I have replaced the control panel twice on my Affinity electric dryer. Also replaced wiring harness, and both thermostats. It still will start but not continue to run after only a few seconds. The second time I noticed the red wire was burned at the connection to the control panel. (hence the wiring harness replacement)
Before this failure occured, both times, I noticed the display panel had flashing lights that circled around and around on the display. What does this mean??
I also had an electrician check my incoming power source for faults and there are none. I just requested another new power control board to see if that is the problem. I will try one more time with this danged machine.
Can anyone give me any clues? I have gotten these successive error codes with each new part replacement. E68, E08, E9E. Every time it is different.
I am about ready to give up if this new control board does not fix it!!! HELP!
