15 AM
