The dryer seems to be working properly, but when it is hard at work and has been hot for awhile it makes a much greater noise. The noise seems to be emitting from the motor/drive area. Motor seem OK. I was curious if common problem with simple fix. I was thinking it may be the idlers on the belt drive or tensioner.
Any ideas?
