Discuss
Dryer won't spin fast
 in
Dryer Repair
I have a maytag dryer that is having problems spinning fast... When lifting the top, you see it struggling to
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't spin fast
  #1 (permalink)
Old 08-02-2013, 10:30 PM
Junior Member
ezfreeze is on a distinguished road
Default Dryer won't spin fast
Model Number: MDE4658ayw   Brand: Maytag   Age: More than 10 years
I have a maytag dryer that is having problems spinning fast... When lifting the top, you see it struggling to spin...
I have a new belt and a new pulley arm from a repair I had to do 2 years ago...
Problem started when I was rotating the inside to find some socks and I heard the belt come off, I opened it up and put the belt back on and now it is having problems spinning..
Any thoughts?
Related Models
Maytag MDE4658AYW DRYER- ELE
Maytag MDE4806AYW DRYER- ELE
Maytag MDE4806AZW DRYER- ELE
Maytag MDE4916AYA DRYER- ELE
Maytag MDE4916AYW DRYER- ELE
Maytag MDE4916AZW DRYER- ELE
Maytag MDE5000AYQ DRYER- ELE
Maytag MDE5000AYW DRYER- ELE
Maytag MDE5000AZW DRYER- ELE
Maytag MDE508DAYK DRYER- ELE
Maytag MDE508DAYW DRYER- ELE
Frigidaire MDE546RED0 Frg(v1) / Electric Dryer
Frigidaire MDE546RED1 Frg(v1) / Electric Dryer
Frigidaire MDE546RES0 Frg(v2) / Electric Dryer
Frigidaire MDE546RES1 Frg(v2) / Electric Dryer
Frigidaire MDE546RET0 Frg(v3) / Electric Dryer
Frigidaire MDE546REW0 Frg(v4) / Electric Dryer
Frigidaire MDE546REW1 Frg(v3) / Electric Dryer
Maytag MDE5500AYQ DRYER- ELE
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
  #2 (permalink)
Old 08-03-2013, 08:13 AM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Did you put the belt back on the right way? most brands the grooved side is facing the drum but some of the maytags have the flat back side of the belt facing the drum........try flipping the belt and routing it correctly over the motor pully and tensioner pully and see what you get..........the groove side must go over the motor pully correctly with good tension.
  #3 (permalink)
Old 08-06-2013, 11:54 AM
Junior Member
Default
I believe I do have it groove side up, but it definitely won't hurt to flip it and see if that fixes my issue...
Thanks for the response and I will try and give this a go tonight...
  #4 (permalink)
Old 08-06-2013, 09:08 PM
Junior Member
Default
That did the trick... The grooved part was not wrapping around the motor pulley and once I flipped it, everything was running like new...
GOD Bless you... Thanks a bunch for your help...
  #5 (permalink)
Old 08-08-2013, 09:22 AM
Senior Member
Default
Hey thanks, God already has blessed me with learning this field and sharing it with others
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no fast spin lmeredith99 Washer Repair 2 05-29-2012 01:20 PM
drum will not spin fast enough in spin cycle CHARLESEMURPHY1 Washer Repair 1 10-09-2011 05:54 PM
Does not spin fast sharper1 Washer Repair 1 02-06-2011 08:25 AM
in spin makes noise and does'nt spin fast monterey Washer Repair 1 12-15-2010 04:53 PM
makes loud banging while in spin, does not spin fast shaggylong Washer Repair 2 01-30-2009 02:29 AM
