GKS
#1 Posted : Saturday, February 9, 2008 11:35:38 AM(UTC)
GKS
I have Voltage on both sides of the heating element while the dryer is running and the element tests 9.9 ohms when tested across the posts. but NO HEAT.
My wife says it sometimes heats.
The dryer runs and everything seems to be working properly except the Heat
Any Ideas?
GKS
#2 Posted : Tuesday, February 12, 2008 2:05:18 PM(UTC)
GKS
Wow...no help so far on this site.
I've got 124 volts on one side of the element ( one side to grnd) no voltage coming out of the heater relay. I'm guessing that means I've got a bad relay. The 124 volts coming through the motor is making it to the Heating element but not the voltage through the relay.
Anyone out there? (as he listens to the sounds of crickets)
abbie
#3 Posted : Wednesday, February 13, 2008 3:31:24 AM(UTC)
abbie
check the two fuses/breakers in your elecrtical panel.There should be 240 volts going to the heater.check the high limet thermostat on the heater box to see if it,s closed.If opened replace.
Kenmore 500 seris (Dryer Repair)
by Guest Today at 4:34:41 PM(UTC)
Kenmore Elite not always cooling (Refrigerator & Freezer Repair)
by rankell1111 Yesterday at 5:23:39 AM(UTC)
Kenmore Model 66513842K601 (Dishwasher Repair)
by CChristopher 4/22/2024 11:23:53 AM(UTC)
Canning on a kenmore elite c970 688925 (Oven Repair (including Ranges and Cooktops))
by Guest 4/17/2024 9:34:41 PM(UTC)
Kenmore Elite (796.2900) uE error and now making weird sounds on startup/rinse... (Washer Repair)
by PirateToast 4/17/2024 8:20:21 AM(UTC)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
Kenmore 110.47566601 makes loud spin noise (Washer Repair)
by Guest 4/6/2024 7:42:40 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Knocking/Thumping sound during agitation - Kenmore 110.22352511 (Washer Repair)
by bucotton 3/29/2024 12:45:08 PM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Kenmore/Whirlpool GB22DKXJW00 - evap fan replacement no ground (Refrigerator & Freezer Repair)
by DIY2024 3/24/2024 1:07:07 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
Kenmore Side by Side Water Inlet Lines (Refrigerator & Freezer Repair)
by Don49 3/15/2024 12:21:35 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
