Discuss
Kenmore dryer smell of gas, not heating
 in
Dryer Repair
Recently there has been a smell of gas when my dryer is on and clothes are coming out damp. When
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore dryer smell of gas, not heating
  #1 (permalink)
Old 07-23-2013, 09:30 AM
Junior Member
kh70 is on a distinguished road
Default Kenmore dryer smell of gas, not heating
Model Number: 11074812200   Brand: Kenmore   Age: 5 - 10 years
Recently there has been a smell of gas when my dryer is on and clothes are coming out damp. When it's turned on, the igniter glows and the gas ignites but after about 10 minutes the flame goes off and I start smelling gas. Is this a sign that I need to replace the igniter? or is it the gas valve coils? Thank you.
Related Models
Kenmore 11074812200 GAS DRYER
Kenmore 11074812201 RESIDENTIAL DRYER
Kenmore 11074832400 RESIDENTIAL DRYER
Kenmore 11074842400 RESIDENTIAL DRYER
Kenmore 11074842500 RESIDENTIAL DRYER
Kenmore 11074852400 RESIDENTIAL DRYER
Kenmore 11074854400 RESIDENTIAL DRYER
Kenmore 11074862100 KENMORE AUTOMATIC WASHER
Kenmore 11074862600 KENMORE AUTOMATIC WASHER
Kenmore 11074863100 AUTOMATIC WASHER
Kenmore 11074863600 AUTOMATIC WASHER
Kenmore 11074870100 KENMORE AUTOMATIC WASHER
Kenmore 11074870600 KENMORE AUTOMATIC WASHER
Kenmore 11074871100 AUTOMATIC WASHER
Kenmore 11074871600 AUTOMATIC WASHER
Kenmore 11074872400 RESIDENTIAL DRYER
Kenmore 11074872401 RESIDENTIAL DRYER
Kenmore 11074882400 RESIDENTIAL DRYER
Kenmore 11074882401 RESIDENTIAL DRYER
Kenmore 11074890100 KENMORE AUTOMATIC WASHER
Kenmore 11074890200 KENMORE AUTOMATIC WASHER
Kenmore 11074890400 KENMORE AUTOMATIC WASHER
Kenmore 11074890600 KENMORE AUTOMATIC WASHER
Kenmore 11074890800 KENMORE AUTOMATIC WASHER
Kenmore 11074891100 AUTOMATIC WASHER
Kenmore 11074891110 AUTOMATIC WASHER
Kenmore 11074891200 AUTOMATIC WASHER
Kenmore 11074891210 AUTOMATIC WASHER
Kenmore 11074891400 AUTOMATIC WASHER
Kenmore 11074891410 AUTOMATIC WASHER
Kenmore 11074891600 AUTOMATIC WASHER
Kenmore 11074891610 AUTOMATIC WASHER
Kenmore 11074891800 AUTOMATIC WASHER
Kenmore 11074891810 AUTOMATIC WASHER
Kenmore 11074892400 RESIDENTIAL DRYER
Kenmore 11074892401 RESIDENTIAL DRYER
Kenmore 11074894400 RESIDENTIAL DRYER
Kenmore 11074894401 RESIDENTIAL DRYER
Kenmore 11074902200 GAS DRYER
Kenmore 11074902201 RESIDENTIAL DRYER
Kenmore 11074912200 GAS DRYER
Kenmore 11074922200 GAS DRYER
Kenmore 11074922201 RESIDENTIAL DRYER
Kenmore 11074924200 GAS DRYER
Kenmore 11074924201 RESIDENTIAL DRYER
Kenmore 11074932200 GAS DRYER
Kenmore 11074932201 RESIDENTIAL DRYER
Kenmore 11074942300 GAS, DRYER
Kenmore 11074944300 GAS, DRYER
Kenmore 11074946300 GAS, DRYER
Kenmore 11074952300 GAS, DRYER
Kenmore 11074954300 GAS, DRYER
Kenmore 11074956300 GAS, DRYER
Kenmore 11074962300 GAS, DRYER
Kenmore 11074964300 GAS, DRYER
Kenmore 11074966300 GAS, DRYER
Kenmore 11074972300 GAS DRYER
Kenmore 11074972301 RESIDENTIAL DRYER
Kenmore 11074976300 GAS DRYER
Kenmore 11074976301 RESIDENTIAL DRYER
Kenmore 11074982300 GAS DRYER
Kenmore 11074982301 RESIDENTIAL DRYER
Kenmore 11074992300 GAS, DRYER
Kenmore 11074992301 RESIDENTIAL DRYER
Kenmore 11074994300 GAS, DRYER
Kenmore 11074994301 RESIDENTIAL DRYER
Kenmore 11074996300 GAS, DRYER
Kenmore 11074996301 RESIDENTIAL DRYER
Kenmore 11075062500 RESIDENTIAL DRYER
Kenmore 11075062501 DRYER
Kenmore 11075064500 RESIDENTIAL DRYER
Kenmore 11075066500 RESIDENTIAL DRYER
Kenmore 11075066501 DRYER
Kenmore 11075193 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11075601 AUT. WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11075822400 RESIDENTIAL DRYER
Kenmore 11075922400 RESIDENTIAL DRYER
Kenmore 11075922401 RESIDENTIAL DRYER
Kenmore 11075924400 RESIDENTIAL DRYER
Kenmore 11075924401 RESIDENTIAL DRYER
Kenmore 11075926400 RESIDENTIAL DRYER
Kenmore 11075926401 RESIDENTIAL DRYER
Kenmore 11075942400 RESIDENTIAL DRYER
Kenmore 11075942401 RESIDENTIAL DRYER
Kenmore 11075944400 RESIDENTIAL DRYER
Kenmore 11075944401 RESIDENTIAL DRYER
Kenmore 11075946400 RESIDENTIAL DRYER
Kenmore 11075946401 RESIDENTIAL DRYER
Kenmore 11075962400 RESIDENTIAL DRYER
Kenmore 11075962401 RESIDENTIAL DRYER
Kenmore 11075964400 RESIDENTIAL DRYER
Kenmore 11075964401 RESIDENTIAL DRYER
Kenmore 11075966400 RESIDENTIAL DRYER
Kenmore 11075966401 RESIDENTIAL DRYER
Kenmore 11076002010 GAS DRYER
Kenmore 11076002011 GAS DRYER
Kenmore 11076051690 COMMERCIAL GAS DRYER
Kenmore 11076051691 COMMERCIAL GAS DRYER
Kenmore 11076058690 COMMERCIAL GAS DRYER
Kenmore 11076058691 COMMERCIAL GAS DRYER
Kenmore 11076065 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 11076071690 COMMERICAL GAS DRYER
Kenmore 11076071691 COMMERCIAL GAS DRYER
Kenmore 11076112500 DRYER
Kenmore 11076112501 RESIDENTIAL DRYER
Kenmore 11076152500 RESIDENTIAL DRYER
Kenmore 11076401100 KENMORE ELECTRIC DRYER
Kenmore 11076401400 KENMORE ELECTRIC DRYER
Kenmore 11076401600 KENMORE ELECTRIC DRYER
Kenmore 11076402100 KENMORE ELECTRIC DRYER
Kenmore 11076402110 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076402400 KENMORE ELECTRIC DRYER
Kenmore 11076402410 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076402600 KENMORE ELECTRIC DRYER
Kenmore 11076402610 KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 11076403100 KENMORE ELECTRIC DRYER
Kenmore 11076403400 KENMORE ELECTRIC DRYER
Kenmore 11076403600 KENMORE ELECTRIC DRYER
Kenmore 11076404100 KENMORE ELECTRIC DRYER
Kenmore 11076404110 SEARS ELECTRIC DRYER
  #2 (permalink)
Old 07-23-2013, 06:36 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
More then likely has nothing to do with ignitor at all.......Is it burnt gas smell or fresh gas? Have you checked the air flow inside the unit and your ducting leading out of the house if it's clogged of course you'll get burnt gas smell because there's nowhere for it to exit except stay in the machine. As you stated the gas goes off after 10 minutes but does it ever come back on again? Things to check.........Check the gas connections from the wall by using soapy water or windex at the wall valve then all throughout your supply hose going to unit and connection at the main line coming in. If you find nothing from that path then i'm thinking you probably have a faulty burner assembly and you may need to replace it.....Part # W10465748 has a new ignitor and coils included goes for around $175.
  #3 (permalink)
Old 07-24-2013, 09:55 AM
Junior Member
Default
Quote:
Thank you for your response. The smell was of fresh gas, I checked the gas connections and airflow and everything checked out fine. I turned on the dryer to see if the flame comes back on, it glowed and the gas ignited and the flame went off after 5 minutes. A minute later I got a glow and flame again and stayed on for a couple of minutes. After the 3rd time of glow and ignition, it just glowed red and was off without a flame. This, glow but no flame, went on several times before I turned off the dryer. There was no smell of fresh gas this time around. Any ideas? thank you.
  #4 (permalink)
Old 07-24-2013, 04:41 PM
Senior Member
Default
Sounds like possibly bad coils.......usually bad coils show within the first 10 minutes of testing and will do what your saying........try the coils first there about 20 bucks.......Check your venting out of the house also..........disconnect the ducting off the back of the unit and see if the flame gets bigger or gets sucked up into the back of the unit better if it does you have vent clogging going on in unit or in the walls of the house....also push the door switch button in while the door is open and test it by turning it on with the door open put your hand over the lint trap area and you should have pretty good suction if the vent is inside the unit itself...........if it's in the top don't attempt doing that........if your air flow is good out of the house or inside the unit i'd change out the coils first.......
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
not heating smell gas in dryer and at out side vent bill_schonetti Dryer Repair 1 11-04-2011 04:24 PM
Kerosene smell while dryer is heating AgileDarrell Dryer Repair 1 08-03-2011 09:16 AM
kenmore gas dryer gas smell andy123 Dryer Repair 4 09-22-2010 07:02 PM
Kenmore Gas Dryer burnt/burning smell suprax Dryer Repair 4 04-12-2010 07:33 PM
microwave smell and not heating steph Microwave Repair 0 03-25-2008 06:51 AM
