Discuss
aloha from Hawaii/ thermal fuse blown/ red wires burnt to two thermostats now
 in
Dryer Repair
Hi, we have an old (30 years?) Kenmore Heavy Duty Plus dryer that we've been repairing several times in the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » aloha from Hawaii/ thermal fuse blown/ red wires burnt to two thermostats now
  #1 (permalink)
Old 07-27-2013, 02:30 AM
Junior Member
nature boy is on a distinguished road
Default aloha from Hawaii/ thermal fuse blown/ red wires burnt to two thermostats now
Model Number: 110.86570100   Brand: Sears   Age: More than 10 years
Hi, we have an old (30 years?) Kenmore Heavy Duty Plus dryer that we've been repairing several times in the last year with the help of your site and I'm wondering if I'm missing something.
The belt broke, we replaced it. Dryer worked fine for a few months.
The dryer stopped working again, we noticed the red wire to the high limit thermostat on the heater was burnt through at the connector, read online elsewhere that this was not uncommon in an old dryer, cut the wire back and replaced the spade connector, dryer worked fine for a few months.
Dryer stopped working, bought digital multimeter, confirmed thermal fuse on blower is bad (no continuity, and dryer works when thermal fuse wires jumped to each other). Don't want to replace thermal fuse and just have it blow again so checked air flow and vent, all fine. Checked lint screen, blower wheel, etc, all fine. No noticeable leaks in drum, all seems to operate smoothly. Disconnected wires to heater element and tested heater, shows correct resistance internally and no continuity to frame to indicate a sagging element (that I could find, tried several spots on frame but admit this is my first time using multimeter). Ran dryer with thermal fuse wires jumped to each other and measured heat coming out of blower exhaust with thermometer, got up to about 130 and then cycled down and then back up. Cycling thermostat on blower shows continuity when cold. Haven't tested continuity when hot using electric griddle. Using an old meat thermometer to measure temp of air from blower, so don't know if 130 is really accurate or not, (seemed a little low to me?). Can't find temp rating written on cycling thermostat
Noticed female spade connector on red wire to cycling thermostat was partly broken and brittle and insulation at end of red wire somewhat melted and the male connector on the cycling thermostat is all blackened and dark compared to the other side.
So could this just be another old red wire/bad connection at the cycling thermostat that caused an intermittent malfunction that caused the dryer to get too hot and blow the thermal fuse, and if I fix the red wire connection at the cycling thermostat all will be well?
Or am I missing something that is in fact a root cause of these issues and the red wires burning at their connectors? Since the high limit thermostat and the cycling thermostat are both $30+ I'd prefer not to just replace them both if not needed. But more importantly don't want the dryer to cause a fire.
Mahalo and Aloha for your thoughts, from Big Island of Hawaii, 4 miles from the active volcano.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 07-27-2013, 04:28 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Yes it is probably a little low just because of the slow reaction time of the thermometer but I am just speculating here.
Can't find temp rating written on cycling thermostat.
Looking at the part, it is adjustable from 135 to 155 degrees F.
This could be a problem as the temperatures are much lower in this area than in the hi-limit/heater area. You could check the cycling thermostat with your meter though it may be advisable to just replace it.
Unplug the unit. Remove one wire from the thermostat.
Set your meter to it's most sensitive resistance scale.
Short the meter leads together to see if there is a zero offset in the meter.
Now measure across the thermostat contacts.
You should get the same reading as when you shorted the meter leads together.
If it is higher then replace the thermostat as it's contacts are dirty or pitted.
This can cause them to heat up when current passes through them and overheat the connections.
Also can cause the thermostat to stick closed either all the time or intermittently.
Of coarse also repair the bad connector on the wire.
Be sure to use connectors rated for high current.
No. A bad connection will cause an open which would lower the temperature not raise it.
Could be but it is a bit of a crap shoot.
Cannot say but it sounds like you have been pretty thorough in checking that the internal seals (drum felts etc.) and air flow is good.
How does you earlier fix at the hi-limit look. If it looks like it is not overheating here than I would say that area is OK.
__________________
  #3 (permalink)
Old 08-04-2013, 11:34 PM
Junior Member
Default thanks Denman, further dryer info
Hi Denman, thanks for the detailed reply. My previous repair to the red wire on the high limit thermostat looks fine BTW.
Embarrassed to say that upon crawling under the house (open post and pier construction) to examine the dryer hose exit I found that the very end of the dryer hose was somewhat constricted with lint. Not completely blocked but substantially narrowed. (the section of hose inside the house looked spotless)
So, I figured, maybe the hose constriction IS what triggered the thermal fuse to blow. So I changed out the dryer hose, sanded the connections on the cycling thermostat and repaired the red wire connector to the cycling thermostat. Connected the thermal fuse wires together and tested the dryer on a supervised and carefully watched load of laundry. Although it took a long time to get hot it did eventually reach 150 and cycle back down.
I was using the auto dryness setting and noticed the dryer wasn't shutting off on its own although the clothes seemed dry. So I thought, OK, maybe the auto dry setting is kaput and THAT's why the dryer overheated and blew the thermal fuse. So I switched to using the timed dry and that was working well.
Until on a subsequent load, it didn't... being careful not to leave the dryer unattended and having left my thermometer inserted in the dryer hose to spot check temps, I was somewhat surprised to see it registering 160 and the clothes were scorching hot. I shut it down and watched the next load carefully and saw it again go up approaching 170 at which point I shut it down and switched it to air dry.
So now I am thinking yes the cycling thermostat must be sticking intermittantly and I plan to order a new cycling thermostat when I get my new thermal fuse.
If you have any further comments I welcome your further input. Aloha !
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fuse blown on & burnt terminal on primary swithch officework13 Microwave Repair 3 03-24-2012 02:40 PM
Thermal fuse blown? abbeyrd Dishwasher Repair 1 10-03-2008 04:47 PM
Blown Thermal Fuse Again jpoldo Dryer Repair 1 09-08-2008 04:06 PM
2nd blown thermal fuse??? Cari Dryer Repair 2 11-25-2007 04:54 PM
Thermal fuse & thermostats john hicks Dryer Repair 1 11-16-2007 01:06 PM
