Discuss
frigidaire affinity e64
 in
Dryer Repair
Dryer cuts off and starts beeping after 2 to 3 minutes with a message saying call for service E 64
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » frigidaire affinity e64
  #1 (permalink)
Old 08-23-2013, 09:26 AM
Junior Member
tommmckinney is on a distinguished road
Default frigidaire affinity e64
Model Number: fase7074lr0   Brand: Frigidaire   Age: 1 - 5 years
Related Models
Frigidaire FASE7074LR0 ELECTRIC DRYER
Frigidaire FASE7074LW0 ELECTRIC DRYER
Frigidaire FASG7073LA0 GAS DRYER
Frigidaire FASG7073LN0 GAS DRYER
Frigidaire FASG7073LR0 GAS DRYER
Frigidaire FASG7073LW0 GAS DRYER
Frigidaire FASG7074LA0 GAS DRYER
Frigidaire FASG7074LN0 GAS DRYER
Frigidaire FASG7074LR0 GAS DRYER
Frigidaire FASG7074LW0 GAS DRYER
Frigidaire FAV157F1A1 Frg/room Air Conditioner
Frigidaire FAV157F1A2 Frg(v0) / Room Air Conditioner
Frigidaire FAV157G1A1 Frg(v0) / Room Air Conditioner
Frigidaire FAV157G1A2 Frg(v0) / Room Air Conditioner
Frigidaire FAV157S1A1 Frg(v1) / Room Air Conditioner
Frigidaire FAV157S1A2 Frg(v1) / Room Air Conditioner
Frigidaire FAV157W1A1 Frg(v0) / Room Air Conditioner
Frigidaire FAV157W1A2 Frg(v0) / Room Air Conditioner
Frigidaire FAV18EJ2A1 Frg(v0) / Room Air Conditioner
Frigidaire FAV18EJ2A2 Frigidaire/air Conditioner
Frigidaire FAV18EJ2A3 Frigidaire/air Conditioner
Maytag FAV6800AWQ WASHER-TOP LOADING
Maytag FAV6800AWW WASHER-TOP LOADING
Maytag FAV9800AWQ WASHER-TOP LOADING
Maytag FAV9800AWW WASHER-TOP LOADING
Frigidaire FAX050P7A1 Frigidaire/air Conditioner
Frigidaire FAX050P7A2 Frigidaire/air Conditioner
Frigidaire FAX050P7A3 Frigidaire/air Conditioner
Frigidaire FAX050P7A4 Frigidaire/air Conditioner
Frigidaire FAX050P7A5 Frigidaire/air Conditioner
Frigidaire FAX050P7A6 Frigidaire/air Conditioner
Frigidaire FAX050P7A7 Frigidaire/air Conditioner
Frigidaire FAX050P7A8 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX050P7AENG6 Frigidaire/air Conditioner
Frigidaire FAX050S7A11 ROOM AIR CONDITIONER
Frigidaire FAX050S7A12 ROOM AIR CONDITIONER
Frigidaire FAX050S7A13 ROOM AIR CONDITIONER
Frigidaire FAX050S7A14 ROOM AIR CONDITIONER
Frigidaire FAX050S7A15 ROOM AIR CONDITIONER
Frigidaire FAX050S7A16 ROOM AIR CONDITIONER
Frigidaire FAX050S7A17 ROOM AIR CONDITIONER
Frigidaire FAX050S7AA ROOM AIR CONDITIONER
Frigidaire FAX050S7AB ROOM AIR CONDITIONER
Frigidaire FAX050S7AC ROOM AIR CONDITIONER
Frigidaire FAX050S7AD ROOM AIR CONDITIONER
Frigidaire FAX050S7AE ROOM AIR CONDITIONER
Frigidaire FAX050S7AF ROOM AIR CONDITIONER
Frigidaire FAX051P7A1 Frigidaire/air Conditioner
Frigidaire FAX051P7A2 Frigidaire/air Conditioner
Frigidaire FAX051P7A3 Frigidaire/air Conditioner
Frigidaire FAX051P7A4 Frigidaire/air Conditioner
Frigidaire FAX051P7A5 Frigidaire/air Conditioner
Frigidaire FAX051P7A6 Frigidaire/air Conditioner
Frigidaire FAX052P7A1 Frigidaire/air Conditioner
Frigidaire FAX052P7A11 ROOM A/C
Frigidaire FAX052P7A12 ROOM A/C
Frigidaire FAX052P7A13 ROOM A/C
Frigidaire FAX052P7A14 ROOM A/C
Frigidaire FAX052P7A15 ROOM A/C
Frigidaire FAX052P7A16 ROOM A/C
Frigidaire FAX052P7A2 Frigidaire/air Conditioner
Frigidaire FAX052P7A3 Frigidaire/air Conditioner
Frigidaire FAX052P7A4 Frigidaire/air Conditioner
Frigidaire FAX052P7A5 Frigidaire/air Conditioner
Frigidaire FAX052P7A6 Frigidaire/air Conditioner
Frigidaire FAX052P7AA ROOM A/C
Frigidaire FAX052P7AB ROOM A/C
Frigidaire FAX052P7AC ROOM A/C
Frigidaire FAX052P7AD ROOM A/C
Frigidaire FAX052P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX052P7AENG6 Frigidaire/air Conditioner
Frigidaire FAX054P7A1 Frigidaire/air Conditioner
Frigidaire FAX054P7A11 ROOM A/C
Frigidaire FAX054P7A12 ROOM A/C
Frigidaire FAX054P7A13 ROOM A/C
Frigidaire FAX054P7A14 ROOM A/C
Frigidaire FAX054P7A15 ROOM A/C
Frigidaire FAX054P7A16 ROOM A/C
Frigidaire FAX054P7A2 Frigidaire/air Conditioner
Frigidaire FAX054P7A3 Frigidaire/air Conditioner
Frigidaire FAX054P7A4 Frigidaire/air Conditioner
Frigidaire FAX054P7A5 Frigidaire/air Conditioner
Frigidaire FAX054P7A6 Frigidaire/air Conditioner
Frigidaire FAX054P7AA ROOM A/C
Frigidaire FAX054P7AB ROOM A/C
Frigidaire FAX054P7AC ROOM A/C
Frigidaire FAX054P7AD ROOM A/C
Frigidaire FAX054P7AENG1 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG2 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG3 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG4 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG5 Frigidaire/air Conditioner
Frigidaire FAX054P7AENG6 Frigidaire/air Conditioner
Frigidaire FAZ085S1AA ROOM A/C
Frigidaire FAZ085S1AB ROOM A/C
Frigidaire FAZ085S7AA ROOM A/C
Frigidaire FAZ085S7AB ROOM A/C
Frigidaire FAZ08ES1AA ROOM A/C
Frigidaire FAZ08ES1AB ROOM A/C
Frigidaire FAZ08HR1A1 Frigidaire/air Conditioner
Frigidaire FAZ08HS1A11 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A12 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A13 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A14 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A15 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1A16 ROOM AIR CONDITIONER
Frigidaire FAZ08HS1AA ROOM AIR CONDITIONER
Frigidaire FAZ08HS1AB ROOM AIR CONDITIONER
Frigidaire FAZ105S1AA ROOM A/C
Frigidaire FAZ105S1AB ROOM A/C
Frigidaire FAZ125S1AA ROOM A/C
  #2 (permalink)
Old 08-23-2013, 07:16 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Take the dryer apart there should be a tech sheet inside, your having a problem with the heating circuit. Ohm test all the thermostats in that circuitry you probably have something burned out somewhere. Here's your wire schematics and parts. Good luck
Parts for Frigidaire FASE7074LR0 Dryer - AppliancePartsPros.com
  #3 (permalink)
Old 08-24-2013, 05:40 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Below is a more legible wiring diagram.
Just in case the tech sheet is not with your unit.
http://manuals.frigidaire.com/prodin.../137507300.pdf
I could not find one for your unit so it is for a FASE7074NA2.
As far as I can see the only difference is that this unit has a drum light so the door switch is different.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Affinity Won't Spin JohnnyG 9 Washer Repair 10 07-06-2013 05:00 PM
Frigidaire Affinity Navywife Washer Repair 1 09-05-2012 05:22 PM
Error dr on affinity frigidaire Nanook Washer Repair 0 08-03-2012 02:10 PM
Frigidaire affinity E41 error, PAU ivinio21 Washer Repair 0 09-28-2011 03:51 PM
Frigidaire affinity mrsakman Dishwasher Repair 1 10-23-2008 07:43 PM
