Kenmore 80 Series Not Getting Hot
Dryer Repair
Hello my dryer is not heating. Can someone please give me the protocol for diagnosing this. It tumbles but does
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 80 Series Not Getting Hot
  #1 (permalink)
Old 08-07-2013, 09:48 AM
Junior Member
MeEric is on a distinguished road
Default Kenmore 80 Series Not Getting Hot
Model Number: 80 Series   Brand: -brand-   Age: 1 - 5 years
Hello my dryer is not heating. Can someone please give me the protocol for diagnosing this. It tumbles but does not heat. I tried flipping the breaker. Model # is 110.60852990
Related Models
Amana 80/05.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/05.501 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/08.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/08.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/08.500 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/08.501 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/30.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/30.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/30.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/30.003 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/31.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/31.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/31.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/40.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/40.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/40.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/41.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/41.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/41.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.003 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.005 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/42.006 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/50.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/50.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/51.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/51.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/51.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/51.003 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/51.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.003 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.005 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/52.006 MWAVE - FAMILY SIZE (60 HZ)
Amana 80/80.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 800 MWAVE - FAMILY SIZE (60 HZ)
Jenn-Air 800038 MISC / ACCESSORY
Jenn-Air 800090 MISC / ACCESSORY
Jenn-Air 800163 MISC / ACCESSORY
Jenn-Air 800181 WALLOVEN- STD ELE
Jenn-Air 800181-C WALLOVEN- STD ELE
Jenn-Air 800185 MISC / ACCESSORY
Jenn-Air 800186 MISC / ACCESSORY
Jenn-Air 800263 WALLOVEN- STD ELE
Jenn-Air 800263-C WALLOVEN- STD ELE
Jenn-Air 800264 WALLOVEN- STD ELE
Jenn-Air 800264-C WALLOVEN- STD ELE
Frigidaire 8007-80C GAS DRYER
Frigidaire 8007-80D GAS DRYER
Frigidaire 8007-80E GAS DRYER
Frigidaire 8007-87C GAS DRYER
Frigidaire 8007-87D GAS DRYER
Frigidaire 8007-87E GAS DRYER
Frigidaire 8007B GAS DRYER
Amana 801.000 RANGE- S/C S/I DDRAFT GAS
Frigidaire 80118-OA FREEZER
Frigidaire 80118A FREEZER
Frigidaire 80119A CHEST FREEZER
Amana 8021.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 8021.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 8022.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 8022.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 8036.A04 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 80436-7A CHEST FREEZER
Frigidaire 80436-7B CHEST FREEZER
Frigidaire 80436-7C CHEST FREEZER
Frigidaire 80437A FREEZER
Frigidaire 80438-7A FREEZER
Frigidaire 80439-7A FREEZER
Frigidaire 80439A CHEST FREEZER
Frigidaire 80457A FREEZER
Frigidaire 80503 CHEST FREEZER
Frigidaire 80543 CHEST FREEZER
Frigidaire 80636-7C CHEST FREEZER
Frigidaire 80656-7A CHEST FREEZER
Frigidaire 80656-7B CHEST FREEZER
Frigidaire 80656-7C CHEST FREEZER
Frigidaire 80657-7A FREEZER
Frigidaire 80658-7A FREEZER
Frigidaire 80659A CHEST FREEZER
Amana 8072.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 8072.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 8072.005 MWAVE - FAMILY SIZE (60 HZ)
Amana 8074.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 8074.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 8074.014 MWAVE - FAMILY SIZE (60 HZ)
Amana 8074.A04 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 80846-7A CHEST FREEZER
Frigidaire 80846-7B CHEST FREEZER
Frigidaire 80846-7C CHEST FREEZER
Frigidaire 80847-7A FREEZER
Frigidaire 80849A CHEST FREEZER
Amana 8090.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 8090.004 MWAVE - FAMILY SIZE (60 HZ)
  #2 (permalink)
Old 08-09-2013, 04:27 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Parts for Kenmore Dryer 11060852990 - AppliancePartsPros.com
If you go to the Sears parts site they have part breakdown diagrams which may be useful to you. Unfortunately they do not share theses with other parts vendors.
I cannot find a wiring diagram for this unit.
If you do not have it take a look in the control console often they store one in this area.
First I would check the power as the motor etc works off of half the line (120 volts) but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
Be careful as 240 volts is lethal !!!
If the power is good unplug the unit and at least one wire at the heating coil and measure it with a meter. They are usually in the 8 to 12 ohms range.
Disconnecting one side while measuring ensures that you do not read an alternate/parallel circuit path.
If OK check the high limit cut-off/fuse on the heater assembly. It is the upper one. It should be 0 ohms.
If it is open (infinite ohms) get back to us as there are other things you should check before replacing it.
If OK, check the hi-limit thermostat. It should be 0 ohms. It is the lower one.
Any further tests will require a wiring diagram or you will have to trace the wires.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 series jparry27 Washer Repair 1 01-16-2012 06:00 PM
Kenmore 80 series help. joness3343 Washer Repair 1 08-24-2011 06:06 PM
Kenmore 80 series feliziris Dryer Repair 0 08-10-2011 05:25 AM
help with kenmore 90 series mrricky Washer Repair 1 09-10-2009 02:27 PM
Kenmore 70 series setnom Washer Repair 1 05-02-2009 03:47 PM
