Discuss
Noobie jumping into a Hotpoint - questions
 in
Dryer Repair
I'll try to make this quick. My dryer has been squeaking for a bit. If you were to count musically
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Noobie jumping into a Hotpoint - questions
  #1 (permalink)
Old 07-06-2013, 06:50 PM
Junior Member
tluxtele is on a distinguished road
Default Noobie jumping into a Hotpoint - questions
Model Number: DLB1550ralad   Brand: Hotpoint   Age: More than 10 years
My dryer has been squeaking for a bit. If you were to count musically it'd go squeak-squeak-3-4. The other day it started to make a new noise. Kinda sounding like an air compressor. I have taken it apart to find the cause. Here is the list of things I think it could be and questions that go with them.
- The belt is bad so that needs to be replaced.
- I figured I would check/replace the bearing while I'm in there. The problem is I don't know what would look bad or worn. The bearing is a sleeve that goes around a post. It looks fine. It has some play in it. Is it supposed to be a "snug" fit or should there be play? How much play?
- Some one told me it could be the belt tensioner. How do I check it? It appears to roll fine. Should I just lube it? What would be a good lube?
- The model doesn't appear to have any drum rollers. There are two strips that it looks like the drum rests on. Should I replace these?
Is there anything else I should check? How does one go about finding parts at a local place and not have to order online. I have no issue with online, I'd just like to make sure I have the right parts.
Thanks for your help.
Related Models
General Electric DLB1550SBLAD Electric dryer
General Electric DLB1550SBLWH Electric dryer
General Electric DLB2450BDL Electric dryer
General Electric DLB2450BEL Electric dryer
General Electric DLB2450BNL Electric dryer
General Electric DLB2450RAL Electric dryer
General Electric DLB2650BAL Electric dryer
General Electric DLB2650BBL Electric dryer
General Electric DLB2650BCL Electric dryer
General Electric DLB2650BDL Electric dryer
General Electric DLB2650BEL Electric dryer
General Electric DLB2650BGL Electric dryer
General Electric DLB2650BNL Electric dryer
General Electric DLB2650RAL BACKSPLASH DRYER PROGRAM
General Electric DLB2650RALWW Electric dryer
General Electric DLB2650TA Electric dryer
General Electric DLB2654TA Electric dryer
General Electric DLB2750BAL Electric dryer
General Electric DLB2750BNL Electric dryer
General Electric DLB2880BAC Electric dryer
General Electric DLB2880DAL Electric dryer
General Electric DLB2880DBL Electric dryer
General Electric DLB2880DCL Electric dryer
General Electric DLB2880DDL Electric dryer
General Electric DLB2880DEL Electric dryer
General Electric DLB2880DGL Electric dryer
General Electric DLB2900MAL Electric dryer
General Electric DLB3000SBLWH Electric dryer
General Electric DLB3200SBLWH Electric dryer
General Electric DLB3400SBLAD Electric dryer
General Electric DLB3400SBLWH Electric dryer
General Electric DLB3600SBLAD Electric dryer
General Electric DLB3600SBLWH Electric dryer
General Electric DLB3600SBLWW Electric dryer
General Electric DLB3800SBLAD Electric dryer
General Electric DLB3800SBLWH Electric dryer
General Electric DLB3800SBLWW Electric dryer
General Electric DLB3900SAM Electric dryer
General Electric DLB3900SBM Electric dryer
General Electric DLB6850AAL Electric dryer
General Electric DLB6850BAL Electric dryer
General Electric DLB6850BBL Electric dryer
General Electric DLB6850BCL Electric dryer
General Electric DLB6850BDL Electric dryer
General Electric DLB6850BEL Electric dryer
General Electric DLB6850TA Electric dryer
General Electric DLB6850TDL Electric dryer
General Electric DLB6850TM Washer
Amana DLD10E COMMERCIAL MICROWAVES
Amana DLD10M COMMERCIAL MICROWAVES
Amana DLD10SE COMMERCIAL MICROWAVES
 DLE0332W Dryer
 DLE0442G Dryer
 DLE0442W Dryer
 DLE1310W Dryer
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
  #2 (permalink)
Old 07-07-2013, 08:36 AM
Senior Member
scott5495 is on a distinguished road
Default hotpoint
replace rear drum bearing part no. we03x0074. if never changed, 100% sure that is problem. ask local parts house for tube of grease for the idler pulley. most any will do. the drum glides at bottom of drum are bad if the plastic has worn through. if not don't replace. the drum bearing can look fine but dry out. sort of a hardening process.
  #3 (permalink)
Old 07-07-2013, 11:49 AM
Junior Member
Default
scott,
Thanks for your help. I'll look for a place tomorrow to get that part. Hopefully that will do it.
Do I need to grease the bearing or just put it on? And you're saying to just get the bearing, not the whole assembly right?
BTW, I'm not far down the road. I'm in Pittsboro. My wife taught in Rocky Mount for a few years.
  #4 (permalink)
Old 07-07-2013, 12:36 PM
Senior Member
Default hotpoint dryer
right, do not replace the whole assembly, just the drum bearing. do not grease the drum bearing. btw the bearing may look a little different than the original. only put a little grease on the belt idler pulley shaft. sounds like you have it licked. [ a term only southerners know]. I wish I were in Pittsboro or somewhere else, Rocky Mount ain't what it used to be.
  #5 (permalink)
Old 07-08-2013, 09:54 PM
Junior Member
Default
Squeaking is gone but the air compressor noise is still there. I took some video so you could hear what I'm talking about. If I had to guess I'd say it's coming from the front of the dryer. Any ideas?
Dryer - YouTube
  #6 (permalink)
Old 07-09-2013, 04:29 AM
Senior Member
Default noise
take the front off the dryer.
look at the fan blade in the lower left corner.
sounds like it may have slid forward on the motor shaft and is hitting the frame.
also look for something in the fan blade housing.
the noise has something to do with the fan blade hitting something
  #7 (permalink)
Old 07-09-2013, 11:38 AM
Junior Member
Default
Ok. I took the front off, spun the fan by hand and it seems to be fine. Can't hear anything rubbing, etc. So I took the drum out to see if I could get a better look. Then I realized the blower tube is in the way. Before I took it off I looked for anything else.
What did I see?
The "slide" just above the fan is almost worn threw and there is a crack near the rivet I missed with my last inspection. I have it off and I'm going to try to make it over to the parts place to see if they have them in stock. I can't figure out what else it'd be.
Could this be my problem? I don't hear any rubbing or scraping when I turn the motor/fan.
  #8 (permalink)
Old 07-09-2013, 05:52 PM
Senior Member
Default dryer
yes this absolutely can be your problem and from what you described it is
the instructions on your part may call for you to mount the slides differently, don't worry about that. glad you found it.
  #9 (permalink)
Old 07-10-2013, 05:45 PM
Junior Member
Default
Well, the slides needed to be changed BUT they weren't the problem. I'm getting frustrated. Just to recap.
Changed...
... belt
... rear bearing
... front slides
It still makes that noise. It seems like something is rubbing because it happens at a consistent revolution while spinning. I have now checked the fan area. Here's what I don't understand. If I don't have the drum in I can spin the fan with no noise. I put it all together, turn it on and I get that noise.
After turning it on tonight and still getting the noise (after replacing the slides) I have now taken the motor out so I can look behind the fan. I don't see any signs of the fan scraping ANYWHERE. I now have the motor completely out and I can't hear the scraping sound by just turning it.
I've brought my wife in for another set of ears. She's stumped too. She's wondering if the drum is just rubbing somewhere.
What do I do now? Should I take video of the motor outside of the dryer spinning by hand to see if I'm missing something?
Is it possible there's a bearing in the motor that's bad? Something that only makes that noise once there is tension from the belt being on it and pulling it?
  #10 (permalink)
Old 07-10-2013, 05:57 PM
Senior Member
you can hook the motor back up without re-installing and then jump the door switch wires. turn on dryer and listen to the motor at full speed. the noise I heard was loud enough to show up without tension on the pulley.
another thought, check the metal vent under the drum to make sure it is not hitting the drum. I saved the video, i'm going back and listen again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer has jumping problems pilsner Dryer Repair 1 09-06-2012 12:38 PM
can't get washer to stop jumping around kensells Washer Repair 0 07-06-2012 06:27 PM
jumping washer bigwalt Washer Repair 0 10-31-2010 06:11 AM
jumping washer FRED BOUMAN Washer Repair 1 11-07-2009 04:59 PM
