Discuss
Need help with dryer not staying lit
 in
Dryer Repair
Maytag LDG710 won't stay lit I've read suggestions from other posts with similar problem but have hit a wall and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Need help with dryer not staying lit
  #1 (permalink)
Old 07-18-2013, 05:34 PM
Junior Member
dave50 is on a distinguished road
Default Need help with dryer not staying lit
Model Number: LDG710   Brand: Maytag   Age: More than 10 years
Maytag LDG710 won't stay lit I've read suggestions from other posts with similar problem but have hit a wall and need some advice. Dryer burner ignites for 10 seconds then goes out. About a minute later it repeats this cycle. I have already replaced the following parts:
1. Igniter
2. Gas valve solenoid coils
3. Flame sensor
4. High limit thermostat
What else can I try?
PS: Originally burner would light for about a minute and a half. Then after a while igniter would light but burner would not light. Now with new coils it is doing as described above.
Related Models
Maytag LDG710 DRYER- GAS
Maytag LDG712 DRYER- GAS
Maytag LDG713 DRYER- GAS
Maytag LDG7304AAE DRYER- GAS
Maytag LDG7304AAL DRYER- GAS
Maytag LDG7304AAM DRYER- GAS
Maytag LDG7304ABE DRYER- GAS
Maytag LDG7304ABL DRYER- GAS
Maytag LDG7304ABM DRYER- GAS
Maytag LDG7304AGE DRYER- GAS
Maytag LDG7304AGL DRYER- GAS
Maytag LDG7304AGM DRYER- GAS
Maytag LDG7304EGE DRYER- GAS
Maytag LDG7304EGL DRYER- GAS
Maytag LDG7304EGM DRYER- GAS
Maytag LDG7314AAE DRYER- GAS
Maytag LDG7314AAL DRYER- GAS
Maytag LDG7314AAM DRYER- GAS
Maytag LDG7334AAE DRYER- GAS
Maytag LDG7334AAL DRYER- GAS
Maytag LDG7334AAM DRYER- GAS
Maytag LDG7400 DRYER- GAS
Maytag LDG7400AAL DRYER- GAS
Maytag LDG7400AAW DRYER- GAS
Maytag LDG7400ABL DRYER- GAS
Maytag LDG7400ABW DRYER- GAS
Maytag LDG7480AAL DRYER- GAS
Maytag LDG7480AAW DRYER- GAS
Maytag LDG7480ABL DRYER- GAS
Maytag LDG7480ABW DRYER- GAS
Maytag LDG7500 DRYER- GAS
Maytag LDG7500AAE DRYER- GAS
Maytag LDG7500AAL DRYER- GAS
Maytag LDG7500AAM DRYER- GAS
Maytag LDG7500AAW DRYER- GAS
Maytag LDG7500ABE DRYER- GAS
Maytag LDG7500ABL DRYER- GAS
Maytag LDG7500ABM DRYER- GAS
Maytag LDG7500ABW DRYER- GAS
Maytag LDG7600 DRYER- GAS
Maytag LDG7600AAG DRYER- GAS
Maytag LDG7600AAL DRYER- GAS
Maytag LDG7600AAW DRYER- GAS
Maytag LDG7600ABL DRYER- GAS
Maytag LDG7600ABW DRYER- GAS
Maytag LDG7600AGG DRYER- GAS
Maytag LDG7600AGL DRYER- GAS
Maytag LDG7600AGW DRYER- GAS
Maytag LDG7800 DRYER- GAS
Maytag LDG7800AAL DRYER- GAS
Maytag LDG7800AAW DRYER- GAS
Maytag LDG7800ABL DRYER- GAS
Maytag LDG7800ABW DRYER- GAS
Maytag LDG8000 DRYER- GAS
Maytag LDG8000AAL DRYER- GAS
Maytag LDG8000AAW DRYER- GAS
Maytag LDG8000ABL DRYER- GAS
Maytag LDG8000ABW DRYER- GAS
Maytag LDG810 DRYER- GAS
Maytag LDG8200 DRYER- GAS
Maytag LDG8200AAE DRYER- GAS
Maytag LDG8200AAL DRYER- GAS
Maytag LDG8200AAW DRYER- GAS
Maytag LDG8200ABE DRYER- GAS
Maytag LDG8200ABL DRYER- GAS
Maytag LDG8200ABW DRYER- GAS
Maytag LDG8300 DRYER- GAS
Maytag LDG8300AAL DRYER- GAS
Maytag LDG8300AAW DRYER- GAS
Maytag LDG8304AAE DRYER- GAS
Maytag LDG8304AAL DRYER- GAS
Maytag LDG8304AAM DRYER- GAS
Maytag LDG8404AAE DRYER- GAS
Maytag LDG8404AAL DRYER- GAS
Maytag LDG8404AAM DRYER- GAS
Maytag LDG8404ABE DRYER- GAS
Maytag LDG8406AAE DRYER- GAS
Maytag LDG8406AAM DRYER- GAS
Maytag LDG8406ABE DRYER- GAS
Maytag LDG8410 DRYER- GAS
Maytag LDG8410AAE DRYER- GAS
Maytag LDG8410AAL DRYER- GAS
Maytag LDG8410AAW DRYER- GAS
Maytag LDG8410ABE DRYER- GAS
Maytag LDG8410ABL DRYER- GAS
Maytag LDG8410ABW DRYER- GAS
Maytag LDG8414AAE DRYER- GAS
Maytag LDG8414AAL DRYER- GAS
Maytag LDG8414AAM DRYER- GAS
Maytag LDG8416AAE DRYER- GAS
Maytag LDG8416AAM DRYER- GAS
Maytag LDG8420 DRYER- GAS
Maytag LDG8420AAL DRYER- GAS
Maytag LDG8420AAW DRYER- GAS
Maytag LDG8420ABL DRYER- GAS
Maytag LDG8420ABW DRYER- GAS
Maytag LDG8424AAE DRYER- GAS
Maytag LDG8424AAL DRYER- GAS
Maytag LDG8424AAM DRYER- GAS
Maytag LDG8424ABE DRYER- GAS
Maytag LDG8426AAE DRYER- GAS
Maytag LDG8426AAM DRYER- GAS
Maytag LDG8426ABE DRYER- GAS
Admiral LDG8426AGE DRYER- GAS
Admiral LDG8426EGE DRYER- GAS
Admiral LDG8426GGE DRYER- GAS
Maytag LDG8500 DRYER- GAS
Maytag LDG8500AAL DRYER- GAS
Maytag LDG8500AAW DRYER- GAS
Maytag LDG8506AAE DRYER- GAS
Maytag LDG8506AAM DRYER- GAS
Maytag LDG8600 DRYER- GAS
Maytag LDG8600AAL DRYER- GAS
Maytag LDG8600AAW DRYER- GAS
Maytag LDG8600ABL DRYER- GAS
Maytag LDG8600ABW DRYER- GAS
Maytag LDG8604AAE DRYER- GAS
Maytag LDG8604AAL DRYER- GAS
Maytag LDG8604AAM DRYER- GAS
Maytag LDG8606AAE DRYER- GAS
  #2 (permalink)
Old 07-18-2013, 06:02 PM
Senior Member
HumboldtRepairMan is on a distinguished road
Default
Check to make sure you have adequate gas pressure from the wall. Also check to make sure your gas to air ratio is right on the burner tube and that you don't have it completely closed off. Also this unit has 3 gas coils valves rather then the standard 2. Has the main, secondary and booster coil. The chirping noise is a well known gas coil noise and the problem with coils they will work several times then not work they can be a pain with an intermitant problem. You can also get brand new coils and have them bad ohm test them. The chirping noise could also be a motor/tensioner/belt/roller or guide issue. Sounds like maybe you have a bad burner valve assembly cuz you replaced all the other parts. Have you changed your unit from Propane to natural at all? If your ignitor is turning on regularly then the main control and other things on that circuit seem to be working properly.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Not Staying hot bbc3 Dryer Repair 1 06-30-2010 05:35 AM
Dryer not staying hot Waterboy09 Dryer Repair 2 09-04-2009 03:58 PM
GE Dryer not staying hot Geezer1 Dryer Repair 4 09-04-2009 09:27 AM
dryer not staying hot ssouthard Dryer Repair 1 08-11-2008 12:51 PM
Gas Dryer Not Staying Hot hcjr Dryer Repair 3 09-11-2007 03:17 PM
