Discuss
Kenmore 800 keeps blowing thermal fuse
 in
Dryer Repair
My Kenmore 800 keeps blowing the thermal fuse - 4 times in ~3 months. I am about out of ideas...
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 800 keeps blowing thermal fuse
  #1 (permalink)
Old 07-20-2013, 12:37 PM
Junior Member
kevincal is on a distinguished road
Default Kenmore 800 keeps blowing thermal fuse
Model Number: 110.69822800   Brand: Kenmore   Age: 5 - 10 years
My Kenmore 800 keeps blowing the thermal fuse - 4 times in ~3 months. I am about out of ideas... would appreciate any help. Here is what I have done so far:
1st time: replaced thermal fuse, cleaned outlet lines (they were pretty clean)
- 1 month later, thermal fuse blows again (2nd time): replace thermal fuse. Check thermistor checks OK hot and cold, replaced it anyway
-1 month later thermal fuse blows again (3rd time): replace thermal fuse and electronic control assembly ($$$).
- 1 weeks later thermal fuse blows AGAIN (4th time)
So at this point I have replaced the thermal fuse, the thermistor and the electronic control assembly.
My only other observation is that evidently when the thermal fuse blows, the dryer keeps running until the cycle stops, or I stop it manually to check the clothes. Then it won't start again. That is, it has never stopped mid cycle like I assume it would when the thermal fuse blows.
Each time I 'fix' it I go from hero to zero (again) with the wife, who now says "just buy me new dryer"!
Kevin.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 07-28-2013, 09:21 AM
Junior Member
Default
...anyone?
  #3 (permalink)
Old 07-28-2013, 11:35 AM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Clean out all ducting inside unit then disconnect the hose from the wall and run it.........if the problem doesn't come back you'll know it was a venting issue...........Most thermal fuses i've seen that have blown where from bad venting and lint clogging in unit or bad thermistor or hi low thermostats getting too hot......good luck
  #4 (permalink)
Old 07-29-2013, 04:21 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I am assuming that you have the tech sheet.
Does it always blow on a certain heat setting or does it make no difference or do you always use the same heat setting so do not know?
The above is troubling.
You are correct that when the fuse blows it should shut the motor off immediately. The fuse is in the motor circuit.
Note: that I am assuming that the fuse that blows is the one on the blower assembly.
I would say that the fuse is blowing at or shortly after the motor stop.
I would swap the motor and the heater relays.
I think they are the same relay but please check this before swapping them.
My thoughts here is that perhaps the heater relay contacts are pitted and are sticking closed intermittently.
Check the heater for any signs that the element has touched the side of the heater case. This would be strange as usually it will weld itself to the case.
Get a thermometer and check the exhaust temperatures as per the tech sheet. Would also be strange if it is running hot as you have replaced the thermistor and the control board. So if it is running hot I would check the heating element.
All the above are grasping at straws as you problem is weird and also intermittent.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dryer keeps blowing thermal fuse spoko Dryer Repair 0 02-23-2012 11:59 AM
Dryer overheat blowing thermal fuse heater box, not vent fuse try2repairguy Dryer Repair 2 11-10-2011 09:27 AM
Thermal fuse keeps blowing bobgjr Dishwasher Repair 3 06-26-2011 08:35 AM
thermal fuse keeps blowing ttr44077 Oven Repair (including Ranges and Cooktops) 0 12-02-2010 07:14 AM
kenmore thermal fuse keeps blowing kbay1977 Dishwasher Repair 2 02-10-2010 10:51 PM
