Discuss
Kenmore / Whirlpool Heat Issue
 in
Dryer Repair
This is the Kenmore Dryer: 110-66912692 I have a heating problem. The heat will not shut off and subsequently blows
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore / Whirlpool Heat Issue
  #1 (permalink)
Old 08-20-2013, 09:03 AM
Junior Member
cjwoodlee is on a distinguished road
Default Kenmore / Whirlpool Heat Issue
Model Number: 110-66912692   Brand: Kenmore   Age: More than 10 years
110-66912692
I have a heating problem. The heat will not shut off and subsequently blows the fuse.
Cycling thermostat and high limit thermostat are OK / new.
HEATER coil test good at 10 ohms. *It is not shorting to the housing frame anywhere. Confirmed / reconfirmed several times. Also, upon visual inspection coil looks good. (Entire harness is clean no nicks, cuts, burns etc.) The heater only comes on when the dryer is started. NOT when the timer is turned to an "on" setting before starting the dryer. It can be heard running "ticking" when moved to on. The heating element will shut off after turning off the dryer but only after it is manually stopped.
The timer had a loose / broken contact point tip between the white & tan terminals inside. *I have ordered a new FSP timer. Obviously the timer is an issue but I am unsure if this powering of the heating element / coil issue will be solved, yet, by replacing just the timer.
The Drive Motor switch appears to be ok. Motor was removed. Contact cover removed. Contacts are not welded shut. Continuity between options tests good for contact & release.
Entire unit is extremely clean and well cared for at 14 (fourteen) years old. (No obstructions in venting.)
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 08-21-2013, 06:47 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
See the attachment for the wiring diagram..
Just to be sure, is this the thermal fuse on the blower?
Often people also call the thermal cut-off on the heater a fuse.
I am assuming that this can be done by opening the door or turning the timer to off.
Does the heater stay off in air only?
Does low heat setting actually change the heat output?
I also doubt this is your problem as the timer cannot keep the heater on as even if Timer Switch 2 was shorted (contacts welded together) the cycling thermostat should regulate the heat.
You seem to have done a very thorough job of troubleshooting so I am also pretty well stumped.
Although the odds are very high I would check the new operating thermostat.
Hold it onto a stove element or heat it's face with a soldering gun to be sure that it will open.
If your oven temperature regulation is good then you could even put it in there to see if it does open at around 150 degrees F.
__________________
  #3 (permalink)
Old 08-21-2013, 08:02 AM
Junior Member
Default
Quote:
*Thanks for the schematic.
*This is the thermal cut-off on the heater.
I am assuming that this can be done by opening the door or turning the timer to off. *Yes, opening the door or turning off at the timer.
Does the heater stay off in air only? *Stays OFF on Air Dry
Does low heat setting actually change the heat output? *Low heat setting DOES NOT change the symptoms - heater stays on constant.
*I have performed the griddle test on both the cycling thermostat and the limiter on the heater. Both are new FSP. **I have suspected the temp setting selector switch. The continuity tone on the meter on the low setting goes haywire before fizzling out. Symptoms do remain unchanged with the temp selector unplugged, as heater still stays on. (The blue resistors on the plug show continuity although I did not compare against thier color coding values) I guess this works by the selector fooling the cycling thermo with a heater.
*Also, the unit sometimes will not start on air dry until the timer was moved a ltttle. It would then start without the start switch relay. However, I suspect the new timer will clear this up. But it has also had me wandering if the start switch / relay is also suspect.
  #4 (permalink)
Old 08-21-2013, 10:01 AM
Senior Expert
APP Volunteer
Default
The thermal cut-off is a different kettle of fish.
Check all seals in the unit including drum and blower.
The reason is that the from the heater up to the blower the system is actually under a vacuum. If it sucks in room air then the cycling thermostat sees this and keeps the heater on.
Check the lint filter. Sometimes fabric softener residue can coat it reducing the air flow through the system. It should be cleaned with soap and water if coated.
I do not think it is in this area. In normal/high heat they are disconnected.
I am not sure about the fizzling out.
Yes it adds heat to the thermostat so it thinks the unit is hotter than it actually is.
I seems strange that it keeps popping the thermal cut-off.
The hi-limit should prevent this. It should open at 225 while the thermal cut-off is at 350 degrees F.
One thing to note is that the hi-limit is just a safety with the thermal cut-off as an extra safety. So if it does start opening/closing it will not last very long.
Unlike the operating thermostat whose contacts are made to do this all the time.
__________________
  #5 (permalink)
Old 08-21-2013, 04:59 PM
Junior Member
Default
Ok This makes sense, after the timer arrives I will ensure the cycling thermo is working at spec, again. Then I will check the integrity of the heater box. I did order a new seal for the blower to housing ring. Also, there is that seal from the lint screen box to the blower box and the drum felts, of course. There is also that tube vent (probably for lint overstuffing bypass). What I am going to do then is use a butane torch to heat up the cycling thermo. If it cycles then obviously there are sealing integrity issues. Hopefully, it would be nice to see the timer get this done. Give me until Saturday since I can't pick this back up until Friday.
  #6 (permalink)
Old 08-21-2013, 05:13 PM
Junior Member
Default
I don't know if there is such a thing as a partially burn't out coil and it would not be getting hot enough, as well. i am at 10 ohms - enough to go over 360 - Make sense on the integrity seals
  #7 (permalink)
Old 08-21-2013, 06:02 PM
Senior Expert
APP Volunteer
Default
Your coil resistance is within the specification.
Also you have checked it to be sure it is not grounded.
I am not totally ruling it out but it would have to be something weird going on with it.
__________________
  #8 (permalink)
Old 08-24-2013, 04:40 PM
Junior Member
Default And the verdirct is...?
Thanks for the help.
When I arrived home this Sat afternoon, the new FSP timer had arrived.
***This solved the problem!
***We thank our God and Father of Jesus Christ and yourself for providing the way and help, of course.
After studying the schematic this week some I was becoming more confident (yes hoping) that the way the contact was broken T ~ W OR neutral was bypassing the cycling thermostat through the motor switches?
SEE SCHEMATIC timer switch 4.
So, I believe, since this would not stop making contact when it should on all cycles the white neutral actually became a direct "constant red"?
It is like a new unit. Every inch of this thing is clean. We have a new cycling thermostat on the blower box, thermal cut off "fuse" & high limit thermo on the heater. All FSP made in the USA. When it cycles is sounds nice and tight. Plus you can not hear the new timer running.
With the unit venting into the laundry room, no clothes in the dryer with the lint screen in place, cycling times are: 1) On the lowest setting - 70 (seventy) seconds 2) On the highest setting (or "roast 'em good") - 95 (ninety-five) seconds.
Next project: If you would like I will provide you with my research on the vent to out side booster vent fan options from FANTECH that I plan to install, next. This should ensure it keeps it well vented and reduces drying times, as well!
Thank You, Chris Huntsville, AL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool/Kenmore Dryer Timer Issue MartinezAppliance Dryer Repair 0 01-25-2013 01:34 PM
Whirlpool - Sears Kenmore won't heat, blows the diode uruiamme Microwave Repair 8 11-15-2012 02:00 PM
Kenmore (Whirlpool) Dryer will not heat bonzai90210 Dryer Repair 1 03-18-2012 07:48 AM
Kenmore (Whirlpool) dryer will not heat JByrd Dryer Repair 5 04-24-2011 08:12 PM
Another No Heat Issue S51flyer Dryer Repair 7 10-31-2008 10:42 AM
