Discuss
flame on only when undressed
 in
Dryer Repair
Gas dryer stopped igniting burner. Replaced igniter unit and flame sensor. With drum out for testing, start-up sequence is OK
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » flame on only when undressed
  #1 (permalink)
Old 07-30-2013, 01:34 PM
Junior Member
williamrcole is on a distinguished road
Default flame on only when undressed
Model Number: SGR641HS1   Brand: White-Westinghouse   Age: 1 - 5 years
Gas dryer stopped igniting burner. Replaced igniter unit and flame sensor. With drum out for testing, start-up sequence is OK all the way to flame ignition. After installing drum and closing up unit, start-up sequence goes all the way to point when flame should ignite, but does not. Igniter glows red hot for several seconds before going out. Igniter will try again after a while, but no flame-on. Take the unit apart, remove the drum and everything works great.
Related Models
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
Thermador SGSX365ZB
Thermador SGSX365ZS
Thermador SGSX365ZW
Thermador SGSX456ZB
Thermador SGSX456ZS
Thermador SGSX456ZW
Thermador SGT3001 COOKTOP
Thermador SGT3002 COOKTOP
Thermador SGT36 COOKTOP
Thermador SGT3601 COOKTOP
Thermador SGT36G01 COOKTOP
Thermador SGT36G02 COOKTOP
Frigidaire SGWS1349AS0 Frigidaire/washer
Bosch SGZ1000
Bosch SGZ1005
Bosch SGZ1024
Bosch SGZ1025
Bosch SGZ1040
Bosch SGZ1042
Bosch SGZ1046
Bosch SGZ2004
Thermador SH01BG
Frigidaire SH205C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH205C1QB Kel(v1) / Room Air Conditioner
Frigidaire SH206C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH206D1QA Kel(v1) / Room Air Conditioner
General Electric SH208W0WW Washer
Frigidaire SH310C1QA Kel(v0) / Room Air Conditioner
Frigidaire SH310D1QA Kel(v1) / Air Conditioner
Hardwick SH4-34A9 SURFACE UNIT- GAS
Hardwick SH4-34W9 SURFACE UNIT- GAS
Frigidaire SH418C2SA Kel(v0) / Room Air Conditioner
Frigidaire SH418D2SA Kel(v1) / Room Air Conditioner
Hardwick SH7241819R WALLOVEN- STD GAS
Whirlpool SHF3801W0 Dishwasher
Whirlpool SHF3804W2 Dishwasher
Whirlpool SHF4500W0 Dishwasher
Whirlpool SHF5500W0 Dishwasher
Whirlpool SHF5501W0 Dishwasher
Whirlpool SHF5504W0 Dishwasher
Whirlpool SHF5584P1 Dishwasher
Whirlpool SHF5584P2 Dishwasher
Whirlpool SHF5801W0 Dishwasher
Whirlpool SHF5801W1 Dishwasher
Whirlpool SHF5884P1 Dishwasher
Whirlpool SHF5884P2 Dishwasher
Whirlpool SHF7800W0 Dishwasher
Whirlpool SHF7801W0 Dishwasher
Whirlpool SHF7804W1 Dishwasher
Whirlpool SHF7884P0 Dishwasher
Whirlpool SHF7884P1 Dishwasher
Whirlpool SHF7884P2 Dishwasher
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30011 DISHWASHER
Bosch SHU3002
Whirlpool SHU30041 DISHWASHER
Bosch SHU3006
Bosch SHU3012
Whirlpool SHU30140 DISHWASHER
Whirlpool SHU30141 DISHWASHER
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
  #2 (permalink)
Old 07-30-2013, 05:58 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Check to see if you have ventilation issues in your ducting make sure inside the unit and the wall ducting is clear......test the unit with the ducting off after you assemble it that should show you if it's a venilation issue also clean all the vents for incoming air into the unit.........also you may have an intermittent issue with your gas coils........Coils will work off an on for a long period of time and their a usual culprit and only cost about $20
  #3 (permalink)
Old 07-30-2013, 06:52 PM
Junior Member
coryp is on a distinguished road
Default
wow, watching this one... exact same works when open on my dryer. get cycling glow from the ignitor when the tub is in, fire when its out. i don't think its the ducting ventilation as i never even put the back panel back on.
one thing to think of though, is that when the tub is not on, there is no suction drawing air through the burner... mine pulls via the exhaust vent, which needs to go through the tub before it can pull from the burner.
to me it suggests the coils, as possibly the still air allows the flame to stay lit when there is too small amount of gas going through the valve...
problem with mine is the coils are integral with the valve and cost closer to $70, even though they all look nearly identical...
  #4 (permalink)
Old 07-31-2013, 06:53 AM
Junior Member
Default gotta be something else
Thanks for the response Humbolt, but the solenoids have been replaced along with the ignitor and flame sensor. Can't be a venting problem since the dryer is disconnected from the discharge and sitting all by itself in the middle of the room. All lint has been cleaned from passages, too. Everything works perfectly when the front panel is off and the drum is out. Put the drum back in and close the front - no flame.
  #5 (permalink)
Old 07-31-2013, 08:17 PM
Junior Member
Default
something else.... i bet if you check yours it's the same, the barrel doesn't have to be out, just hold the door switch to trick it and i bet it'll run.
i changed out my coils today as well and the result is the same. the only difference between working and not is that air is flowing through the heat tube and exhaust tube when it doesn't work, and not flowing in the heat tube when it does. the following was in another thread...
Quote:
Originally Posted by Gene View Post
There are five major electrical parts involved in the heating process:
1. Hi limit thermostat
2. Cycling thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 25 Ohms
b) across the left and the right terminals – 560 25 Ohms
- The part number for the hi limit thermostat is AP275754
- The part number for the igniter is AP3464835
- The part number for the flame sensor is AP2910747
- The part number for the gas valve coils kit is AP3094251
- The part number for the cycling thermostat is AP276896
The first four parts are located on or around the gas valve, the cycling thermostat is located on the blower cover.
Good luck.
only one thing wasn't clear... there are 4 prongs on the cycling thermostat... i got 0ohms at the outer two, but 7kohms across the inner. i don't know what that means. (open to either outer to inner, or inner to outer)
don't know if this helps
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
flame on, out in less than 1 min. Chip Enamel Dryer Repair 0 12-30-2011 08:51 AM
flame stays lit for a few (20) seconds then goes out. could it be the flame sensor? h grubxx96 Dryer Repair 1 11-11-2011 03:23 PM
Full flame then very low flame jeffnaps Oven Repair (including Ranges and Cooktops) 0 07-21-2011 10:18 AM
No Flame awthorp Dryer Repair 3 08-03-2010 12:49 PM
Gas flame comes on one time, then no flame just ignitor cycling kwilson263 Dryer Repair 0 07-15-2010 06:36 PM
