Discuss
LG Dryer Won't Heat After a Fire
 in
Dryer Repair
We just bought a new house and a new dryer ( LG DLE2250W ). We used the dryer several times
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » LG Dryer Won't Heat After a Fire
  #1 (permalink)
Old 08-15-2013, 01:28 PM
Junior Member
ncbutterfield is on a distinguished road
Default LG Dryer Won't Heat After a Fire
Model Number: DLE2250W   Brand: -other-   Age: Less than 1 year
We just bought a new house and a new dryer ( LG DLE2250W ). We used the dryer several times before there was a fire due the previous owners of the house having not cleaned the vent in a while, if ever. Now the dyer does not heat.
I checked the thermal fuse, high limit thermostat, and heating element with a multimeter on the 20 ohm setting and got the following results:
thermal fuse and high limit thermostat: 0.3
heating element: 40
I'm no electrical engineer, but I think this means that all three parts are OK. So, assuming that I did check the three parts correctly and they are all OK, what else could be wrong?
Thanks for any help in advance.
Related Models
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
General Electric DLL2880ABC Electric dryer
General Electric DLL2880BAC Electric dryer
  #2 (permalink)
Old 08-15-2013, 04:38 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
With fire damage it could be anything check the tech sheet if you have one and LG's aren't the greatest of appliance makers i personally would never own one. Thermal fuse should read infinite........the heating element should be 10-50 ohms. Do you have 240v going to the heating element? You have 3 or more thermostats to check and a thermister also.......Follow the wiring from your element and check everything that is in that circuitry.......
Here's some help
https://www.youtube.com/watch?v=Sy_ZK5f-WS8
  #3 (permalink)
Old 08-15-2013, 04:45 PM
Junior Member
Default
Thanks for the reply.
For what it's worth, there are no obvious signs of fire damage which leads me to believe something tripped. I'll try and follow the wiring back further and see what I can find.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help Dryer Fire smj2112 Dryer Repair 1 05-27-2011 04:52 AM
Heat & Glow Gas-Fire Place w/o Fire ●●●●●● Heating, Ventilation, and Air Conditioning (HVAC) 0 11-07-2010 11:06 AM
Gas Dryer doesn't Fire LesterS Dryer Repair 0 10-28-2010 01:48 PM
Dryer FIRE!!!!! That guy from Florida Dryer Repair 1 03-11-2010 04:15 PM
dryer does not fire Captain Carquest Dryer Repair 1 08-20-2007 09:55 AM
