Discuss
Whirlpool Gas Dryer Heats than blows cool
 in
Dryer Repair
Hi, I'm new here, and thank you in advance for any help you can offer. My Whirlpool model LGR7648KQ1 gas
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Gas Dryer Heats than blows cool
  #1 (permalink)
Old 10-07-2009, 09:49 PM
Junior Member
OldAsDirt is on a distinguished road
Question Whirlpool Gas Dryer Heats than blows cool
Model Number: LGR7648KQ1   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool model LGR7648KQ1 gas dryer heats initially, but then quits - it continues to run, but without heat.
I have checked the vent, and it blows freely. After sitting awhile, (Cooling down?) it then will repeat, heat then just blow cool air.
Would you guess a thermostat or 'gas valve coil'?
(I was not able to find gas valve coil on the parts diagrams...)
Regards,
"C" aka OldAsDirt
Related Models
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" GAS DRYER
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"GAS DRYER
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0 GAS DRYER
Whirlpool LGR8857EQ1 DRYERS
Whirlpool LGR8857EQ2 GAS DRYER
Whirlpool LGR8857EQ3 GAS DRYER
Whirlpool LGR8857EZ0 GAS DRYER
Whirlpool LGR8857EZ1 DRYERS
Whirlpool LGR8857EZ2 GAS DRYER
Whirlpool LGR8857EZ3 GAS DRYER
Whirlpool LGR8858DQ0 GAS DRYER
Whirlpool LGR8858DQ1 GAS DRYER
Whirlpool LGR8858DZ0 GAS DRYER
Whirlpool LGR8858DZ1 GAS DRYER
Whirlpool LGR8858EQ0 GAS DRYER
Whirlpool LGR8858EQ1 DRYERS
Whirlpool LGR8858EQ2 GAS DRYER
Whirlpool LGR8858EQ3 GAS DRYER
Whirlpool LGR8858EZ0 GAS DRYER
Whirlpool LGR8858EZ1 DRYERS
Whirlpool LGR8858EZ2 GAS DRYER
Whirlpool LGR8858EZ3 GAS DRYER
Amana LGS10AW WASHER-TOP LOADING
Amana LGS19AW DRYER- GAS
Amana LGS33AW DRYER- GAS
Amana LGS34AW WASHER-TOP LOADING
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AQ0 Residential Dryer
Whirlpool LGT5434AW0 Residential Dryer
Whirlpool LGT5436AW0 Residential Dryer
Whirlpool LGT5624BN0 GAS DRYER
Whirlpool LGT5624BN1 GAS DRYER
Whirlpool LGT5624BN2 GAS DRYER
Whirlpool LGT5624BQ0 GAS DRYER
Whirlpool LGT5624BQ1 GAS DRYER
Whirlpool LGT5624BQ2 GAS DRYER
Whirlpool LGT5624BW0 GAS DRYER
Whirlpool LGT5624BW1 GAS DRYER
Whirlpool LGT5624BW2 GAS DRYER
Whirlpool LGT5624DQ0 GAS DRYER
Whirlpool LGT5624DQ1 GAS DRYER
Whirlpool LGT6634AN1 DRYER
Whirlpool LGT6634AN2 GAS DRYER
Whirlpool LGT6634AQ0 GAS DRYER
Whirlpool LGT6634AQ1 GAS DRYER
Whirlpool LGT6634AQ2 GAS DRYER
Whirlpool LGT6634AW0 Residential Dryer
Whirlpool LGT6634AW1 DRYER
Whirlpool LGT6634AW2 GAS DRYER
Whirlpool LGT6634DQ0 GAS DRYER
Whirlpool LGT6634DQ1 GAS DRYER
Whirlpool LGT6634DZ0 GAS DRYER
Whirlpool LGT6634DZ1 GAS DRYER
Whirlpool LGT6638AN1 GAS DRYER
Whirlpool LGT6638AN2 GAS DRYER
Whirlpool LGT6638AQ2 GAS DRYER
Whirlpool LGT6638AW0 Residential Dryer
Whirlpool LGT6638AW1 GAS DRYER
Whirlpool LGT6638AW2 GAS DRYER
Whirlpool LGT6638DQ0 GAS DRYER
Whirlpool LGT6638DQ1 GAS DRYER
Whirlpool LGT6638DZ0 GAS DRYER
Whirlpool LGT6638DZ1 GAS DRYER
Whirlpool LGT7646AQ0 Residential Dryer
Whirlpool LGT7646AQ2 GAS DRYER
Whirlpool LGT7646AW0 Residential Dryer
Whirlpool LGT7646AZ2 GAS DRYER
Whirlpool LGT7646DQ0 GAS DRYER
Whirlpool LGT7646DQ1 GAS DRYER
Whirlpool LGT7646DZ0 GAS DRYER
Whirlpool LGT7646DZ1 GAS DRYER
Whirlpool LGT7646EQ0 GAS DRYER
Whirlpool LGT7646EQ1 DRYERS
Whirlpool LGT7646EQ2 GAS DRYER
Whirlpool LGT7646EQ3 GAS DRYER
Whirlpool LGT7646EZ0 GAS DRYER
Whirlpool LGT7646EZ1 DRYERS
Whirlpool LGT7646EZ2 GAS DRYER
Whirlpool LGT7646EZ3 GAS DRYER
Whirlpool LGT7848AQ0 Residential Dryer
Whirlpool LGT7848AQ1 GAS DRYER
Whirlpool LGT7848AQ2 GAS DRYER
Whirlpool LGT7848AW0 Residential Dryer
Whirlpool LGT7848AZ1 GAS DRYER
Whirlpool LGT7848AZ2 GAS DRYER
Whirlpool LGT7848DQ0 GAS DRYER
Whirlpool LGT7848DQ1 GAS DRYER
Whirlpool LGT7848DZ0 GAS DRYER
Whirlpool LGT7848DZ1 GAS DRYER
  #2 (permalink)
Old 10-08-2009, 12:21 PM
Senior Member
applianceman is on a distinguished road
Default
More than likely it is the coils on the gas valve. The problem is intermitting so it is hard to check. I would say replace the coils on the gas valve. Hope this helps! Clothes Dryer Repair Guide
  #3 (permalink)
Old 10-08-2009, 02:10 PM
Junior Member
Default
Thank you ApplianceMan! One other quick question: Being that the Dryer is in a vacation home 4 hours away (with not very good parts sources there...), would you get just the gas valve coils, or be safe an get a new thermostat also? (Do I feel lucky? - In Clint Eastwood voice...)
Thanks again! regards, "C" aka OldAsDirt in NH
  #4 (permalink)
Old 10-08-2009, 02:25 PM
Senior Member
Default
Well you got to think a 4 hour trip with the wrong part would be bad and there is no way for me to know for sure if that is the part you need or not. It is possible for it to be a number of things but my next guess would be the operating thermostat. This is not likely but possible. Good luck!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool gas dryer heats then stops heating? Need Help! cdpken Dryer Repair 5 09-27-2011 08:13 PM
whirlpool dryer turns on heats for 5 min and and keeps turning but not heating? nimster64 Dryer Repair 16 08-04-2011 06:24 AM
GE Gas Dryer heats initially and then goes cool Greggy_D Dryer Repair 1 12-29-2009 11:43 AM
AMANA dryer heats at first then runs cool mike k Dryer Repair 0 10-15-2009 05:51 PM
Freezer blows cool but not freezing and refrig is warm Angelicas Refrigerator & Freezer Repair 2 08-08-2007 08:06 PM
