Discuss
whirlpool heats erratically
 in
Dryer Repair
The dryer will sometimes heat up and dry properly, and sometimes does not heat at all. I have replaced the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool heats erratically
  #1 (permalink)
Old 07-20-2013, 09:08 AM
Junior Member
CaryM is on a distinguished road
Default whirlpool heats erratically
Model Number: 4800xq0   Brand: Whirlpool   Age: 1 - 5 years
The dryer will sometimes heat up and dry properly, and sometimes does not heat at all. I have replaced the dryer cycling thermostat and the hi-limit thermostat. Any suggestions?
Related Models
Frigidaire 4803A ELECTRIC RANGE
Frigidaire 48044 ELECTRIC RANGE
Frigidaire 480440A ELECTRIC RANGE
Frigidaire 480440D ELECTRIC RANGE
Frigidaire 480440E ELECTRIC RANGE
Frigidaire 480440F ELECTRIC RANGE
Frigidaire 480447A ELECTRIC RANGE
Frigidaire 480447D ELECTRIC RANGE
Frigidaire 480447E ELECTRIC RANGE
Frigidaire 480447F ELECTRIC RANGE
Frigidaire 4809A ELECTRIC RANGE
Frigidaire 4809B ELECTRIC RANGE
Frigidaire 4811 ELECTRIC RANGE
Frigidaire 4813-80B ELECTRIC RANGE
Frigidaire 4813A ELECTRIC RANGE
Frigidaire 4819A ELECTRIC RANGE
Frigidaire 4820A ELECTRIC RANGE
Frigidaire 4821-80A ELECTRIC RANGE
Frigidaire 4821A ELECTRIC RANGE
Frigidaire 4822A ELECTRIC RANGE
Frigidaire 4823A ELECTRIC RANGE
Frigidaire 4829A ELECTRIC RANGE
General Electric 4832990 RADIANT MODULE
Frigidaire 4833A ELECTRIC RANGE
Frigidaire 4839A ELECTRIC RANGE
Frigidaire 484240A ELECTRIC RANGE
General Electric 4842990 RADIANT MODULE
Frigidaire 48436 ELECTRIC RANGE
Frigidaire 484360A ELECTRIC RANGE
Frigidaire 484360B ELECTRIC RANGE
Frigidaire 484360D ELECTRIC RANGE
Frigidaire 484367A ELECTRIC RANGE
Frigidaire 484367B ELECTRIC RANGE
Frigidaire 484367D ELECTRIC RANGE
Frigidaire 4843A ELECTRIC RANGE
Frigidaire 484440A ELECTRIC RANGE
Frigidaire 484440C ELECTRIC RANGE
Frigidaire 484440D ELECTRIC RANGE
Frigidaire 484447C ELECTRIC RANGE
Frigidaire 484447D ELECTRIC RANGE
Frigidaire 484560A ELECTRIC RANGE
Frigidaire 484560B ELECTRIC RANGE
Frigidaire 484567A ELECTRIC RANGE
Frigidaire 484567B ELECTRIC RANGE
Frigidaire 484640A ELECTRIC RANGE
Frigidaire 4847-80B ELECTRIC RANGE
Frigidaire 4851A ELECTRIC RANGE
Frigidaire 4853 ELECTRIC RANGE
Frigidaire 4853A ELECTRIC RANGE
Jenn-Air 4855 RANGE- F/S STD DDRAFT ELE
Jenn-Air 4860 RANGE- F/S STD DDRAFT ELE
Frigidaire 4863A ELECTRIC RANGE
Frigidaire 48654 ELECTRIC RANGE
Frigidaire 486540A ELECTRIC RANGE
Frigidaire 486540B ELECTRIC RANGE
Frigidaire 486540D ELECTRIC RANGE
Frigidaire 486547A ELECTRIC RANGE
Frigidaire 486547B ELECTRIC RANGE
Frigidaire 486547D ELECTRIC RANGE
Frigidaire 486640B ELECTRIC RANGE
Frigidaire 486640C ELECTRIC RANGE
Frigidaire 486640D ELECTRIC RANGE
Frigidaire 486640E ELECTRIC RANGE
Frigidaire 486647B ELECTRIC RANGE
Frigidaire 486647C ELECTRIC RANGE
Frigidaire 486647E ELECTRIC RANGE
Frigidaire 48664B ELECTRIC RANGE
Frigidaire 4869A ELECTRIC RANGE
Jenn-Air 4870 RANGE- F/S STD DDRAFT ELE
Frigidaire 4871A ELECTRIC RANGE
Frigidaire 4872A ELECTRIC RANGE
Frigidaire 4873A ELECTRIC RANGE
Frigidaire 4874-80A ELECTRIC RANGE
Frigidaire 4874-87A ELECTRIC RANGE
Jenn-Air 4875 RANGE- F/S STD DDRAFT ELE
Frigidaire 4879A ELECTRIC RANGE
Frigidaire 4881 ELECTRIC RANGE
Frigidaire 4883A ELECTRIC RANGE
Frigidaire 4889A ELECTRIC RANGE
Jenn-Air 4890 RANGE- F/S STD DDRAFT ELE
Frigidaire 4891A ELECTRIC RANGE
Frigidaire 4893-80B ELECTRIC RANGE
Frigidaire 4893A ELECTRIC RANGE
Frigidaire 4899A ELECTRIC RANGE
Frigidaire 49-2151-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2151-23-02 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-02 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-02 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-23-04 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2351-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2351-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2451-00-01 Tap(v5) / 27 " Gas Dryer
Frigidaire 49-2451-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2451-23-01 Tap(v6) / 27 " Gas Dryer
Frigidaire 49-2451-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2551-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2551-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2551-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2551-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2707-00-01 Tap(v2)
Frigidaire 49-2707-23-01 Tap(v1)
Frigidaire 49-2751-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2827-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2827-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2828-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-03 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-04 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2828-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-02 Tap(v2) / Gas Dryer
Frigidaire 49-2828-23-03 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-04 Tap(v4) / 27 " Gas Dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer starts and stops erratically spthomas Dryer Repair 0 09-03-2011 08:09 AM
Microwave turntable moves erratically (jerks) zookeeper121 Microwave Repair 0 12-28-2009 03:46 PM
Oven acting erratically dee1953 Oven Repair (including Ranges and Cooktops) 3 12-25-2008 06:20 AM
Microwave turntable jumping erratically derajm Microwave Repair 1 12-22-2008 03:28 PM
Microwave turntable turns erratically mrnester@charter.net Microwave Repair 1 12-22-2008 06:30 AM
