Electric Kitchen aid dryer won't heat
To troubleshoot this you will need a test meter.
First check to see that you have 120v to each side of the connection block at the Dryer.
Then unplug it and check the thermal fuses and thermostats for continuity. Finally, check the heating element to see that it is not broken or is grounded by sagging or touching the frame.
Good luck
