Register | FAQ's | New Posts | Today's Posts | Extras |
» Dryer will not start |
![]() Model Number: AEQB6000ES0 Brand: Frigidaire Age: 1 - 5 years
![]() Dryer starts the immediately stops. Tried the diag test select/cancel 6 seconds buzzer sounds once rotate knob counter clockwise 5 turns (second from bottom) select/option 2 sec buzzer sounds 3 times all leds flashing turn clockwise 1 to test motor / heat **** at this point the dryer acts like it wants to start and stops immediately. Same as it does when we try to use it. Then exits test mode. I cant test anything else in this mode as i can not get past the first turn. Tried field test mode (from another post on this forum) 1. Press and hold the Select and Cancel buttons simultaneously for 6 seconds to reset control. The buzzer will sound 1 time and “rES” will be shown briefly in the display. 2. Immediately after, rotate cycle selector knob 2 turns counter-clockwise to the third position from the top, and then press and hold the Select and Cancel buttons simultaneously for 6 seconds. The control will enter Field Test Mode, the buzzer will sound 3 times, and the digital display will alternate between “Fld” and the firmware revision number (ex. “r03”). 3. Rotate the cycle selector knob 2 turns counterclockwise. The error code will appear in the digit display. got Fld / r08 then the error code E05 any thoughts Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Check under the touchpad for the tech sheet or you can check your manual and look up the code it should guide you to look at the proper circuitry. If i'm not mistaken this is associated with something in the motor circuitry.
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
HOT POINT DRYER has power but start button doesn't start the dryer. | HOT POINT | Dryer Repair | 2 | 08-01-2011 06:47 PM |
Dryer wont start, sensing light just flashes when i hold down the start button! | crsteilen | Dryer Repair | 0 | 03-28-2011 03:21 PM |
Dryer wont start, sensing light just flashes when i hold down the start button! | crsteilen | Dishwasher Repair | 0 | 03-28-2011 12:13 PM |
Dryer will not start - will power up, but when push the start button, will not start | perduena | Dryer Repair | 0 | 07-12-2010 07:14 PM |
dryer start button flashing and not clicking to start dryer | lawfamily | Dryer Repair | 0 | 06-21-2010 07:43 PM |
