Discuss
Kenmore - timer won't advance even with replacement
 in
Dryer Repair
We recently purchased a new home which came with this Kenmore electric dryer. However, the timer does not advance in
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore - timer won't advance even with replacement
  #1 (permalink)
Old 08-06-2013, 12:10 PM
Junior Member
vickischow is on a distinguished road
Default Kenmore - timer won't advance even with replacement
Model Number: 11069532800   Brand: Kenmore   Age: 1 - 5 years
We recently purchased a new home which came with this Kenmore electric dryer. However, the timer does not advance in the auto dry or timed dry settings. I had a repairman come and he was $60 to tell me the timer needed to be replaced, which would be another $200 in parts and labor. Instead of having him return, I bought the part myself and replaced the timer. However, the new timer does not advance either. The dryer continuously runs until we open the dryer door.
Any other suggestions about what could be going on here? Should I call it a loss and just install a gas dryer instead?
Other things to note:
Even the the timer doesn't advance, the clothes dry fine. However, I am skeptical about whether there is much of a heat difference between the high and low heat settings (even on "low" the clothes feel very hot).
About 4 times in the last month the dryer HAS advanced when in the timed dry setting, but it happens completely randomly.
For some unknown reason the previous homeowner wired the dryer directly into the breaker box. So there is no plug to unplug... just a breaker to flip.
Thanks.
Related Models
Kenmore 11069532800 RESIDENTIAL DRYER
Kenmore 1106957700 KENMORE GAS DRYER
Kenmore 1106957701 KENMORE GAS DRYER
Kenmore 1106957702 KENMORE GAS DRYER
Kenmore 1106957703 KENMORE GAS DRYER
Kenmore 1106957704 KENMORE GAS DRYER
Kenmore 1106957705 KENMORE GAS DRYER
Kenmore 1106957706 KENMORE GAS DRYER-NOVEMBER, 1971
Kenmore 1106957710 KENMORE GAS DRYER
Kenmore 1106957711 KENMORE GAS DRYER
Kenmore 1106958700 KENMORE ELECTRIC DRYER
Kenmore 1106958701 KENMORE ELECTRIC DRYER
Kenmore 1106958702 KENMORE ELECTRIC DRYER
Kenmore 1106958703 KENMORE ELECTRIC DRYER
Kenmore 1106958710 KENMORE ELECTRIC DRYER
Kenmore 1106958711 KENMORE ELECTRIC DRYER
Kenmore 11069622800 RESIDENTIAL DRYER
Kenmore 11069632800 RESIDENTIAL DRYER
Kenmore 11069652800 RESIDENTIAL DRYER
Kenmore 11069722800 RESIDENTIAL DRYER
Kenmore 11069727800 RESIDENTIAL DRYER
Kenmore 11069732800 RESIDENTIAL DRYER
Kenmore 11069737800 RESIDENTIAL DRYER
Kenmore 11069812990 ELECTRIC DRYER
Kenmore 11069822800 RESIDENTIAL DRYER
Kenmore 11069822801 RESIDENTIAL DRYER
Kenmore 11069832800 DRYER
Kenmore 11069832801 RESIDENTIAL DRYER
Kenmore 11069902890 ELECTRIC DRYER
Kenmore 11069912990 ELECTRIC DRYER
Kenmore 11070012000 COMMERCIAL GAS DRYER
Kenmore 11070012001 COMMERCIAL GAS DRYER
Kenmore 11070012002 COMMERCIAL DRYER
Kenmore 11070022010 GAS DRYER
Kenmore 1107003400 KENMORE AUTOMATIC WASHER
Kenmore 1107003402 KENMORE AUTOMATIC WASHER
Kenmore 1107003403 KENMORE AUTOMATIC WASHER
Kenmore 1107003410 KENMORE AUTOMATIC WASHER
Kenmore 1107003500 KENMORE AUTOMATIC WASHER
Kenmore 1107003501 KENMORE AUTOMATIC WASHER
Kenmore 1107003502 KENMORE AUTOMATIC WASHER
Kenmore 1107003503 KENMORE AUTOMATIC WASHER
Kenmore 1107003504 KENMORE WASHER
Kenmore 1107003510 KENMORE AUTOMATIC WASHER
Kenmore 1107004400 KENMORE AUTOMATIC WASHER
Kenmore 1107004401 KENMORE AUTOMATIC WASHER
Kenmore 1107004402 KENMORE AUTOMATIC WASHER
Kenmore 1107004403 KENMORE AUTOMATIC WASHER
Kenmore 1107004405 KENMORE AUTOMATIC WASHER
Kenmore 1107004406 KENMORE AUTOMATIC WASHERS
Kenmore 1107004407 KENMORE AUTOMATIC WASHER
Kenmore 1107004408 KENMORE AUTOMATIC WASHER
Kenmore 1107004409 KENMORE AUTOMATIC WASHER
Kenmore 1107004500 KENMORE AUTOMATIC WASHER
Kenmore 1107004501 KENMORE AUTOMATIC WASHER
Kenmore 1107004502 KENMORE AUTOMATIC WASHERS
Kenmore 1107004503 KENMORE AUTOMATIC WASHER
Kenmore 1107004504 KENMORE AUTOMATIC WASHER
Kenmore 1107004505 KENMORE AUTOMATIC WASHER
Kenmore 1107004510 KENMORE AUTOMATIC WASHER
Kenmore 1107004511 KENMORE AUTOMATIC WASHER
Kenmore 1107004512 KENMORE AUTOMATIC WASHER
Kenmore 1107004513 KENMORE AUTOMATIC WASHER
Kenmore 1107004514 KENMORE AUTOMATIC WASHERS
Kenmore 1107004550 KENMORE AUTOMATIC WASHER
Kenmore 1107004551 KENMORE AUTOMATIC WASHER
Kenmore 1107004552 KENMORE AUTOMATIC WASHERS
Kenmore 1107004553 KENMORE AUTOMATIC WASHER
Kenmore 1107004554 KENMORE AUTOMATIC WASHER
Kenmore 1107004600 KENMORE AUTOMATIC WASHER
Kenmore 1107004601 KENMORE AUTOMATIC WASHER
Kenmore 1107004610 KENMORE AUTOMATIC WASHER
Kenmore 1107004611 KENMORE AUTOMATIC WASHERS
Kenmore 1107004613 KENMORE AUTOMATIC WASHER
Kenmore 1107004615 KENMORE AUTOMATIC WASHER
Kenmore 1107004616 KENMORE AUTOMATIC WASHER
Kenmore 1107004617 KENMORE AUTOMATIC WASHER
Kenmore 1107004618 KENMORE AUTOMATIC WASHER
Kenmore 1107004619 KENMORE AUTOMATIC WASHER
Kenmore 1107004650 KENMORE AUTOMATIC WASHER
Kenmore 1107004651 KENMORE AUTOMATIC WASHER
Kenmore 1107004660 KENMORE AUTOMATIC WASHER
Kenmore 1107004661 KENMORE AUTOMATIC WASHERS
Kenmore 1107004663 KENMORE AUTOMATIC WASHER
Kenmore 1107004665 KENMORE AUTOMATIC WASHER
Kenmore 1107004666 KENMORE AUTOMATIC WASHER
Kenmore 1107004667 KENMORE AUTOMATIC WASHER
Kenmore 1107004668 KENMORE AUTOMATIC WASHER
Kenmore 1107004669 KENMORE AUTOMATIC WASHER
Kenmore 1107004700 KENMORE AUTOMATIC WASHER
Kenmore 1107004701 KENMORE AUTOMATIC WASHER
Kenmore 1107004702 KENMORE AUTOMATIC WASHER
Kenmore 1107004703 KENMORE AUTOMATIC WASHER
Kenmore 1107004704 KENMORE AUTOMATIC WASHER
Kenmore 1107004750 KENMORE AUTOMATIC WASHER
Kenmore 1107004751 KENMORE AUTOMATIC WASHER
Kenmore 1107004752 KENMORE AUTOMATIC WASHER
Kenmore 1107004753 KENMORE AUTOMATIC WASHER
Kenmore 1107004754 KENMORE AUTOMATIC WASHER
Kenmore 1107004800 KENMORE AUTOMATIC WASHER
Kenmore 1107004801 KENMORE AUTOMATIC WASHER
Kenmore 1107004802 KENMORE AUTOMATIC WASHER
Kenmore 1107004803 KENMORE AUTOMATIC WASHER
Kenmore 1107004850 KENMORE AUTOMATIC WASHER
Kenmore 1107004851 KENMORE AUTOMATIC WASHER
Kenmore 1107004852 KENMORE AUTOMATIC WASHER
Kenmore 1107004853 KENMORE AUTOMATIC WASHER
Kenmore 1107004900 KENMORE AUTOMATIC WASHER
Kenmore 1107004901 KENMORE AUTOMATIC WASHER
Kenmore 1107004902 KENMORE AUTOMATIC WASHER
Kenmore 1107004903 KENMORE AUTOMATIC WASHER
Kenmore 1107004950 KENMORE AUTOMATIC WASHER
Kenmore 1107004951 KENMORE AUTOMATIC WASHER
Kenmore 1107004952 KENMORE AUTOMATIC WASHER
Kenmore 1107004953 KENMORE AUTOMATIC WASHER
Kenmore 11070052990 GAS DRYER
Kenmore 11070052991 GAS DRYER
Kenmore 1107005400 KENMORE AUTOMATIC WASHER
Kenmore 1107005401 KENMORE AUTOMATIC WASHER
Kenmore 1107005402 KENMORE AUTOMATIC WASHER
  #2 (permalink)
Old 08-06-2013, 04:31 PM
Senior Member
scott5495 is on a distinguished road
Default timer
if you have a volt meter, check the two wires going to the motor for 120 volts. be sure to check it in the timed cycle not automatic. I have looked at the schematic and there is no reason for the timer not to advance in the timed cycle. if you have 120 volts on your timer motor wires then you have a new timer that is bad.
  #3 (permalink)
Old 08-07-2013, 02:10 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Kenmore Dryer 11069532800 - AppliancePartsPros.com
Could be you have a grounded element. This would explain why there seems to be only one heat setting and no timer advance.
Flip the breaker off.
Disconnect both wires from the heating element.
Measure the coil with a meter. Should be around 8 to 12 ohms.
Then measure from each element connector to Neutral or ground (the frame/heater case if it is a 3 wire hook up).
Both should be infinite ohms.
If not replace the heater.
Also check for 240 at the terminal strip in the unit.
If there is no 240 this would explain no timer advance sa the heater and timer motor use 240 (if I have the correct wiring diagram).
This does not explain why the timer advances once in a while so I think you have 240 but the heater un-grounds itself once in a while which is unusual.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Series 80 Kenmore washer timer won't advance frugalastheyget Washer Repair 1 07-27-2012 02:15 PM
Kenmore Washer Timer Replacement alanpbear Washer Repair 0 03-16-2011 11:57 AM
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 ambsdr4god Washer Repair 1 11-09-2009 07:21 AM
Kenmore timer won't advance automatically jennyparadox Washer Repair 3 11-07-2008 02:50 PM
Kenmore Timer won't advance or shut off zaq12wsx Dryer Repair 1 01-19-2008 06:36 PM
