Discuss
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes.
 in
Dryer Repair
The timer on my 6 year old Dryer is failing to advance. I'm thinking it is just the timer.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-09-2008, 09:07 AM
XtremeRob XtremeRob is offline
Junior Member
XtremeRob is on a distinguished road
Default Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes.
Model Number: LGB6200KQ1   Brand: Whirlpool   Age: 5 - 10 years
The timer on my 6 year old Dryer is failing to advance. I'm thinking it is just the timer. But the symptoms came on slowly and strangly.
First the Sensor Drying started failing to advance ... most of the time. But the Timed drying worked.
Then about a week later the Timed drying started to fail too.
Then we noticed that sometimes we had heated air flowing through the dryer and sometimes we only had cool air flowing through. I've yet to see any consistency with that problem. I can start it have have no heat. Open the door to stop it. Come back 10 minutes later, close the door, push the start button, and then have heat. Open the door again. Come back 10 minutes later, close the door, start it again, and this time have no heat.... or maybe it will have heat. ??? It's all the doings of gremlins, I tell ya.
Does this all sound like a Timer problem to you or is it something else? Or is it multiple failures?
It's model LGB6200KQ1. Here is the parts list is:
http://shared.whirlpoolcorp.com/asse...%208179770.pdf
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-09-2008, 10:14 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem caused by the coils (#13 & 14 on the burner break down diagram) on the gas valve. They are not stable and do not always holding the gas valve open.
- The part number for the set of the coils is AP3094251
Here are the break down diagrams for the Whirlpool dryer Model LGB6200KQ1
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-12-2008, 07:45 PM
Junior Member
Default
Hi Gene,
You're the best! I replaced the two coils as you suggested and everything works.
Thank you!
Rob
  #4 (permalink)
Old 02-12-2008, 07:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Rob,
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 03:22 PM
Kenmore Timer won't advance or shut off zaq12wsx Dryer Repair 1 01-19-2008 06:36 PM
Gas dryer won't heat and timer not working mark55 Dryer Repair 3 12-30-2007 06:46 PM
Timer does not advance Lloyd Kneller Washer Repair 1 09-26-2007 02:18 AM
Whirlpool washer will not advance cycles GARY H Washer Repair 0 08-14-2007 06:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
