seethinghate
#1 Posted : Friday, February 8, 2008 9:09:26 PM(UTC)
seethinghate
dryer runs but glow plug dont work. i changed it out still nothing i put a new timer in still nothing. if the gas valve is bad wont the glow plug still light? ty for your help
#2 Posted : Saturday, February 9, 2008 3:19:55 AM(UTC)
You will need a meter to check things, post back when you get one.
seethinghate
#3 Posted : Saturday, February 9, 2008 6:15:32 PM(UTC)
seethinghate
ty rich i do have a meter i have 4 dryers down with same problem i know for fact most of the venting on the first floor was cloged that was taken care of. i also test them not connected to venting for test purpuis only. so I'm letting u know they problem where over heated?
#4 Posted : Sunday, February 10, 2008 12:44:06 AM(UTC)
Check for voltage at the main connector going to the gas valve/igniter area. If bad use the schematic to check which component is bad, probably the ovrload thermostat/thermal fuse.
seethinghate
#5 Posted : Sunday, February 10, 2008 8:36:07 AM(UTC)
seethinghate
ok ty rich i will do that monday let u know
seethinghate
#6 Posted : Sunday, February 10, 2008 12:10:34 PM(UTC)
seethinghate
ty rich it was the fuse in the back i tested it no power out so i jumped it for testing and works now ty very much sir
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
