Discuss
Duet front load dryer no power on
 in
Dryer Repair
The power button has no effect when pushed however the light comes on when the door is open and goes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Duet front load dryer no power on
  #1 (permalink)
Old 07-23-2013, 06:52 PM
Junior Member
Shorty@lamar is on a distinguished road
Unhappy Duet front load dryer no power on
Brand: Whirlpool   Age: 1 - 5 years
The power button has no effect when pushed however the light comes on when the door is open and goes off when closed. It was working fine a couple of days ago.
Hubby checked the power to it and all is well. Help!
  #2 (permalink)
Old 07-23-2013, 07:16 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Your biggest problem is you bought a Duet first off lol.......Check the tech sheet inside the unit.........Assuming it's electric make sure you have 240v inside the unit.....120v if gas...........check all connections at the main board and make sure the touchpad cable at the main board is ok......Inside your tech sheet it should have a diagnostic mode sequence follow that and see if you get any error codes.........Also sometimes you can hold down the power button and unplug the unit and then replug it back in for 5 seconds and try power again....You have to hold down the power button the whole time while doing this.........
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help! My whirlpool duet front load dryer stuck in sensor mode! Sandy DiMascolo Dryer Repair 1 02-26-2017 06:55 PM
Whirlpool Duet front load dryer will not start brokend Dryer Repair 1 07-15-2011 02:18 PM
Kenmore Duet Washer, Front Load whsydddy9 Washer Repair 1 03-17-2011 02:43 PM
Electric Duet Dryer Front Load JPVILL Dryer Repair 0 06-25-2010 08:44 AM
No power to Whirlpool Duet front load washer after bellow repair llm0283 Washer Repair 1 12-23-2009 01:52 PM
