Discuss
Maytag LDG7600AAW no flame FIXED
 in
Dryer Repair
I downloaded a troubleshooting guide from another site and took it with me. The dryer in question is a Maytag
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag LDG7600AAW no flame FIXED
  #1 (permalink)
Old 07-28-2013, 08:58 AM
Junior Member
Stahlmaster is on a distinguished road
Default Maytag LDG7600AAW no flame FIXED
Model Number: LDG7600AAW   Brand: Maytag   Age: More than 10 years
I downloaded a troubleshooting guide from another site and took it with me. The dryer in question is a Maytag LDG7600AAW at least 17 years old. This model has an access door in the front lower right hand corner that allows access to the gas valve and other heat related sensors. I started the dryer and the igniter glowed red and the flame came on as it should. It continued to heat for about a minute then went out. It tried to light once more but failed. I removed the two gas valve coils and checked the ohms. The small coil tested good but the larger one tested bad. I was able to source a set of valves in stock it Millers Maytag in Port Huron, MI for $31.75 for the pair. Before I left to pick them up I rechecked the bad coil and it checked out GOOD, however, when it got warm it failed again. I picked-up the new coils and installed them. It took all of 15 minutes to remove, check and install the coils. The dryer is fixed and heats great. So remember to check your coils when they are both cold and when they warm up. This model would allow you to check the coils while they are still on the valve.
There are two coils one with three terminals and one with two terminals.
1. Coil with two terminals should have 1220 50 Ohms
2. Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals 1365 25 Ohms (this tested bad)
b) across the left and the right terminals 560 25 Ohms
The coils I got were FSP #279834
Related Models
Maytag LDG7600AAW DRYER- GAS
Maytag LDG7600ABL DRYER- GAS
Maytag LDG7600ABW DRYER- GAS
Maytag LDG7600AGG DRYER- GAS
Maytag LDG7600AGL DRYER- GAS
Maytag LDG7600AGW DRYER- GAS
Maytag LDG7800 DRYER- GAS
Maytag LDG7800AAL DRYER- GAS
Maytag LDG7800AAW DRYER- GAS
Maytag LDG7800ABL DRYER- GAS
Maytag LDG7800ABW DRYER- GAS
Maytag LDG8000 DRYER- GAS
Maytag LDG8000AAL DRYER- GAS
Maytag LDG8000AAW DRYER- GAS
Maytag LDG8000ABL DRYER- GAS
Maytag LDG8000ABW DRYER- GAS
Maytag LDG810 DRYER- GAS
Maytag LDG8200 DRYER- GAS
Maytag LDG8200AAE DRYER- GAS
Maytag LDG8200AAL DRYER- GAS
Maytag LDG8200AAW DRYER- GAS
Maytag LDG8200ABE DRYER- GAS
Maytag LDG8200ABL DRYER- GAS
Maytag LDG8200ABW DRYER- GAS
Maytag LDG8300 DRYER- GAS
Maytag LDG8300AAL DRYER- GAS
Maytag LDG8300AAW DRYER- GAS
Maytag LDG8304AAE DRYER- GAS
Maytag LDG8304AAL DRYER- GAS
Maytag LDG8304AAM DRYER- GAS
Maytag LDG8404AAE DRYER- GAS
Maytag LDG8404AAL DRYER- GAS
Maytag LDG8404AAM DRYER- GAS
Maytag LDG8404ABE DRYER- GAS
Maytag LDG8406AAE DRYER- GAS
Maytag LDG8406AAM DRYER- GAS
Maytag LDG8406ABE DRYER- GAS
Maytag LDG8410 DRYER- GAS
Maytag LDG8410AAE DRYER- GAS
Maytag LDG8410AAL DRYER- GAS
Maytag LDG8410AAW DRYER- GAS
Maytag LDG8410ABE DRYER- GAS
Maytag LDG8410ABL DRYER- GAS
Maytag LDG8410ABW DRYER- GAS
Maytag LDG8414AAE DRYER- GAS
Maytag LDG8414AAL DRYER- GAS
Maytag LDG8414AAM DRYER- GAS
Maytag LDG8416AAE DRYER- GAS
Maytag LDG8416AAM DRYER- GAS
Maytag LDG8420 DRYER- GAS
Maytag LDG8420AAL DRYER- GAS
Maytag LDG8420AAW DRYER- GAS
Maytag LDG8420ABL DRYER- GAS
Maytag LDG8420ABW DRYER- GAS
Maytag LDG8424AAE DRYER- GAS
Maytag LDG8424AAL DRYER- GAS
Maytag LDG8424AAM DRYER- GAS
Maytag LDG8424ABE DRYER- GAS
Maytag LDG8426AAE DRYER- GAS
Maytag LDG8426AAM DRYER- GAS
Maytag LDG8426ABE DRYER- GAS
Admiral LDG8426AGE DRYER- GAS
Admiral LDG8426EGE DRYER- GAS
Admiral LDG8426GGE DRYER- GAS
Maytag LDG8500 DRYER- GAS
Maytag LDG8500AAL DRYER- GAS
Maytag LDG8500AAW DRYER- GAS
Maytag LDG8506AAE DRYER- GAS
Maytag LDG8506AAM DRYER- GAS
Maytag LDG8600 DRYER- GAS
Maytag LDG8600AAL DRYER- GAS
Maytag LDG8600AAW DRYER- GAS
Maytag LDG8600ABL DRYER- GAS
Maytag LDG8600ABW DRYER- GAS
Maytag LDG8604AAE DRYER- GAS
Maytag LDG8604AAL DRYER- GAS
Maytag LDG8604AAM DRYER- GAS
Maytag LDG8606AAE DRYER- GAS
Maytag LDG8606AAM DRYER- GAS
Maytag LDG8616AAE DRYER- GAS
Maytag LDG8616AAM DRYER- GAS
Maytag LDG8624AAE DRYER- GAS
Maytag LDG8624AAL DRYER- GAS
Maytag LDG8624AAM DRYER- GAS
Maytag LDG8626AAE DRYER- GAS
Maytag LDG8626AAM DRYER- GAS
Maytag LDG8704AAE DRYER- GAS
Maytag LDG8704AAL DRYER- GAS
Maytag LDG8704AAM DRYER- GAS
Maytag LDG8706AAE DRYER- GAS
Maytag LDG8706AAM DRYER- GAS
Maytag LDG8804AAE DRYER- GAS
Maytag LDG8804AAL DRYER- GAS
Maytag LDG8804AAM DRYER- GAS
Maytag LDG882 DRYER- GAS
Maytag LDG8824AAE DRYER- GAS
Maytag LDG8824AAL DRYER- GAS
Maytag LDG8824AAM DRYER- GAS
Maytag LDG8904AAE DRYER- GAS
Maytag LDG8904AAL DRYER- GAS
Maytag LDG8904AAM DRYER- GAS
Norge LDG9127A DRYER- GAS
Norge LDG9127H DRYER- GAS
Norge LDG9127W DRYER- GAS
Maytag LDG9206AAE DRYER- GAS
Maytag LDG9206AAM DRYER- GAS
Maytag LDG9206ABE DRYER- GAS
Maytag LDG9304AAE DRYER- GAS
Maytag LDG9304AAL DRYER- GAS
Maytag LDG9304AAM DRYER- GAS
Maytag LDG9304ABE DRYER- GAS
Maytag LDG9304ABM DRYER- GAS
Maytag LDG9306AAE DRYER- GAS
Maytag LDG9306AAM DRYER- GAS
Maytag LDG9306ABE DRYER- GAS
Maytag LDG9306ABM DRYER- GAS
Maytag LDG9314AAE DRYER- GAS
Maytag LDG9314AAL DRYER- GAS
Maytag LDG9314AAM DRYER- GAS
Maytag LDG9316AAE DRYER- GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dyer Flame Does Not Stay Lit jgwalter Dryer Repair 6 05-02-2013 07:10 PM
Fixed an old Maytag MDB PCB assembly Todd K. Dishwasher Repair 2 08-08-2012 11:15 PM
Maytag dryer flame issue Chicago Joe Dryer Repair 2 03-20-2012 03:33 PM
Maytag Gas Dryer Flame Goes Out wizzorm2g Dryer Repair 0 07-14-2011 05:11 PM
maytag atlantis still not fixed-HELP! dotsonhome Washer Repair 1 09-23-2010 08:26 PM
