Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer wont start, but (http://forum.appliancepartspros.com/dryer-repair/530309-dryer-wont-start-but.html)
mawskin 07-16-2013 10:34 PM
Hi, My Whirlpool dryer wont start,but if I press the More time & the Less time buttons for 5 seconds it will start. The front panel will show 8 and if I press the button again it will show 88. Once I press the start button it will run for 5 - 8 minutes and stop. Plenty of heat and the drum turns. All of the lights on the panel stay on. Any thoughts to what it can be. I replaced the Thermal fuse & the Thermister and it still does the same thing.
mawskin 07-17-2013 02:52 PM
Dryer will not start
[quote=mawskin;820627]Hi, My Whirlpool dryer wont start,but if I press the More time & the Less time buttons for 5 seconds it will start. The front panel will show 8 and if I press the button again it will show 88. Once I press the start button it will run for 5 - 8 minutes and stop. Plenty of heat and the drum turns. All of the lights on the panel stay on. Any thoughts to what it can be. I replaced the Thermal fuse & the Thermister and it still does the same thing.
HumboldtRepairMan 07-17-2013 05:09 PM
Sounds like a main control board or user interface issue with the buttons sticking or malfunctioning.
mawskin 07-18-2013 11:05 PM
Dryer wont start
Had to order the User Control & Display Board. It will take 5-7 working days. I will get back to you and also rate your idea.
