Discuss
Whirlpool Cabrio AF Error
 in
Dryer Repair
Hello. I am having an issue with the AF (air flow) error on my Cabrio dryer. I recently posted the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Cabrio AF Error
  #1 (permalink)
Old 07-10-2013, 06:34 PM
Junior Member
chav is on a distinguished road
Default Whirlpool Cabrio AF Error
Model Number: WED6600   Brand: Whirlpool   Age: 1 - 5 years
Hello. I am having an issue with the AF (air flow) error on my Cabrio dryer. I recently posted the following question on the appliancepartspros website and received the following answer:
QUESTION: "I had been getting an AF error (air flow). I had the vent professionally cleaned and still got AF. My dryer then stopped working. There is full power but once I hit start it the unit does nothing. I fixed replaced the thermal fuse and was able to do two loads of laundry and it stopped working again. I tested the thermal fuse with a multimeter and it needs to be replaced again. What could be the bigger issue that I need to fix. I'm assuming the motor is fine since the drum was tumbling fine and the blower wheel doesn't seem to have any resistance when I turn it by hand. Could it be the thermostat, thermal cut-off, or thermister? Or something else? Thanks!"
ANSWER "Hello Chav. You need to test the thermistor 8577274 and see if it is causing the issues with the unit. You can test this with a multi-meter TJMA-DMT3. Here is a link on how to use a multi-meter. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html"
UPDATE: So I bought and installed a new thermal fuse and thermister and after a couple of minutes of running the dryer the AF code re-appears. What would be the next logical issue that I can try to fix. Thanks!
Related Models
Whirlpool WED6600VU0 29" ELECTRIC DRYER
Whirlpool WED6600VW0 29" ELECTRIC DRYER
Whirlpool WED6600WL0 29"ELECTRIC DRYER
Whirlpool WED7300XW0 27" ELECTRIC DRYER
Whirlpool WED7400XW0 27"ELECTRIC DRYER
Whirlpool WED7500VW0 COMPACT ELECTRIC DRYER
Whirlpool WED7600XW0 27" ELECTRIC DRYER
Whirlpool WED7800XB0 27" ELECTRIC DRYER
Whirlpool WED7800XL0 27" ELECTRIC DRYER
Whirlpool WED7800XW0 27" ELECTRIC DRYER
Whirlpool WED7990XG0 29" ELECTRIC DRYER
Whirlpool WED8200YW0 27" ELECTRIC DRYER
Whirlpool WED8300SB0 27" Electric Dryer
Whirlpool WED8300SB1 27" Electric Dryer
Whirlpool WED8300SB2 27" Electric Dryer
Whirlpool WED8300SE2 27" ELECTRIC DRYER
Whirlpool WED8300SW0 27" Electric Dryer
Whirlpool WED8300SW1 27" Electric Dryer
Whirlpool WED8300SW2 27" Electric Dryer
Whirlpool WED8410SW0 27"Electric Dryer
Whirlpool WED8410SW1 27" Electric Dryer
Whirlpool WED8410SW2 27" ELECTRIC DRYER
Whirlpool WED8500SR0 27"Electric Dryer
Whirlpool WED8600YW0 27" ELECTRIC DRYER
Whirlpool WED8800YC0 27" ELECTRIC DRYER
Whirlpool WED8800YW0 27" ELECTRIC DRYER
Whirlpool WED9050XW0 27" ELECTRIC DRYER
Whirlpool WED9050XW1 27" ELECTRIC DRYER
Whirlpool WED9150WW0 27" ELECTRIC DRYER
Whirlpool WED9150WW1 27" ELECTRIC DRYER
Whirlpool WED9151YW0 27" ELECTRIC DRYER
Whirlpool WED9200SQ0 ELECTRIC DRYER
Whirlpool WED9200SQ1 ELECTRIC DRYER
Whirlpool WED9200SQ2 ELECTRIC DRYER
Whirlpool WED9250WL0 27" ELECTRIC DRYER
Whirlpool WED9250WL1 27" ELECTRIC DRYER
Whirlpool WED9250WR0 27" ELECTRIC DRYER
Whirlpool WED9250WR1 27" ELECTRIC DRYER
Whirlpool WED9250WW0 27" ELECTRIC DRYER
Whirlpool WED9250WW1 27" ELECTRIC DRYER
Whirlpool WED9270XL0 27" ELECTRIC DRYER
Whirlpool WED9270XL1 27" ELECTRIC DRYER
Whirlpool WED9270XL2 27" ELECTRIC DRYER
Whirlpool WED9270XR0 27" ELECTRIC DRYER
Whirlpool WED9270XR1 27" ELECTRIC DRYER
Whirlpool WED9270XR2 27" ELECTRIC DRYER
Whirlpool WED9270XW0 27" ELECTRIC DRYER
Whirlpool WED9270XW1 27" ELECTRIC DRYER
Whirlpool WED9270XW2 27" ELECTRIC DRYER
Whirlpool WED9300VU0 ELECTRIC DRYER
Whirlpool WED9300VU1 ELECTRIC DRYER
Whirlpool WED9371YL0 27" ELECTRIC DRYER
Whirlpool WED9371YW0 27" ELECTRIC DRYER
Whirlpool WED9400SB0 ELECTRIC DRYER
Whirlpool WED9400SB1 ELECTRIC DRYER
Whirlpool WED9400ST0 ELECTRIC DRYER
Whirlpool WED9400ST1 ELECTRIC DRYER
Whirlpool WED9400SU0 ELECTRIC DRYER
Whirlpool WED9400SU1 ELECTRIC DRYER
Whirlpool WED9400SU2 ELECTRIC DRYER
Whirlpool WED9400SW0 ELECTRIC DRYER
Whirlpool WED9400SW1 ELECTRIC DRYER
Whirlpool WED9400SW2 ELECTRIC DRYER
Whirlpool WED9400SZ0 ELECTRIC DRYER
Whirlpool WED9400SZ1 ELECTRIC DRYER
Whirlpool WED9400SZ2 ELECTRIC DRYER
Whirlpool WED9400VE0 ELECTRIC DRYER
Whirlpool WED9400VE1 ELECTRIC DRYER
Whirlpool WED9450WL0 ELECTRIC DRYER
Whirlpool WED9450WL1 ELECTRIC DRYER
Whirlpool WED9450WR0 ELECTRIC DRYER
Whirlpool WED9450WR1 ELECTRIC DRYER
Whirlpool WED9450WW0 ELECTRIC DRYER
Whirlpool WED9450WW1 ELECTRIC DRYER
Whirlpool WED9470WL1 ELECTRIC DRYER
Whirlpool WED9470WR1 ELECTRIC DRYER
Whirlpool WED9470WW1 ELECTRIC DRYER
Whirlpool WED94HEXL0 DRYER
Whirlpool WED94HEXL1 27" ELECTRIC DRYER
Whirlpool WED94HEXR0 DRYER
Whirlpool WED94HEXR1 27" ELECTRIC DRYER
Whirlpool WED94HEXW0 DRYER
Whirlpool WED94HEXW1 27" ELECTRIC DRYER
Whirlpool WED9500TC0 ELECTRIC DRYER
Whirlpool WED9500TC1 ELECTRIC DRYER
Whirlpool WED9500TC2 ELECTRIC DRYER
Whirlpool WED9500TU0 ELECTRIC DRYER
Whirlpool WED9500TU1 ELECTRIC DRYER
Whirlpool WED9500TW0 ELECTRIC DRYER
Whirlpool WED9500TW1 ELECTRIC DRYER
Whirlpool WED9500TW2 ELECTRIC DRYER
Whirlpool WED9500TW3 ELECTRIC DRYER
Whirlpool WED9550WL0 ELECTRIC DRYER
Whirlpool WED9550WL1 ELECTRIC DRYER
Whirlpool WED9550WR0 ELECTRIC DRYER
Whirlpool WED9550WR1 ELECTRIC DRYER
Whirlpool WED9550WW0 ELECTRIC DRYER
Whirlpool WED9550WW1 ELECTRIC DRYER
Whirlpool WED95HEXL0 DRYER
Whirlpool WED95HEXL1 27" ELECTRIC DRYER
Whirlpool WED95HEXR0 DRYER
Whirlpool WED95HEXR1 27" ELECTRIC DRYER
Whirlpool WED95HEXW0 DRYER
Whirlpool WED95HEXW1 27" ELECTRIC DRYER
Whirlpool WED9600SU0 ELECTRIC DRYER
Whirlpool WED9600TA0 27" ELECTRIC DRYER
Whirlpool WED9600TA1 27" ELECTRIC DRYER
Whirlpool WED9600TA2 27" ELECTRIC DRYER
Whirlpool WED9600TB0 27" ELECTRIC DRYER
Whirlpool WED9600TB1 27" ELECTRIC DRYER
Whirlpool WED9600TU0 27" ELECTRIC DRYER
Whirlpool WED9600TU1 27" ELECTRIC DRYER
Whirlpool WED9600TW0 27" ELECTRIC DRYER
Whirlpool WED9600TW1 27" ELECTRIC DRYER
Whirlpool WED9600TW2 27" ELECTRIC DRYER
Whirlpool WED9600TZ0 27" ELECTRIC DRYER
Whirlpool WED9610XW0 27" ELECTRIC DRYER
Whirlpool WED9750WL0 27" ELECTRIC DRYER
Whirlpool WED9750WR0 27" ELECTRIC DRYER
Whirlpool WED9750WW0 27" ELECTRIC DRYER
  #2 (permalink)
Old 07-11-2013, 04:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Your model number is missing several digits at the end of it.
May be I am reading the below wrong.
The blower wheel should have some resistance as it is on the motor which is connected to the drum etc. Could be it is stripped.
Or did you test it with the belt disconnected.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cabrio Washer UL error code Kellyclark665 Washer Repair 5 06-09-2012 08:56 AM
Whirlpool Cabrio F1 Error Code Assistance twhittaker Washer Repair 1 04-16-2012 01:56 PM
Cabrio Washer F50 error lphuffman Washer Repair 1 08-02-2010 02:12 PM
Whirlpool Cabrio keeps displaying error message & won't continue cycle leighvalencia Washer Repair 1 03-30-2009 06:33 AM
