Discuss
Maytag Intellidry Dryer knob has to be twisted around and around to get heat going
 in
Dryer Repair
The knob on my Maytag Intellidryer must be twisted around a couple of times to get the heat setting I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Intellidry Dryer knob has to be twisted around and around to get heat going
  #1 (permalink)
Old 10-09-2009, 12:25 PM
Junior Member
jjjules is on a distinguished road
Default Maytag Intellidry Dryer knob has to be twisted around and around to get heat going
Model Number: MDE3500AYW   Brand: Maytag   Age: 5 - 10 years
The knob on my Maytag Intellidryer must be twisted around a couple of times to get the heat setting I need to start the dryer when I push the start button. The arrow on the knob does not match up with the actual setting I am trying to use. I can easily pull the knob off and there does seem to be a slight crack on either side of the part that goes over the piece of the smooth metal screw that sticks out of the dryer, but would that be enough to screw up the timing or could it be the actual timer???
Ads By Google
Related Models
Maytag MDE3500AYW Dryer - Ele
Maytag MDE3500AZW Dryer - Ele
Maytag MDE3600AYQ Dryer - Ele
Maytag MDE3600AYW Dryer - Ele
Maytag MDE3600AZW Dryer - Ele
International MDE3706AGW Dryer - Ele
International MDE3706AKW Dryer - Ele
Maytag MDE3706AYW Dryer - Ele
Maytag MDE3706AZW Dryer - Ele
Maytag MDE3757AYW Dryer - Ele
Maytag MDE3758AYW Dryer - Ele
Maytag MDE3758AZW Dryer - Ele
Maytag MDE4000AYQ Dryer - Ele
Maytag MDE4000AYW Dryer - Ele
Maytag MDE4000AZQ Dryer - Ele
Maytag MDE4000AZW Dryer - Ele
Maytag MDE4057AYA Dryer - Ele
Maytag MDE4057AYQ Dryer - Ele
Maytag MDE4057AYW Dryer - Ele
Maytag MDE4057AYY Dryer - Ele
Frigidaire MDE436RBD0 Frg(v2) / 27 " Electric Dryer
Frigidaire MDE436RBD1 Wwh(v4) / Electric Dryer
Frigidaire MDE436RBD2 Frg(v3) / Electric Dryer
Frigidaire MDE436RBW0 Tap(v10) / 27 " Electric Dryer
Frigidaire MDE436RBW1 Wwh(v5) / Electric Dryer
Frigidaire MDE436RBW2 Frg(v4) / Electric Dryer
Frigidaire MDE436RBWD0 Gib(v14) / 27 " Electric Dryer
Frigidaire MDE436RBWL0 Frg(v2) / 27 " Electric Dryer
Frigidaire MDE436RBWW0 Frg(v1) / 27 " Electric Dryer
Frigidaire MDE436RED0 Frg(v1) / Electric Dryer
Frigidaire MDE436RED1 Frg(v1) / Electric Dryer
Frigidaire MDE436REW0 Frg(v2) / Electric Dryer
Frigidaire MDE436REW1 Frg(v2) / Electric Dryer
Maytag MDE4658AYW Dryer - Ele
Maytag MDE4806AYW Dryer - Ele
Maytag MDE4806AZW Dryer - Ele
Maytag MDE4916AYA Dryer - Ele
Maytag MDE4916AYW Dryer - Ele
Maytag MDE4916AZW Dryer - Ele
Maytag MDE5000AYQ Dryer - Ele
Maytag MDE5000AYW Dryer - Ele
Maytag MDE5000AZW Dryer - Ele
Maytag MDE508DAYK Dryer - Ele
Maytag MDE508DAYW Dryer - Ele
Frigidaire MDE546RED0 Frg(v1) / Electric Dryer
Frigidaire MDE546RED1 Frg(v1) / Electric Dryer
Frigidaire MDE546RES0 Frg(v2) / Electric Dryer
Frigidaire MDE546RES1 Frg(v2) / Electric Dryer
Frigidaire MDE546RET0 Frg(v3) / Electric Dryer
Frigidaire MDE546REW0 Frg(v4) / Electric Dryer
Frigidaire MDE546REW1 Frg(v3) / Electric Dryer
Maytag MDE5500AYQ Dryer - Ele
Maytag MDE5500AYW Dryer - Ele
Maytag MDE5500AZQ Dryer - Ele
Maytag MDE5500AZW Dryer - Ele
Maytag MDE5806AYK Dryer - Ele
Maytag MDE5806AYW Dryer - Ele
Maytag MDE5806AZK Dryer - Ele
Maytag MDE5806AZW Dryer - Ele
Maytag MDE5960AYW Dryer - Ele
Maytag MDE6000AUW Dryer - Ele
Maytag MDE6000AYQ Dryer - Ele
Maytag MDE6000AYW Dryer - Ele
Maytag MDE6000AZQ Dryer - Ele
Maytag MDE6000AZW Dryer - Ele
Maytag MDE6200AYQ Dryer - Ele
Maytag MDE6200AYW Dryer - Ele
Maytag MDE6200AZQ Dryer - Ele
Maytag MDE6200AZW Dryer - Ele
Maytag MDE6400AGW Dryer - Ele
Maytag MDE6400AYQ Dryer - Ele
Maytag MDE6400AYW Dryer - Ele
Maytag MDE6400AZW Dryer - Ele
Maytag MDE6460AYW Dryer - Ele
Maytag MDE6460AZW Dryer - Ele
Maytag MDE6657BYQ Dryer - Ele
Maytag MDE6657BYW Dryer - Ele
Maytag MDE6700AYW Dryer - Ele
Maytag MDE6700AZW Dryer - Ele
Maytag MDE6800AYB Dryer - Ele
Maytag MDE6800AYQ Dryer - Ele
Maytag MDE6800AYW Dryer - Ele
Maytag MDE6800AZQ Dryer - Ele
Maytag MDE6800AZW Dryer - Ele
Maytag MDE7057AYQ Dryer - Ele
Maytag MDE7057AYW Dryer - Ele
Maytag MDE7057AZW Dryer - Ele
Maytag MDE7400AYQ Dryer - Ele
Maytag MDE7400AYW Dryer - Ele
Maytag MDE7400AZQ Dryer - Ele
Maytag MDE7400AZW Dryer - Ele
Maytag MDE7460AYQ Dryer - Ele
Maytag MDE7460AYW Dryer - Ele
Maytag MDE7500AYQ Dryer - Ele
Maytag MDE7500AYW Dryer - Ele
Maytag MDE7500AZQ Dryer - Ele
Maytag MDE7500AZW Dryer - Ele
Maytag MDE7550AGW Dryer - Ele
International MDE7550AGW Dryer - Ele
Maytag MDE7600AUW Dryer - Ele
Maytag MDE7600AYQ Dryer - Ele
Maytag MDE7600AYW Dryer - Ele
Maytag MDE7600AZQ Dryer - Ele
Maytag MDE7600AZW Dryer - Ele
Maytag MDE7657AYQ Dryer - Ele
Maytag MDE7657AYW Dryer - Ele
Maytag MDE7657BYQ Dryer - Ele
Maytag MDE7657BYW Dryer - Ele
Maytag MDE7658AYQ Dryer - Ele
Maytag MDE7658AYW Dryer - Ele
Maytag MDE7658BYQ Dryer - Ele
Maytag MDE7658BYW Dryer - Ele
Maytag MDE7757AYQ Dryer - Ele
Maytag MDE7757AYW Dryer - Ele
Maytag MDE7758AYQ Dryer - Ele
Maytag MDE7758AYW Dryer - Ele
Maytag MDE8000AYQ Dryer - Ele
Maytag MDE8000AYW Dryer - Ele
Maytag MDE8000AZW Dryer - Ele
Maytag MDE8057AYQ Dryer - Ele
  #2 (permalink)
Old 10-10-2009, 05:27 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
It is probably the timer knob. Try to determine the correct orientation of the flat part of the timer knob shaft, and then turn it with a pair of pliers and see if it engages the cycles as it should. If it does replace the timer knob.
Occasionally you have this problem when the timer has broken away from the console, but this is more of problem with GE machines.
__________________
  #3 (permalink)
Old 10-15-2009, 03:06 PM
Junior Member
Default
Thank you. It was the timer knob. The problem I am having now is that when installing it I cannot get it to slide all the way down over the screw, so it is sticking about a half inch up from where it should be. It still works, but it doesn't look right. Any idea how to make it slide down without breaking it.
There seems to be a thin insert in the hole that the original did not have.I'm guessing Maytag figured out there was a problem with these knobs cracking so easily and this is their correction.
  #4 (permalink)
Old 10-15-2009, 04:00 PM
Senior Expert
APP Volunteer
Default
Well, good that you got it fixed and at an inexpensive price, but I know you want it to look good too.\
I don't know about that particular knob, but sometimes there is a ferrule or piece that stays on the shaft. Other than that I cannot think of a reason why the new one should not go on like the old, but it may be something you will have to live with.
Thanks for updating us, glad you got it going.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gas Dryer Won't Heat gregk5 Dryer Repair 4 10-31-2009 06:28 PM
Maytag Gas Dryer Does Not Heat JJAAYYFF Dryer Repair 3 04-22-2009 02:28 PM
Dryer won't heat and timer knob not moving Calicia Dryer Repair 4 03-30-2009 05:12 PM
Maytag dryer won't heat again Striker Dryer Repair 1 09-01-2008 05:08 PM
Dryer Intellidry Mode Problem danceilike Dryer Repair 0 08-26-2008 10:58 AM
