Squeling noise when dryer is on
Dryer Repair
Hi, I have been experiencing this Squeling noise like if the belt is slipping. I did put a little bit
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Squeling noise when dryer is on
  #1 (permalink)
Old 08-07-2013, 10:34 PM
Junior Member
ace4cruisin is on a distinguished road
Default Squeling noise when dryer is on
Model Number: 41794802301   Brand: Kenmore   Age: 5 - 10 years
Hi, I have been experiencing this Squeling noise like if the belt is slipping. I did put a little bit of pressure on the idler spring and it helps a bit but it still sqeeks. I am not sure if its the Belt that is stretch out and causing this or if its the bearing at the back of the Tub. Any ideas as to what I can do to narrow down where the noise is coming from? Also, it does it intermitenly, not always, even with a light load.
I am an electrician so I am very Careful when I put pressure on the idler not to touch any electrical wires.
Thanks in advance,
Related Models
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794862302 LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794872302 LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797042700 DRYER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797812700 LAUNDRY CENTER
Kenmore 41797812701 LAUNDRY CENTER
Kenmore 41797812702 LAUNDRY CENTER
Kenmore 41797812704 LAUNDRY CENTER
Kenmore 41797822700 LAUNDRY CENTER
Kenmore 41797822701 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41797912700 LAUNDRY CENTER
Kenmore 41797912701 LAUNDRY CENTER
Kenmore 41797912702 LAUNDRY CENTER
Kenmore 41797912704 LAUNDRY CENTER
Kenmore 41797922700 LAUNDRY CENTER
Kenmore 41797922701 LAUNDRY CENTER
Kenmore 41797962700 LAUNDRY CENTER
Kenmore 41797962701 LAUNDRY CENTER
Kenmore 41797962702 LAUNDRY CENTER
Kenmore 41797962703 LAUNDRY CENTER
Kenmore 41797962705 LAUNDRY CENTER
Kenmore 41797972700 LAUNDRY CENTER
Kenmore 41797972701 LAUNDRY CENTER
Kenmore 41797972702 LAUNDRY CENTER
Kenmore 41798042700 DRYER
Kenmore 41798042701 DRYER
Kenmore 41798052700 GAS DRYER
Kenmore 41798052701 GAS DRYER
Kenmore 41798056700 DRYER
Kenmore 41798056701 DRYER
Kenmore 41798076700 DRYER
Kenmore 41798076701 DRYER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
  #2 (permalink)
Old 08-08-2013, 05:00 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Odds are that it is the rear drum bearing.
Remove the cover at the back of the unit so you can get to the back of the bearing.
Watch out for the ball bearing as they like to take off when released and then play hide and seek,
Then a couple drops of oil to the bearing to se if it is the culprit.
This is just a diagnostic.
If it does help then dismantle the unit and check the bearing parts.
If OK you may only have to re-grease the bearing.
Be sure to use high temperature grease.
You can do the same with a drop or two on the idler wheel shaft.
Check the front drum support glides for wear.
I doubt that the drive belt has stretched.
If you have to take the unit apart this is a good time to check the belt for cracks. Also any other parts that are part of the drum rotation ( drum seals etc.)
Give the interior a good cleaning including the blower wheel.
Since you are working on the unit it is a good time to check/clean your vent system.
Note that the dears parts site has actual part breakdown diagrams that youm may find useful.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Squeling Dryer ttlyons Dryer Repair 0 08-31-2012 04:03 PM
maytag washer loud squeling noise myed Washer Repair 1 08-17-2011 01:45 PM
Dryer Noise sassybutter Dryer Repair 1 08-19-2009 12:16 PM
dryer start button noise - dryer won't run brhodes58 Dryer Repair 6 03-14-2009 02:11 PM
squeling exaust fan t.ash1 Oven Repair (including Ranges and Cooktops) 0 10-04-2007 05:58 PM
