Discuss
Whirlpool Dryer Runs Intermittently
 in
Dryer Repair
Recently, my whirlpool dryer has started to run intermittently. When pushing the start button, it usually tries to start (you
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Runs Intermittently
  #1 (permalink)
Old 08-14-2013, 11:35 AM
Junior Member
jd101 is on a distinguished road
Default Whirlpool Dryer Runs Intermittently
Model Number: WED9400SB02   Brand: Whirlpool   Age: 5 - 10 years
Recently, my whirlpool dryer has started to run intermittently. When pushing the start button, it usually tries to start (you hear a relay click on) followed by the motor kicking on but then it shuts down almost immediately. It sounds like the motor just stutters. If I keep cancelling and restarting, eventually the motor stays on and the dryer runs but then it stops at random intervals. Sometimes after a few seconds and other times after a few minutes.
Any idea what might be the cause of this?
I've performed a little troubleshooting using the tech sheet. Running the onboard diagnostics, the system reports a control board malfunction, but I don't necessarily buy that. Taking the measurements described in the tech sheet, the control board checks out. The door switch checks out too as does the belt switch.
However, I can't quite figure out if there's a problem with the motor circuit. Measuring between the light blue wire and the bare copper wire of the main winding, I get an open circuit (> 200KOhms). Same with the start winding. However, when I measure between the light blue wire and the main winding terminal (what the bare copper wires connect to), then I get a short. Same with the start winding.
The tech sheet says that if there's resistance between 3.3-3.6 ohms, there's a problem with the main control board, and if the resistance is much greater, there's a problem with the motor. What doesn't make sense to me is why I get an open circuit measuring on the bare wire but an short measuring on the terminal that the bare wire connects to. How can that be?
The wire doesn't appear broken and is touching the terminal so current should flow via path of least resistance. I should either get an open or a short in both places, not both.
Any ideas?
Related Models
Whirlpool WED9400SB1 ELECTRIC DRYER
Whirlpool WED9400ST0 ELECTRIC DRYER
Whirlpool WED9400ST1 ELECTRIC DRYER
Whirlpool WED9400SU0 ELECTRIC DRYER
Whirlpool WED9400SU1 ELECTRIC DRYER
Whirlpool WED9400SU2 ELECTRIC DRYER
Whirlpool WED9400SW0 ELECTRIC DRYER
Whirlpool WED9400SW1 ELECTRIC DRYER
Whirlpool WED9400SW2 ELECTRIC DRYER
Whirlpool WED9400SZ0 ELECTRIC DRYER
Whirlpool WED9400SZ1 ELECTRIC DRYER
Whirlpool WED9400SZ2 ELECTRIC DRYER
Whirlpool WED9400VE0 ELECTRIC DRYER
Whirlpool WED9400VE1 ELECTRIC DRYER
Whirlpool WED9450WL0 ELECTRIC DRYER
Whirlpool WED9450WL1 ELECTRIC DRYER
Whirlpool WED9450WR0 ELECTRIC DRYER
Whirlpool WED9450WR1 ELECTRIC DRYER
Whirlpool WED9450WW0 ELECTRIC DRYER
Whirlpool WED9450WW1 ELECTRIC DRYER
Whirlpool WED9470WL1 ELECTRIC DRYER
Whirlpool WED9470WR1 ELECTRIC DRYER
Whirlpool WED9470WW1 ELECTRIC DRYER
Whirlpool WED94HEXL0 DRYER
Whirlpool WED94HEXL1 27" ELECTRIC DRYER
Whirlpool WED94HEXR0 DRYER
Whirlpool WED94HEXR1 27" ELECTRIC DRYER
Whirlpool WED94HEXW0 DRYER
Whirlpool WED94HEXW1 27" ELECTRIC DRYER
Whirlpool WED9500TC0 ELECTRIC DRYER
Whirlpool WED9500TC1 ELECTRIC DRYER
Whirlpool WED9500TC2 ELECTRIC DRYER
Whirlpool WED9500TU0 ELECTRIC DRYER
Whirlpool WED9500TU1 ELECTRIC DRYER
Whirlpool WED9500TW0 ELECTRIC DRYER
Whirlpool WED9500TW1 ELECTRIC DRYER
Whirlpool WED9500TW2 ELECTRIC DRYER
Whirlpool WED9500TW3 ELECTRIC DRYER
Whirlpool WED9550WL0 ELECTRIC DRYER
Whirlpool WED9550WL1 ELECTRIC DRYER
Whirlpool WED9550WR0 ELECTRIC DRYER
Whirlpool WED9550WR1 ELECTRIC DRYER
Whirlpool WED9550WW0 ELECTRIC DRYER
Whirlpool WED9550WW1 ELECTRIC DRYER
Whirlpool WED95HEXL0 DRYER
Whirlpool WED95HEXL1 27" ELECTRIC DRYER
Whirlpool WED95HEXR0 DRYER
Whirlpool WED95HEXR1 27" ELECTRIC DRYER
Whirlpool WED95HEXW0 DRYER
Whirlpool WED95HEXW1 27" ELECTRIC DRYER
Whirlpool WED9600SU0 ELECTRIC DRYER
Whirlpool WED9600TA0 27" ELECTRIC DRYER
Whirlpool WED9600TA1 27" ELECTRIC DRYER
Whirlpool WED9600TA2 27" ELECTRIC DRYER
Whirlpool WED9600TB0 27" ELECTRIC DRYER
Whirlpool WED9600TB1 27" ELECTRIC DRYER
Whirlpool WED9600TU0 27" ELECTRIC DRYER
Whirlpool WED9600TU1 27" ELECTRIC DRYER
Whirlpool WED9600TW0 27" ELECTRIC DRYER
Whirlpool WED9600TW1 27" ELECTRIC DRYER
Whirlpool WED9600TW2 27" ELECTRIC DRYER
Whirlpool WED9600TZ0 27" ELECTRIC DRYER
Whirlpool WED9610XW0 27" ELECTRIC DRYER
Whirlpool WED9750WL0 27" ELECTRIC DRYER
Whirlpool WED9750WR0 27" ELECTRIC DRYER
Whirlpool WED9750WW0 27" ELECTRIC DRYER
Whirlpool WED97HEXL0 ELECTRIC DRYER
Whirlpool WED97HEXL1 27" ELECTRIC DRYER
Whirlpool WED97HEXL2 27" ELECTRIC DRYER
Whirlpool WED97HEXR0 ELECTRIC DRYER
Whirlpool WED97HEXR1 27" ELECTRIC DRYER
Whirlpool WED97HEXR2 27" ELECTRIC DRYER
Whirlpool WED97HEXW0 ELECTRIC DRYER
Whirlpool WED97HEXW1 27" ELECTRIC DRYER
Whirlpool WED97HEXW2 27" ELECTRIC DRYER
White Westinghouse WEF303PHDA White Westinghouse/electric Range
White Westinghouse WEF303PHDB White Westinghouse/electric Range
White Westinghouse WEF303PHWA White Westinghouse/electric Range
White Westinghouse WEF303PHWB White Westinghouse/electric Range
White Westinghouse WEF311SHDA White Westinghouse/electric Range
White Westinghouse WEF311SHWA White Westinghouse/electric Range
Frigidaire WEF322BADA Wwh(v1) / Electric Range
Frigidaire WEF322BADB Wwh(v1) / Electric Range
Frigidaire WEF322BADC Wwh(v2) / Electric Range
Frigidaire WEF322BADD Wwh(v1) / Electric Range
Frigidaire WEF322BAWA Wwh(v2) / Electric Range
Frigidaire WEF322BAWB Wwh(v3) / Electric Range
Frigidaire WEF322BAWC Wwh(v4) / Electric Range
Frigidaire WEF322BAWD Wwh(v2) / Electric Range
Frigidaire WEF322BEDA Wwh(v1) / Electric Range
Frigidaire WEF322BEDB Wwh(v1) / Electric Range
Frigidaire WEF322BEWA Wwh(v2) / Electric Range
Frigidaire WEF322BEWB Wwh(v2) / Electric Range
Frigidaire WEF322BEWC Frg(v0) / Electric Range
Frigidaire WEF322SADA Wwh(v1) / Electric Range
Frigidaire WEF322SADB Wwh(v1) / Electric Range
Frigidaire WEF322SADC Wwh(v5) / Electric Range
Frigidaire WEF322SADD Wwh(v3) / Electric Range
Frigidaire WEF322SAWA Wwh(v2) / Electric Range
Frigidaire WEF322SAWB Wwh(v2) / Electric Range
Frigidaire WEF322SAWC Wwh(v6) / Electric Range
Frigidaire WEF322SAWD Wwh(v4) / Electric Range
White Westinghouse WEF326GSA ELECTRIC RANGE
White Westinghouse WEF326GSB ELECTRIC RANGE
Frigidaire WEF350BADB Wwh(v1) / Electric Range
Frigidaire WEF350BADC Wwh(v1) / Electric Range
Frigidaire WEF350BAWB Wwh(v2) / Electric Range
Frigidaire WEF350BAWC Wwh(v2) / Electric Range
Frigidaire WEF350CASA Wwh(v0) / Electric Range
White Westinghouse WEF350ESA White Westinghouse/range
White Westinghouse WEF350ESB White Westinghouse/range
Frigidaire WEF350SADA Wwh(v1) / Electric Range
Frigidaire WEF350SADB Wwh(v1) / Electric Range
Frigidaire WEF350SADC Wwh(v3) / Electric Range
Frigidaire WEF350SAWA Wwh(v2) / Electric Range
Frigidaire WEF350SAWB Wwh(v2) / Electric Range
Frigidaire WEF350SAWC Wwh(v4) / Electric Range
White Westinghouse WEF351ESA White Westinghouse/range
White Westinghouse WEF351ESB White Westinghouse/range
White Westinghouse WEF351ESC WHITE-WESTINGHOUSE/RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore fridge/freezer runs intermittently wbranch7 Refrigerator & Freezer Repair 1 03-03-2013 06:04 PM
Whirlpool Gas Dryer Runs But No Heat cybolt Dryer Repair 5 03-26-2011 07:43 AM
whirlpool dryer runs about 3-5 min. and shuts off drifter22 Dryer Repair 0 03-06-2011 03:39 PM
Whirlpool Dryer Runs, Ignites sometimes dcboucher Dryer Repair 1 06-06-2009 06:34 PM
Maytag washer runs intermittently radac Dishwasher Repair 0 07-31-2008 01:30 PM
