Discuss
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes.
 in
Dryer Repair
Instead of order the coil kit (both coils included) you tried to order each coil separate. Just click on the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes.
  #11 (permalink)
Old 04-20-2010, 10:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Instead of order the coil kit (both coils included) you tried to order each coil separate. Just click on the part number or picture I posted and proceed with your order.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 04-25-2010, 07:14 AM
Junior Member
benw01 is on a distinguished road
Default
I* got it. Thanks.
  #13 (permalink)
Old 04-25-2010, 02:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #14 (permalink)
Old 04-25-2010, 04:01 PM
Junior Member
Default
I had problem to reach the Burner Assembly, I have some progress now. I'll keep you posted...
4/28
It was not easy for me to take out the old parts. Anyway, I got them and I am ordering the new parts. Thanks Gene.
  #15 (permalink)
Old 05-03-2010, 09:23 PM
Junior Member
Default
Gene,
I got the parts as suggested. BTW, shipping was amazingly fast.
I replaced the parts. It definitly fixed one of the two problems I had. Thanks for your advice.
problem 1: No heat supply after 10 minutes of running. Again, this problem is fixed.
problem 2: the Timer knob does NOT advance when it is running in "Drying" cycle. When running in Timer cycle (says 60 mins), it works fine. Again,
when running in Drynig cycle, it would run indefinitely and the dryer would get over heat.
Further advice appreciated.
Thanks,
Ben
  #16 (permalink)
Old 01-13-2011, 07:51 PM
Junior Member
AlanJ is on a distinguished road
Default Coil fix worked perfectly. Thanks!
Thanks AppliancePartsPros and contributors for the advice! The coils were exactly the problem why the gas valve wasn't opening and the timer wasn't moving (I would never have guessed). I bought the coil set for my Whirlpool as instructed, which arrived in 2 days, and in less than 20 minutes from start to finish the dryer was back up and running.
Thanks again.
  #17 (permalink)
Old 01-14-2011, 04:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. We are glad you were able to fix it.
Thank you for the feedback.
__________________
  #18 (permalink)
Old 08-02-2011, 09:34 PM
Junior Member
Lanz is on a distinguished road
Default
Hello, I have had the same problem with my dryer, a whirlpool model LHI5801W0. Do you know what part I need?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Timer does not advance dryer runs no heat Rmelc1 Dryer Repair 3 05-22-2014 06:55 PM
Dryer Timer Will Not Advance cyclone Dryer Repair 2 01-16-2009 02:10 PM
Timer wont advance and dryer wont heat awatt26 Dryer Repair 2 06-20-2008 09:43 PM
Dryer timer fails to advance. robersonlee Dryer Repair 0 02-11-2008 12:34 PM
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 03:22 PM
