Discuss
Admiral dryer won't run
 in
Dryer Repair
my admiral dryer wont run. the timer/start knob does not stay in to start the dryer. i replaced the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Admiral dryer won't run
  #1 (permalink)
Old 10-09-2009, 08:43 AM
mikey18610 mikey18610 is offline
Junior Member
mikey18610 is on a distinguished road
Default Admiral dryer won't run
Model Number: ade7000ayw   Brand: Admiral   Age: 5 - 10 years
my admiral dryer wont run. the timer/start knob does not stay in to start the dryer. i replaced the timer assembly and the resistor and still nothing. the knob still does not stay in and i laso have no light inside the drum when the door is open. anyone have a suggestion. i can't afford to replace things parts by part till i get it right.
Related Models
Admiral ADE7000AYW Dryer - Ele
Admiral ADE7005AKW Dryer - Ele
Admiral ADE7005AYW Dryer - Ele
Maytag ADE808 Dryer - Ele
Admiral ADE9000AYW Dryer - Ele
Admiral ADE9005AGW Dryer - Ele
Whirlpool ADF07520
Whirlpool ADF07521
Whirlpool ADF07522
Whirlpool ADF10020
Whirlpool ADF10220
Whirlpool ADF11021
Whirlpool ADF12020
Whirlpool ADF12540
Whirlpool ADF13520
Whirlpool ADF13521
Whirlpool ADF13522
Whirlpool ADF13523
Whirlpool ADF17040
Whirlpool ADF18040
Whirlpool ADF18041
Whirlpool ADF18043
Whirlpool ADF18044
Whirlpool ADF18240
Whirlpool ADF21240
Whirlpool ADF21340
Whirlpool ADF21342
Whirlpool ADF21343
Whirlpool ADF29040
Whirlpool ADF29041
Whirlpool ADF29042
Whirlpool ADF29043
Whirlpool ADFC6320
Whirlpool ADFC6321
Whirlpool ADFC6322
Whirlpool ADFE1240
Whirlpool ADFE1241
Whirlpool ADFE1242
Whirlpool ADFE1540
Whirlpool ADFE1541
Whirlpool ADFE1542
Whirlpool ADFE1830
Whirlpool ADFE1831
Whirlpool ADFH0720
Whirlpool ADFH0721
Whirlpool ADFH2130
Whirlpool ADFP5020
Whirlpool ADFP5021
Whirlpool ADFP5022
Whirlpool ADFP5023
Whirlpool ADFP5520
Whirlpool ADFP6021
Whirlpool ADFP6022
Whirlpool ADFP8020
Whirlpool ADFP8021
Whirlpool ADFR1240
Whirlpool ADFS1020
Whirlpool ADFS1021
Whirlpool ADFS6020
Whirlpool ADFS6021
Whirlpool ADFS8020
Whirlpool ADFS8021
Whirlpool ADFS8022
Whirlpool ADFW0940
Whirlpool ADFW0941
Whirlpool ADFW0942
Whirlpool ADFW1240
Whirlpool ADFW1241
Whirlpool ADFW1242
Whirlpool ADFW1540
Whirlpool ADFW1541
Whirlpool ADFW1542
Whirlpool ADFW1543
Whirlpool ADFW1544
Maytag ADG107 Dryer - Gas
Admiral ADG20K2A Dryer - Gas
Admiral ADG20K2H Dryer - Gas
Admiral ADG20K2W Dryer - Gas
Admiral ADG20K3 Dryer - Gas
Admiral ADG20K3A Dryer - Gas
Admiral ADG20K3H Dryer - Gas
Admiral ADG20K3V Dryer - Gas
Admiral ADG20K3W Dryer - Gas
Admiral ADG20K4 Dryer - Gas
Admiral ADG20K4A Dryer - Gas
Admiral ADG20K4H Dryer - Gas
Admiral ADG20K4W Dryer - Gas
Admiral ADG20L1A Dryer - Gas
Admiral ADG20L1H Dryer - Gas
Admiral ADG20L1W Dryer - Gas
Admiral ADG20L2A Dryer - Gas
Admiral ADG20L2H Dryer - Gas
Admiral ADG20L2W Dryer - Gas
Admiral ADG20L4 Dryer - Gas
Admiral ADG20L4A Dryer - Gas
Admiral ADG20L4H Dryer - Gas
Admiral ADG20L4W Dryer - Gas
Admiral ADG20M3V Dryer - Gas
Admiral ADG20N3V Dryer - Gas
Maytag ADG308 Dryer - Gas
Maytag ADG309 Dryer - Gas
Maytag ADG408 Dryer - Gas
Maytag ADG409 Dryer - Gas
Maytag ADG608 Dryer - Gas
Admiral ADG7000AWW Dryer - Gas
Admiral ADG7005AWW Dryer - Gas
Maytag ADG808 Dryer - Gas
Admiral ADG9000AWW Dryer - Gas
Amana ADGS902E Range - S/c S/i Ddraft Gas
Amana ADGS902SS Range - S/c S/i Ddraft Gas
Amana ADGS902WW Range - S/c S/i Ddraft Gas
General Electric ADH15D3Z1 Room air conditioner
General Electric ADH18D1G1 Room air conditioner
General Electric ADH18D1G2 Room air conditioner
General Electric ADH18D1G3 Room air conditioner
General Electric ADH18D3E1 Room air conditioner
General Electric ADH23D1X1 Room air conditioner
General Electric ADH23D3B1 Room air conditioner
Whirlpool ADJ06020
Whirlpool ADJ07220
  #2 (permalink)
Old 10-09-2009, 10:26 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here are your parts includes the wiring diagram.
Wiring information (series 15 elec) replacement parts for ADMIRAL ADE7000AYW | AppliancePartsPros.com
Does it start and then stop when you release the knob?
I do not believe the knob should stay in, once the dryer starts it gets power to keep running through the centrifugal/motor switch 2B to 7 and timer contact M/L.
If timer contacts M/L were shot in the timer this could have been the problem. The resistor has nothing to do with starting .
This could be the clue to the problem. You will see that the thermal fuse is before the door switch which provides power to the inside light so the first thing I would check is the thermal fuse, Item 5 in the "Heater" section.
Remove one wire from it and check it with a meter, should be 0 ohms.
There is a jiggery pokery method for checking it.
Unplug the unit
Remove the wires from the fuse
Short them together
Tape them up so they do not short to the frame/case
Plug it in and give it a try.
If it is blown replace it ASAP as it is a critical safety device.
If it is blown then give the interior a good cleaning including the blower wheel. Also clean/check your vent system. Also make sure the lint filter is clean and not clogged up with softener residue.
If the fuse is OK then next would be to check the door switch.
__________________
  #3 (permalink)
Old 10-10-2009, 12:10 PM
Junior Member
Thumbs up thanks Denman
re:admiral ade7000afw that wouldn't start
followed your instructions and found it was the thermal fuse. its out of stock but on order. jumped the wires to confirm it but won't use the dryer until the new fuse is in. looks a little tight to get the old one out but i should be able to figure it out. thanks for the help.
mikey
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral Gas Dryer seoulgrl Dryer Repair 1 11-23-2008 06:00 PM
Admiral Gas Dryer seoulgrl Dryer Repair 2 11-06-2008 09:51 PM
admiral dryer tomtom45 Dryer Repair 0 03-13-2008 08:07 PM
admiral dryer kojo Dryer Repair 2 03-13-2008 01:26 PM
Admiral Dryer no power to light or dryer Do-right Dryer Repair 1 01-14-2008 02:15 PM
