dafuchs
#1 Posted : Wednesday, July 24, 2013 9:52:48 PM(UTC)
dafuchs
I had repairman look at the dryer, he stated it needed a new control board. We chose to purchase and install the control board, except after removing the top of the dryer noticed that the belt was not there. Well after taking the back of the dryer off we found the broken belt. Well, just wondering should I replace or check out anything else before replacing the belt? The reason we called the repairman in the first place is because after turning on the dryer after I pressed start their was a click but it wouldn't start.:(
#2 Posted : Thursday, July 25, 2013 12:45:45 PM(UTC)
Parts for Maytag MED9600SQ0 Dryer - AppliancePartsPros.com
Probably all you needed was the belt as this unit has a belt switch that kills power to the motor if the belt breaks.
Check that the motor spins OK manually.
Check the following for wear and bearing slop idler wheel, front and rear support rollers and the drum seals.
Note that if you click on many of the part's picture/name a new page will open with additional info on that part.
Give the interior including the blower wheel a good cleaning.
Also a good time to check/clean your vent system.
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Dryer won't start all the time (Dryer Repair)
by DaHadster 1/10/2017 12:25:28 PM(UTC)
