Discuss
need wiring diagram
 in
Dryer Repair
no manual and need wiring diagram, specifically connections to heating element that I am replacing. Related Models Kenmore  11096588210  ELECTRIC
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » need wiring diagram
  #1 (permalink)
Old 07-28-2013, 07:59 AM
Junior Member
rva-fixit is on a distinguished road
Default need wiring diagram
Model Number: 11096588210   Brand: Kenmore   Age: 5 - 10 years
Related Models
Kenmore 11096588210 ELECTRIC DRYER
Kenmore 11096588400 ELECTRIC DRYER
Kenmore 11096588410 ELECTRIC DRYER
Kenmore 11096589200 ELECTRIC DRYER
Kenmore 11096589210 ELECTRIC DRYER
Kenmore 11096589400 ELECTRIC DRYER
Kenmore 11096589410 ELECTRIC DRYER
Kenmore 11096590100 ELECTRIC DRYER
Kenmore 11096590110 ELECTRIC DRYER
Kenmore 11096590120 ELECTRIC DRYER
Kenmore 11096590130 ELECTRIC DRYER
Kenmore 11096590140 ELECTRIC DRYER
Kenmore 11096590800 ELECTRIC DRYER
Kenmore 11096590810 ELECTRIC DRYER
Kenmore 11096590820 ELECTRIC DRYER
Kenmore 11096590830 ELECTRIC DRYER
Kenmore 11096590840 ELECTRIC DRYER
Kenmore 11096591200 ELECTRIC DRYER
Kenmore 11096591210 ELECTRIC DRYER
Kenmore 11096591220 ELECTRIC DRYER
Kenmore 11096591230 ELECTRIC DRYER
Kenmore 11096591240 ELECTRIC DRYER
Kenmore 11096591400 ELECTRIC DRYER
Kenmore 11096591410 ELECTRIC DRYER
Kenmore 11096591420 ELECTRIC DRYER
Kenmore 11096591430 ELECTRIC DRYER
Kenmore 11096591440 ELECTRIC DRYER
Kenmore 11096592200 ELECTRIC DRYER
Kenmore 11096592210 ELECTRIC DRYER
Kenmore 11096592220 ELECTRIC DRYER
Kenmore 11096592230 ELECTRIC DRYER
Kenmore 11096592240 ELECTRIC DRYER
Kenmore 11096592400 ELECTRIC DRYER
Kenmore 11096592410 ELECTRIC DRYER
Kenmore 11096592420 ELECTRIC DRYER
Kenmore 11096592430 ELECTRIC DRYER
Kenmore 11096592440 ELECTRIC DRYER
Kenmore 11096593210 ELECTRIC DRYER
Kenmore 11096593230 ELECTRIC DRYER
Kenmore 11096593410 ELECTRIC DRYER
Kenmore 11096593430 ELECTRIC DRYER
Kenmore 11096595200 ELECTRIC DRYER
Kenmore 11096595220 ELECTRIC DRYER
Kenmore 11096595400 ELECTRIC DRYER
Kenmore 11096595420 ELECTRIC DRYER
Kenmore 11096595500 ELECTRIC DRYER
Kenmore 11096595520 ELECTRIC DRYER
Kenmore 11096694700 LIMITED EDITION ELECTRIC DRYER
Kenmore 11096694800 LIMITED EDITION ELECTRIC DRYER
Kenmore 11096742700 DRYER
Kenmore 11096742701 RESIDENTIAL DRYER
Kenmore 11096742702 RESIDENTIAL DRYER
Kenmore 11096747701 RESIDENTIAL DRYER
Kenmore 11096747702 GAS DRYER
Kenmore 11096757701 RESIDENTIAL DRYER
Kenmore 11096757702 RESIDENTIAL DRYER
Kenmore 11096762700 DRYER
Kenmore 11096762701 RESIDENTIAL DRYER
Kenmore 11097081601 DRYER
Kenmore 11097081602 RESIDENTIAL DRYER
Kenmore 11097086601 DRYER
Kenmore 11097086602 RESIDENTIAL DRYER
Kenmore 11097087601 DRYER
Kenmore 11097087602 RESIDENTIAL DRYER
Kenmore 11097088601 DRYER
Kenmore 11097088602 RESIDENTIAL DRYER
Kenmore 11097089601 DRYER
Kenmore 11097089602 RESIDENTIAL DRYER
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091601 DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 11097280600 DRYER FEATURE SHEET
Kenmore 11097280800 DRYER FEATURE SHEET
Kenmore 11097281100 DRYER FEATURE SHEET
Kenmore 11097281800 DRYER FEATURE SHEET
Kenmore 11097282100 DRYER FEATURE SHEET
Kenmore 11097282800 DRYER FEATURE SHEET
Kenmore 11097283100 GAS DRYER
  #2 (permalink)
Old 07-29-2013, 03:34 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find a wiring diagram for this unit.
On most units the heater is hooked up as follows.
One side goes to the motor's centrifugal switch (often a red wire).
The other side goes to high limit thermostat, then the operating thermostat , then the thermal cut-off, then a set of contacts in the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wiring diagram jackthejack Dryer Repair 1 01-08-2012 08:49 AM
wiring disconnected from timer, need wiring diagram Chip65 Dryer Repair 1 12-03-2011 01:24 AM
Need wiring diagram. Help. justin99 Refrigerator & Freezer Repair 1 02-25-2011 11:01 AM
Defrost thermostat wiring, wiring diagram jaalmdo Refrigerator & Freezer Repair 0 12-27-2010 08:10 AM
Wiring Schematic and Wiring Diagram Needed tabrane Refrigerator & Freezer Repair 1 11-11-2010 12:24 AM
