Discuss
Shaking/rattling noise for LG electric dryer
 in
Dryer Repair
Model LGE0442W dryer Started to make a loud noise within the past couple of weeks and progressively getting worse. Didn't
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Shaking/rattling noise for LG electric dryer
  #1 (permalink)
Old 07-22-2013, 12:46 PM
Junior Member
forgop is on a distinguished road
Default Shaking/rattling noise for LG electric dryer
Model Number: DLE0442W   Brand: -other-   Age: 1 - 5 years
Started to make a loud noise within the past couple of weeks and progressively getting worse. Didn't originally shake like it is now. A short video clip uploaded to youtube included.
LG Dryer Noise/Shaking - YouTube
I'm suspecting drum rollers, but not 100% sure. Your thoughts?
Thanks!
Related Models
 DLE0442W Dryer
 DLE1310W Dryer
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
General Electric DLL2450BHL Gas dryer
General Electric DLL2450RAL Gas dryer
General Electric DLL2450RBL Gas dryer
General Electric DLL2450RCL Gas dryer
General Electric DLL2650ABL Electric dryer
General Electric DLL2650BAL Gas dryer
General Electric DLL2650BBL Gas dryer
General Electric DLL2650BCL Gas dryer
General Electric DLL2650BDL Gas dryer
General Electric DLL2650BEL Gas dryer
General Electric DLL2650BFL Gas dryer
General Electric DLL2650BGL Gas dryer
General Electric DLL2650BHL Gas dryer
General Electric DLL2650BJL Gas dryer
General Electric DLL2650RAL BACKSPLASH DRYER WOW
General Electric DLL2650RALWW Gas dryer
General Electric DLL2650RBL BACKSPLASH DRYER PROGRAM
General Electric DLL2650RBLWW Gas dryer
General Electric DLL2650RCL GAS DRYER
General Electric DLL2650RCLWW Gas dryer
General Electric DLL2650TA Electric dryer
General Electric DLL2654TA Electric dryer
General Electric DLL2750BAL Gas dryer
General Electric DLL2750BBL Gas dryer
  #2 (permalink)
Old 07-22-2013, 06:02 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
LG's dryers are infamous for this and it's funny what will cause this.......something as simple as a small furball in the blower housing can cause this i've seen it many many times and have fixed it........Look down the lint trap hole and see if you can notice any clogging down the shoot near the blower i've seen 1 fabric softener and a small ball of lint about 4" wide cause the unit to shake like a WWII tank........if you cant' get this debris from the top of the lint trap you have to remove the whole front of the unit to make sure this is completely clean. If that's not the problem remove the drum and realign it and put it back together and see if the noise goes away sometimes it just gets off alignment off the felt or rollers. The rollers are rarely the problem with these models from what i've noticed i used to think it was the rollers originally as well but i'd say maybe 1 out of 100 are the rollers. LG makes their dryer drums super thin to where you can bend the drum with 2 fingers and it's a horrible cheaply made drum. I'm suspecting something trapped in the lint shoot near the blower or you have a bad or warped drum (bad drums will also sound like a train going down the track as far as the noise goes when it's excessive)......Also when reassembling make sure you do not turn the drum in opposite direction of the way it should turn both LG and Samsung if you turn the drum alot of times the belt will pop right off and you have to dismantle the machine and reattach the belt again. Check your warranty paperwork in regards to your drum.
  #3 (permalink)
Old 07-22-2013, 07:44 PM
Junior Member
Default
You hit the nail on the head. I finally disassembled it and sure enough, this was stuck in there:
[IMG]http://********************.com/a/img547/1979/28cx.jpg[/IMG]
And the results (running empty)
Much more quiet dryer now - YouTube
  #4 (permalink)
Old 07-22-2013, 08:53 PM
Senior Member
Default
The video shows a pretty loud unit but then again it could just be your audio on your phone or whatever you shoot with. Does it sound like it's brand new?
  #5 (permalink)
Old 10-12-2014, 02:25 PM
Junior Member
jmegert is on a distinguished road
Default
Quote:
Thank you so much for this question and post. My LG dryer starting making a loud noise this week. I took apart some things but didn't see anything obvious. After looking at the exhaust path from the drum I found a big ball of lint, a student ID, bobby pins, safety pins and a dime. TOTALLY fixed the problem once I cleared it all out. Thank you again. Certainly saved me a service call....!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer making loud Buzzing and rattling noise lmorris2026 Dryer Repair 1 07-13-2012 12:16 PM
Dryer making rattling noise Tahoe99 Dryer Repair 0 05-16-2011 08:18 AM
Dryer Rattling & Grinding Noise Avatar3 Dryer Repair 1 03-12-2009 04:41 AM
Dryer works; making noise/shaking more than usual clarkha99 Dryer Repair 1 02-27-2009 03:48 AM
Gas Dryer rattling and shaking since being moved mstrig Dryer Repair 0 07-03-2008 10:12 AM
