E64 code: I tested continuity and Heating element/coil was bad, thermostats and thermal fuse were good. I replaced it. Now when I hit start on any cycle it clicks as if to start and says drying. About two seconds later it clicks again it goes to paused mode and blinks multiple times but no error code appears. The only wires that may not have been connected correctly may be the three thermostat wires. Would that play a role? Is there a reset I must do? Help Please.:confused:
