greg.od11@gmail.com
#1 Posted : Wednesday, August 21, 2013 3:29:48 PM(UTC)
greg.od11@gmail.com
Puzzling gas dryer
No heat after initial 13 sec burn. Igniter ok. fuse ok. exhaust clear. Now hear is the puzzle with cabinet open drum out, the burner last 13 sec over and over.
Put it back together and only 1- 13 sec burn ??????:mad: Help !!!!:)
HumboldtRepairMan
#2 Posted : Wednesday, August 21, 2013 7:51:15 PM(UTC)
HumboldtRepairMan
Sounds exactly like bad coils watch this video..........it also could be a faulty thermostat, ignitor, or even bad venting.....check the air flow going outside and if necessary pull the vent hose off the back and test it not hooked up to the wall.........if your problem goes away you have a clog in the vent and if it doesn't tear it down and start doing continuity tests on the parts inside as the video shows
Gas Dryer Repair Video: Heating Problems - YouTube
greg.od11@gmail.com
#3 Posted : Thursday, August 22, 2013 4:56:24 AM(UTC)
greg.od11@gmail.com
U tube link was a big help:)
Maytag MEDC200XW1 - Intermittent heat and no buzzer (Dryer Repair)
by Lemarac 1/9/2019 4:09:17 PM(UTC)
electric dryer intermittent heat (Dryer Repair)
by wags1970 7/11/2017 9:31:33 AM(UTC)
gas dryer with intermittent heat (Dryer Repair)
by highpoint 1/21/2017 12:14:48 PM(UTC)
Intermittent Heating (Dryer Repair)
by lccent 8/7/2015 9:19:56 AM(UTC)
Intermittent heating. Now none. (Microwave Repair)
by bstruss 2/23/2015 6:29:10 PM(UTC)
Intermittent heating problem with gas dryer (Dryer Repair)
by David L. Mandel 8/16/2014 8:21:23 PM(UTC)
by colbey 7/11/2014 4:55:38 PM(UTC)
LG electric dryer Intermittent Heat (Dryer Repair)
by Saurin 10/2/2013 7:41:23 PM(UTC)
Gas Dryer Intermittent Heat (Dryer Repair)
by FranDaMan 7/4/2013 6:53:18 PM(UTC)
by gvel 5/19/2013 3:38:09 PM(UTC)
Gas Dryer - Intermittent heat, checked coils and igniter (Dryer Repair)
by nevets 11/18/2012 6:14:02 PM(UTC)
by rcady52 10/26/2012 12:03:54 PM(UTC)
Whirlpool Super Capacity 465 Oven...intermittent heating issue (Oven Repair (including Ranges and Cooktops))
by wetzelbp 9/3/2012 4:25:33 PM(UTC)
Maytag Dryer Intermittent Heat (Dryer Repair)
by jayjaysin 6/24/2012 4:59:26 PM(UTC)
Whirlpool LGQ9857LW0 Intermittent heat (Dryer Repair)
by deanm11 6/17/2012 4:08:12 PM(UTC)
