Discuss
maytag dryer takes three to four cycles to dry a load
 in
Dryer Repair
Ho folks: just replaced the heater/thermostat in my dryer and cleaned the lint passage all the way to the exhaust
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » maytag dryer takes three to four cycles to dry a load
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-02-2013, 06:58 PM
Junior Member
jscumm is on a distinguished road
Talking maytag dryer takes three to four cycles to dry a load
Brand: Maytag   Age: More than 10 years
Ho folks:
just replaced the heater/thermostat in my dryer and cleaned the lint passage all the way to the exhaust on the back, but it takes good 3 to 4 cycles to dry the clothes. To eliminate this problem I replaced the parts (heater/thermostat). The problem still remains.
What I noticed that it goes to max high temp, then cuts of and stays in a sort of warm temp mode to the finish.
Any suggestions from a pro in this forum?
Thanks a lot!
JS
  #2 (permalink)
Old 09-02-2013, 07:48 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Since you didn't specify the type of dryer or the model of the dryer check out these video's maybe they will help.
dryer doesnt stay hot - YouTube
  #3 (permalink)
Old 09-04-2013, 12:14 PM
Junior Member
Default
thanx for your response. The maytag's model is # PYE2300AZW.
I am not sure if there is low limit thermostat to kick back the heat on again. However, I replaced the element and hi limit thermostat recently which did not solve the problem.
The resistance on new element and thermostat was almost same (10 ohms and .5 ohms respectively)
As I mentioned I cleaned out all the lint to allow max air flow.
Thanks! lookin' for your response
JS
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag electric dryer takes 2 or 3 cycles to dry msta116949 Dryer Repair 1 06-30-2009 09:39 PM
dryer takes 2 or 3 cycles to dry Photoplay1 Dryer Repair 2 06-08-2009 05:07 AM
My dryer takes 3-4 cycles to dry IDEZ Dryer Repair 1 05-22-2009 03:30 PM
Takes 3 cycles to dry a load of clothes!!! Monica Oven Repair (including Ranges and Cooktops) 3 12-21-2008 02:33 PM
Takes 3 cycles to dry a load of clothes!!! Monica Dryer Repair 2 12-20-2008 05:06 AM
