Discuss
Roper (whirlpool) won't start. Tried all the usual problems.
 in
Dryer Repair
Hello, I have been frequenting this helpful forum for a long time and can usually find the answer I need
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Roper (whirlpool) won't start. Tried all the usual problems.
  #1 (permalink)
Old 08-21-2013, 07:18 AM
Junior Member
forstm is on a distinguished road
Default Roper (whirlpool) won't start. Tried all the usual problems.
Brand: Roper   Age: 1 - 5 years
Hello,
I have been frequenting this helpful forum for a long time and can usually find the answer I need without asking. However, I'm stuck right now.
I have a Roper dryer that won't start. It worked fine until yesterday. Now it is dead and will not start. I have looked at other posts and can confirm.
1. There is proper 240W of power coming in from the plug.
2. The Thermal Fuse is good. I even tried the trick of connecting the two blue wires to double check it wasn't the fuse.
3. The start button works when disconnecting it and using an Ohm tester.
4. The door switch works when disconnecting it and using an Ohm tester.
UGH, I was hoping this would be any easy fix. Any help would be greatly appreciated. I don't want to have to call a repair man since this isn't an expensive dryer. If i have to pay him, I might as well just buy a new one.
Thanks!
  #2 (permalink)
Old 08-21-2013, 09:17 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Did you check for 120 volts?
On most units the motor runs off of 120: L1 to Neutral (black to white)
__________________
  #3 (permalink)
Old 08-21-2013, 09:26 AM
Junior Member
Default
The model number is RED4440VQ1
I used a multimeter on the three connections on the back while plugged into the wall. It is getting 120V/120V/240V when you do the left-middle. right-middle, outer two test.
  #4 (permalink)
Old 08-21-2013, 09:55 AM
Senior Expert
APP Volunteer
Default
See the attachment for the wiring diagram.
Since you have already check some components I would check timer contacts C to B. They should be closed in any cycle type.
It is a good idea to disconnect the wires going to at least one of them. This prevents you from reading a parallel/alternate circuit path. Also use your most sensitive meter scale.
If that check out OK then I would connect one meter lead to L1 at the power cord end and leave it there. Now work your way back through the motor circuit to find the open.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper Dryer spinning, no heat (Not usual suspects) dizzum28 Dryer Repair 2 03-02-2013 01:37 PM
Roper (Whirlpool) dryer won't start Quasimodo1234 Dryer Repair 7 10-22-2012 08:32 AM
Roper by Whirlpool Dryer Wont Start cjduke Dryer Repair 1 07-31-2011 03:34 AM
Amana Dryer Won't Start - None of the Usual Suspects AmyandLouie Dryer Repair 1 02-08-2010 02:01 AM
Whirlpool Dishwasher Water Cycles running longer than usual Patricia Ratliff Dishwasher Repair 0 02-03-2010 10:21 AM
