Estate dryer not heating up
Dryer Repair
My Estate dryer is not heating up. Checked voltage nothing is reading on the thermostat on the blower or the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Estate dryer not heating up
  #1 (permalink)
Old 08-06-2013, 06:23 PM
Junior Member
Jackier is on a distinguished road
Default Estate dryer not heating up
Model Number: Tedx640pq1   Brand: Estate   Age: 1 - 5 years
My Estate dryer is not heating up. Checked voltage nothing is reading on the thermostat on the blower or the bottom one that is attached to the housing on the outside of the heating element. The thermal fuse is also not giving off a reading, but I already replaced that part. There is proper voltage going to the machine. I am getting a reading on the top thermostat that is attached to the heating element. Dryer runs fine just no heat. Any suggestions on my next course of action? Dryer worked fine since I have had it this problem has just happened.
Related Models
Frigidaire TEF240PHD1 Tap(v1) / Electric Range
Frigidaire TEF240PHW1 Tap(v2) / Electric Range
Tappan TEF240PHW2 Tappan/electric Range
Tappan TEF242BU1 Tappan/electric Range
Tappan TEF242BU2 Tappan/electric Range
Tappan TEF242BU3 Tappan/electric Range
Tappan TEF242BW1 Tappan/electric Range
Tappan TEF242BW2 Tappan/electric Range
Tappan TEF242BW3 Tappan/electric Range
Tappan TEF303AWA Tappan/range
Tappan TEF303AWB Tappan/electric Range
Tappan TEF303BWA Tappan/electric Range
Tappan TEF303BWB Tappan/electric Range
Tappan TEF303BWC Tappan/electric Range
Tappan TEF303BWD Tappan/electric Range
Tappan TEF303BWE Tappan/range
Tappan TEF317AUA Tappan/range
Tappan TEF317AUB Tappan/electric Range
Tappan TEF317AWA Tappan/range
Tappan TEF317AWB Tappan/electric Range
Tappan TEF317AWC Tappan/electric Range
Tappan TEF317BUA Tappan/electric Range
Tappan TEF317BUB Tappan/electric Range
Tappan TEF317BUC Tappan/electric Range
Tappan TEF317BUD Tappan/electric Range
Tappan TEF317BWA Tappan/electric Range
Tappan TEF317BWB Tappan/electric Range
Tappan TEF317BWC Tappan/electric Range
Tappan TEF317BWD Tappan/electric Range
Tappan TEF317BWE Tappan/electric Range
Frigidaire TEF322BHDA
Frigidaire TEF322BHWA
Frigidaire TEF322SCDA Tap(v1) / Electric Range
Frigidaire TEF322SCDB Tap(v1) / Electric Range
Frigidaire TEF322SCDC Tap(v1) / Electric Range
Frigidaire TEF322SCWA Tap(v2) / Electric Range
Frigidaire TEF322SCWB Tap(v2) / Electric Range
Frigidaire TEF322SCWC Tap(v2) / Electric Range
Frigidaire TEF322WHSA
Frigidaire TEF324BCDA Tap(v1) / Electric Range
Frigidaire TEF324BCDB Tap(v3) / Electric Range
Frigidaire TEF324BCDC Tap(v3) / Electric Range
Frigidaire TEF324BCWA Tap(v2) / Electric Range
Frigidaire TEF324BCWB Tap(v4) / Electric Range
Frigidaire TEF324BCWC Tap(v4) / Electric Range
Frigidaire TEF324CCSA Tap(v0) / Electric Range
Frigidaire TEF324CCSB Tap(v5) / Electric Range
Tappan TEF326FBA Tappan/range
Tappan TEF326FSA Tappan/range
Tappan TEF350DSA Tappan/range
Tappan TEF350DWA Tappan/electric Range
Frigidaire TEF350SCDA Tap(v1) / Electric Range
Frigidaire TEF350SCDB Tap(v1) / Electric Range
Frigidaire TEF350SCDC Tap(v1) / Electric Range
Frigidaire TEF350SCDD Tap(v1) / Electric Range
Frigidaire TEF350SCDE Tap(v1) / Electric Range
Frigidaire TEF350SCWA Tap(v2) / Electric Range
Frigidaire TEF350SCWB Tap(v2) / Electric Range
Frigidaire TEF350SCWC Tap(v2) / Electric Range
Frigidaire TEF350SCWD Tap(v2) / Electric Range
Frigidaire TEF350SCWE Tap(v2) / Electric Range
Tappan TEF351DSB Tappan/range
Tappan TEF351DUA Tappan/electric Range
Tappan TEF351DUB Tappan/range
Tappan TEF351DWA Tappan/electric Range
Tappan TEF351DWB Tappan/range
Tappan TEF351EWA Tappan/range
Tappan TEF351EWB Tappan/range
Tappan TEF351EWC Tappan/electric Range
Frigidaire TEF352BHDA Tap(v1) / Electric Range
Frigidaire TEF352BHWA Tap(v2) / Electric Range
Frigidaire TEF352CHSA Tap(v3) / Electric Range
Tappan TEF352CHTA Tappan/electric Range
Frigidaire TEF352SCDA Tap(v1) / Electric Range
Frigidaire TEF352SCDB Tap(v1) / Electric Range
Frigidaire TEF352SCDC Tap(v1) / Electric Range
Frigidaire TEF352SCDD Tap(v1) / Electric Range
Frigidaire TEF352SCWA Tap(v2) / Electric Range
Frigidaire TEF352SCWB Tap(v2) / Electric Range
Frigidaire TEF352SCWC Tap(v2) / Electric Range
Frigidaire TEF352SCWD Tap(v2) / Electric Range
Tappan TEF353AQA Tappan/range
Tappan TEF353AQB Tappan/electric Range
Tappan TEF353AQC Tappan/electric Range
Tappan TEF353AQD Tappan/electric Range
Tappan TEF353AQE Tappan/range
Tappan TEF353AQF Tappan/electric Range
Tappan TEF353ASA Tappan/range
Tappan TEF353ASB Tappan/electric Range
Tappan TEF353ASC Tappan/electric Range
Tappan TEF353ASD Tappan/electric Range
Tappan TEF353ASE Tappan/range
Tappan TEF353ASF Tappan/electric Range
Tappan TEF353AUA Tappan/range
Tappan TEF353AUB Tappan/electric Range
Tappan TEF353AUC Tappan/electric Range
Tappan TEF353AUD Tappan/electric Range
Tappan TEF353AUE Tappan/range
Tappan TEF353AUF Tappan/electric Range
  #2 (permalink)
Old 08-09-2013, 04:41 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Parts for Estate TEDX640PQ1 Dryer - AppliancePartsPros.com
I am assuming that by correct power, you have checked for 240 volts at the terminal strip in the unit.
Another test is to check that the timer advances in timed dry when the unit is running. It also uses 240 volts.
Note that the thermal fuse on the blower kills power to the motor.
Using voltage when trouble shooting heating problems can get confusing because Neutral/ground is not part of the heater circuit.
You are better off starting with resistance.
It is a good idea to disconnect one side of any device you are measuring as this ensures that you do not read an alternate/parallel circuit path.
Also in the heater circuit you should use your most sensitive meter scale.
The heaters are usually in the 8 to 12 ohm range.
The hi-limit, thermal cutoff and the operating thermostat should all be 0 ohms at room temperature.
The timer switch 2 should also be 0 ohms when the timer is in a hwating type cycle.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Estate Model Dryer not heating properly eaaron63 Dryer Repair 5 07-30-2013 04:06 AM
Estate(Whirlpool) Electric Dryer not heating JDB59 Dryer Repair 11 12-10-2012 12:07 PM
Whirlpool Estate Dryer Stopped Heating kimyoung Dryer Repair 1 05-17-2011 04:45 AM
maytag estate dryer not heating detherth Dryer Repair 4 05-10-2011 06:27 PM
Estate Dryer not heating tohman Dryer Repair 1 09-30-2009 05:52 PM
