Discuss
Roper RES7646KQ2 Not Working
 in
Dryer Repair
Yesterday morning dryer worked great like usual. Went to use it shortly after and it wouldn't turn on. Read a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper RES7646KQ2 Not Working
  #1 (permalink)
Old 08-23-2013, 05:31 PM
Junior Member
NormKyle is on a distinguished road
Default Roper RES7646KQ2 Not Working
Model Number: RES7646KQ2   Brand: Roper   Age: 1 - 5 years
Yesterday morning dryer worked great like usual. Went to use it shortly after and it wouldn't turn on. Read a little online and replaced the thermal fuse, buttoned it back up and it still won't turn on. I should mention that recently it would not shut off with the door open, only when the timer was set to OFF. Anything else I could check? Thanks in advance everybody.
Related Models
Roper RES7646KQ2 DRYER
Roper RES7646KQ3 29"ELECTRIC DRYER
Roper RES7648EN0 ELECTRIC DRYER
Roper RES7648EN1 DRYERS
Roper RES7648EN2 ELECTRIC DRYER
Roper RES7648EQ0 ELECTRIC DRYER
Roper RES7648EQ2 ELECTRIC DRYER
Roper RES7648EW0 ELECTRIC DRYER
Roper RES7648EW1 DRYERS
Roper RES7648EW2 ELECTRIC DRYER
Roper RES7648JQ0 ELECTRIC DRYER
Roper RES7648KQ0 DRYER
Roper RES7648KQ1 DRYER
Roper RES7745PQ0 29"ELECTRIC DRYER
Roper RES7745RQ0 29"ELECTRIC DRYER
Roper RES7745RQ1 29"ELECTRIC DRYER
 RESF3330DB RANGE- S/C F/S ELE
 RESF3330DW RANGE- S/C F/S ELE
 RESF5330DT RANGE- S/C F/S ELE
Roper REX2614LQ0 29"ELECTRIC DRYER
Roper REX3514PQ0 29"ELECTRIC DRYER
Roper REX3514RQ0 29"ELECTRIC DRYER
Roper REX3514RQ1 29"ELECTRIC DRYER
Roper REX3519PQ0 29" ELECTRIC DRYER
Roper REX3614JW0 ELECTRIC DRYER
Roper REX3614KW0 RESIDENTIAL DRYER
Roper REX3614KW1 DRYER
Roper REX3614KW2 29" ELECTRIC DRYER
Roper REX3614PW0 29" ELECTRIC DRYER
Whirlpool REX3614PW1 29" ELECTRIC DRYER
Roper REX3614PW2 29" ELECTRIC DRYER
Roper REX3615EW0 ELECTRIC DRYER
Roper REX3615EW1 DRYERS
Roper REX3615EW2 ELECTRIC DRYER
Roper REX4625EN0 ELECTRIC DRYER
Roper REX4625EW0 ELECTRIC DRYER
Roper REX4625EW1 DRYERS
Roper REX4625EW2 ELECTRIC DRYER
Roper REX4634JQ0 ELECTRIC DRYER
Roper REX4634KQ0 RESIDENTIAL DRYER
Roper REX4634KQ1 DRYER
Roper REX4634KQ2 29" ELECTRIC DRYER
Roper REX4635EN0 ELECTRIC DRYER
Roper REX4635EN1 DRYERS
Roper REX4635EN2 ELECTRIC DRYER
Roper REX4635EQ0 ELECTRIC DRYER
Roper REX4635EQ1 DRYERS
Roper REX4635EQ2 ELECTRIC DRYER
Roper REX4635EW0 ELECTRIC DRYER
Roper REX4635EW1 DRYERS
Roper REX4635EW2 ELECTRIC DRYER
Roper REX5634JQ0 ELECTRIC DRYER
Roper REX5634KQ0 RESIDENTIAL DRYER
Roper REX5634KQ1 DRYER
Roper REX5634KQ2 29" ELECTRIC DRYER
Roper REX5634PQ0 29" ELECTRIC DRYER
Roper REX5634PQ1 29" ELECTRIC DRYER
Roper REX5634RQ0 29" ELECTRIC DRYER
Roper REX5635EN0 ELECTRIC DRYER
Roper REX5635EN1 DRYERS
Roper REX5635EN2 ELECTRIC DRYER
Roper REX5635EQ0 ELECTRIC DRYER
Roper REX5635EQ1 DRYERS
Roper REX5635EQ2 ELECTRIC DRYER
Roper REX5635EW0 ELECTRIC DRYER
Roper REX5635EW1 DRYERS
Roper REX5635EW2 ELECTRIC DRYER
Roper REX5636AL1 ELECTRIC DRYER
Roper REX5636AL2 ELECTRIC DRYER
Roper REX5636AW0 Residential Dryer
Roper REX5636AW1 ELECTRIC DRYER
Roper REX5636AW2 ELECTRIC DRYER
Roper REX6634PQ0 29" ELECTRIC DRYER
Roper REX6634RQ0 29" ELECTRIC DRYER
Roper REX6634RQ1 29" ELECTRIC DRYER
Roper REX6646AL1 ELECTRIC DRYER
Roper REX6646AL2 ELECTRIC DRYER
Roper REX6646AL3 ELECTRIC DRYER
Roper REX6646AQ2 ELECTRIC DRYER
Roper REX6646AQ3 ELECTRIC DRYER
Roper REX6646AW0 Residential Dryer
Roper REX6646AW1 ELECTRIC DRYER
Roper REX6646AW2 ELECTRIC DRYER
Roper REX6646AW3 ELECTRIC DRYER
Whirlpool RF0100XKW0 Ranges, Electric*
Whirlpool RF0100XKW1 Ranges, Electric*
Whirlpool RF0100XRN8 Ranges, Electric*
Whirlpool RF0100XRW0 Ranges, Electric*
Whirlpool RF0100XRW1 Ranges, Electric*
Whirlpool RF0100XRW2 Ranges, Electric*
Whirlpool RF0100XRW3 Ranges, Electric*
Whirlpool RF0100XRW4 Ranges, Electric*
Whirlpool RF0100XRW5 Ranges, Electric*
Whirlpool RF0100XRW7 Ranges, Electric*
Whirlpool RF0100XRW8 Ranges, Electric*
Whirlpool RF0100XRW9 Ranges, Electric*
Whirlpool RF010ESPW0 Ranges, Electric*
Whirlpool RF010EXPW0
Whirlpool RF010EXRW0 Ranges, Electric*
Whirlpool RF010EXRW1 Ranges, Electric*
Whirlpool RF010EXRW2 Ranges, Electric*
Whirlpool RF014PXRW0 Ranges, Electric*
Whirlpool RF110AXSQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXSQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXSQ2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXSQ3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXST0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXST1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF110AXST2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSQ3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF111PXSW3 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF114PXSB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF114PXSB1 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool RF114PXSB2 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
  #2 (permalink)
Old 08-23-2013, 06:44 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Sounds like your having an issue with your door switch check it for continuity......if a door switch doesn't stop while opening or now your unit won't power up the door switch will not allow it to start if it's not functioning properly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Dryer Not Working venkman Dryer Repair 1 11-19-2011 09:06 AM
Roper stopped working wifemomo4 Washer Repair 0 12-04-2010 01:45 PM
My Roper dryer not working rryker1971 Dryer Repair 5 07-08-2009 03:33 PM
Roper Dryer Timer Working But Nothing ELSE fixit318 Dryer Repair 4 11-20-2008 11:29 PM
Roper Dryer not working at all now cpego123 Dryer Repair 2 09-19-2007 05:46 PM
