Discuss
Gas Dryer doesn't heat & won't stop
 in
Dryer Repair
We've a Maytag gas dryer (MDG7600AWW) still running but do not produce enough heat up to dry clothes and the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer doesn't heat & won't stop
  #1 (permalink)
Old 08-28-2013, 07:47 AM
Junior Member
dduong is on a distinguished road
Default Gas Dryer doesn't heat & won't stop
Model Number: MDG7600AWW   Brand: Maytag   Age: 5 - 10 years
We've a Maytag gas dryer (MDG7600AWW) still running but do not produce enough heat up to dry clothes and the dryer continue to run after its cycle ended. The timer does advance. I've opened the panel below the door and checked that ignitor and gas valves lit up and continued to light normally. The vent is clear. There's a thin thermal fuse? two prongs on the right side and tested that there's continuity. Next to it is a four prongs (cycling thermostat or high limit) thermostat. This four prong is also tested for continuity and it's good on the two outside large prongs. The two inner small prong doesn't return any value when tested for resistance/continuity. Please advise what other parts I would need to test or replace and please point out where they are in the dryer. Also how many thermostats in this gas dryer and anything I need to check from the back panel as I have not opened the back to inspect anything yet?
Thank you in advance.
Related Models
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Admiral MDG8426AEW DRYER- GAS
Admiral MDG8426AGW DRYER- GAS
Maytag MDG8500BWW DRYER- GAS
Maytag MDG8506AWA DRYER- GAS
Maytag MDG8506AWW DRYER- GAS
Admiral MDG8550AGW DRYER- GAS
Admiral MDG8550BGW DRYER- GAS
Maytag MDG8600AWQ DRYER- GAS
Maytag MDG8600AWW DRYER
Maytag MDG8757AWQ DRYER- GAS
Maytag MDG8757AWW DRYER- GAS
Maytag MDG9206AWA DRYER- GAS
Maytag MDG9206AWW DRYER- GAS
Maytag MDG9206AXW DRYER- GAS
Maytag MDG9206BWW DRYER- GAS
Maytag MDG9306AWA DRYER- GAS
Maytag MDG9306AWW DRYER- GAS
Maytag MDG9306AXA DRYER- GAS
Maytag MDG9306AXW DRYER- GAS
Maytag MDG9316AWA DRYER- GAS
Maytag MDG9316AWQ DRYER- GAS
Maytag MDG9316AWW DRYER- GAS
Maytag MDG9316AXW DRYER- GAS
Maytag MDG9316BWQ DRYER- GAS
Maytag MDG9316BWW DRYER- GAS
Maytag MDG9357AWA DRYER- GAS
Maytag MDG9357AWW DRYER- GAS
Maytag MDG9360BWW DRYER- GAS
Maytag MDG9390AWW DRYER- GAS
Maytag MDG9390AXW DRYER- GAS
Maytag MDG9390BWW DRYER- GAS
Maytag MDG9420BWW DRYER- GAS
Maytag MDG9520BWQ DRYER- GAS
Maytag MDG9520BWW DRYER- GAS
Maytag MDG9557AWA DRYER- GAS
Maytag MDG9557AWQ DRYER- GAS
Maytag MDG9557AWW DRYER- GAS
Maytag MDG9557AXQ DRYER- GAS
Maytag MDG9557AXW DRYER- GAS
Maytag MDG9557BWQ DRYER- GAS
Maytag MDG9557BWW DRYER- GAS
Maytag MDG9606AWA DRYER- GAS
Maytag MDG9606AWQ DRYER- GAS
Maytag MDG9606AWW DRYER- GAS
Maytag MDG9606AXW DRYER- GAS
Maytag MDG9606BWQ DRYER- GAS
Maytag MDG9606BWW DRYER- GAS
Maytag MDG9700AWM DRYER- GAS
Maytag MDG9700AWW DRYER- GAS
Maytag MDG9706AWA DRYER- GAS
Maytag MDG9706AWW DRYER- GAS
Maytag MDG9766AWW DRYER- GAS
Maytag MDG9766AXW DRYER- GAS
Maytag MDG9800AWQ DRYER- GAS
Maytag MDG9800AWW DRYER- GAS
Maytag MDG9806AWA DRYER- GAS
Maytag MDG9806AWW DRYER- GAS
Maytag MDG9876AWW DRYER- GAS
Maytag MDGT236AWW DRYER- GAS
Maytag MDGT336AWW DRYER- GAS
Maytag MDGT446AWW DRYER- GAS
Frigidaire MDH13TN2
Frigidaire MDH13TN3
Frigidaire MDH15FN1
Frigidaire MDH15TF1 Frg(v1) / Dehumidifier
Frigidaire MDH15TF2 Frg(v1) / Dehumidifier
Frigidaire MDH15TF3 Frg(v1) / Dehumidifier
Frigidaire MDH15WG1 Gib(v0) / Dehumidifier
Frigidaire MDH15WW1 Wwh(v1) / Dehumidifier
 MDH24 DISHWASHER
Frigidaire MDH25TF1 Frg(v1) / Dehumidifier
Frigidaire MDH25TF2 Frg(v2) / Dehumidifier
Frigidaire MDH25TF3 Frg(v0) / Dehumidifier
Frigidaire MDH25TF4 Frg(v0) / Dehumidifier
Frigidaire MDH25TN1
Frigidaire MDH25WW1 Wwh(v2) / Dehumidifier
Frigidaire MDH25WW2 Wwh(v0) / Dehumidifier
Frigidaire MDH25YF1 Frg(v1) / Dehumidifier
Frigidaire MDH25YG2 Gib(v0) / Dehumidifier
Frigidaire MDH25YG3 Gib(v0) / Dehumidifier
Frigidaire MDH25YW1 Wwh(v0) / Dehumidifier
Frigidaire MDH25YW2 Wwh(v0) / Dehumidifier
Frigidaire MDH25YW3 Wwh(v0) / Dehumidifier
Frigidaire MDH25YW4 Wwh(v0) / Dehumidifier
Frigidaire MDH30GG1 Gib(v0) / Dehumidifier
Frigidaire MDH30TF1 Frg(v1) / Dehumidifier
Frigidaire MDH30TF2 Frg(v2) / Dehumidifier
Frigidaire MDH30TF3 Frg(v2) / Dehumidifier
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't heat and runs non stop. Paul LeGrande Dryer Repair 2 03-12-2014 02:21 PM
Dryer won't stop and no heat krazykarl05 Dryer Repair 4 02-04-2011 01:07 AM
Dryer will heat one load and stop? mwpenni Dryer Repair 1 10-28-2009 11:52 AM
Dryer won't heat up and doesn't stop running vbandpb Dryer Repair 3 01-28-2008 07:54 PM
GE Gas Dryer-no heat, doesn't stop tenor_ringer Dryer Repair 1 11-26-2007 02:35 PM
