Discuss
Dryer will not heat.
 in
Dryer Repair
My dryer will not heat up. I have replaced the heater element and the Hi Limit Thermostat. I checked the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not heat.
  #1 (permalink)
Old 07-04-2013, 02:24 PM
Junior Member
modelshop8624 is on a distinguished road
Default Dryer will not heat.
Model Number: LEN2000KQ0   Brand: Whirlpool   Age: More than 10 years
My dryer will not heat up. I have replaced the heater element and the Hi Limit Thermostat. I checked the thermal fuse for continuity and it was good. I also cleaned out the vent hose. I'm not sure what to do next. Any help will be appreciated.
Related Models
Whirlpool LEN2000KQ0 DRYER
Whirlpool LEN2000KQ1 29"ELECTRIC DRYER
Whirlpool LEN2000KQ2 29"ELECTRIC DRYER
Whirlpool LEN2000KT0 DRYER
Whirlpool LEN2000KT1 29"ELECTRIC DRYER
Whirlpool LEN2000LG0 RESIDENTIAL DRYER
Whirlpool LEN2000LG1 29"ELECTRIC DRYER
Whirlpool LEN2000LW0 RESIDENTIAL DRYER
Whirlpool LEN2000LW1 29"ELECTRIC DRYER
Whirlpool LEN2000PG0 29"ELECTRIC DRYER
Whirlpool LEN2000PG1 29"ELECTRIC DRYER
Whirlpool LEN2000PW0 29"ELECTRIC DRYER
Whirlpool LEN2000PW1 29"ELECTRIC DRYER
Whirlpool LEN3434AW0 Residential Dryer
Whirlpool LEN3624BN0 ELECTRIC DRYER
Whirlpool LEN3624BN1 ELECTRIC DRYER
Whirlpool LEN3624BN2 ELECTRIC DRYER
Whirlpool LEN3624BW0 ELECTRIC DRYER
Whirlpool LEN3624BW1 ELECTRIC DRYER
Whirlpool LEN3624BW2 ELECTRIC DRYER
Whirlpool LEN3634DW0 ELECTRIC DRYER
Whirlpool LEN3634DW1 ELECTRIC DRYER
Whirlpool LEP6646AN1 ELECTRIC DRYER
Whirlpool LEP6646AN2 ELECTRIC DRYER
Whirlpool LEP6646AW0 Residential Dryer
Whirlpool LEP6646AW1 ELECTRIC DRYER
Whirlpool LEP6646AW2 ELECTRIC DRYER
Whirlpool LEP6848AN1 ELECTRIC DRYER
Whirlpool LEP6848AN2 ELECTRIC DRYER
Whirlpool LEP6848AW0 Residential Dryer
Whirlpool LEP6848AW1 ELECTRIC DRYER
Whirlpool LEP6848AW2 ELECTRIC DRYER
Whirlpool LEP7858AN1 ELECTRIC DRYER
Whirlpool LEP7858AN2 ELECTRIC DRYER
Whirlpool LEP7858AQ2 ELECTRIC DRYER
Whirlpool LEP7858AW0 Residential Dryer
Whirlpool LEP7858AW1 ELECTRIC DRYER
Whirlpool LEP7858AW2 ELECTRIC DRYER
Whirlpool LEP7858AZ2 ELECTRIC DRYER
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ1442ES1 DRYER
Frigidaire LEQ1452KS0 DRYER
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152EE1 DRYER
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ2152HS0 DRYER
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0 DRYER
Whirlpool LEQ5000KQ1 29"ELECTRIC DRYER
Whirlpool LEQ5000KQ2 29"ELECTRIC DRYER
Whirlpool LEQ5000KW1 29"ELECTRIC DRYER
Whirlpool LEQ5000KW2 29"ELECTRIC DRYER
Whirlpool LEQ5000PW0 29"ELECTRIC DRYER
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ6400FS0 DRYER
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0 DRYER
Whirlpool LEQ7000KQ1 DRYER
Whirlpool LEQ7000KQ2 DRYER
Whirlpool LEQ7030KQ0 DRYER
Whirlpool LEQ7030KQ1 RESIDENTIAL DRYER
Whirlpool LEQ7030KQ2 29"ELECTRIC DRYER
Frigidaire LEQ8000FE0 DRYER
Whirlpool LEQ8000HQ0 DRYER
Whirlpool LEQ8000HQ1 DRYER
Whirlpool LEQ8000JQ0 DRYER
Whirlpool LEQ8000JQ1 DRYER
Whirlpool LEQ8000JQ2 DRYER
Whirlpool LEQ8000JQ3 29"ELECTRIC DRYER
Whirlpool LEQ8000JQ4 ELECTRIC DRYER
Whirlpool LEQ8100KQ0 DRYER
Whirlpool LEQ8100KQ1 DRYER
Whirlpool LEQ8100KT0 DRYER
Whirlpool LEQ8100KT1 DRYER
Whirlpool LEQ8611LG0 RESIDENTIAL DRYER
Whirlpool LEQ8611LG1 27"ELECTRIC DRYER
Whirlpool LEQ8611LW0 RESIDENTIAL DRYER
Whirlpool LEQ8611LW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG0 27" ELECTRIC DRYER
Whirlpool LEQ8611PG1 27"ELECTRIC DRYER
Whirlpool LEQ8611PG2 27"ELECTRIC DRYER
Whirlpool LEQ8611PW0 27" ELECTRIC DRYER
Whirlpool LEQ8611PW1 27"ELECTRIC DRYER
Whirlpool LEQ8611PW2 27"ELECTRIC DRYER
Whirlpool LEQ8621PG0 27" ELECTRIC DRYER
Whirlpool LEQ8621PG1 27"ELECTRIC DRYER
Whirlpool LEQ8621PG2 27"ELECTRIC DRYER
Whirlpool LEQ8621PW0 27" ELECTRIC DRYER
Whirlpool LEQ8621PW1 27"ELECTRIC DRYER
Whirlpool LEQ8621PW2 27"ELECTRIC DRYER
Whirlpool LEQ8800JQ0 DRYER
Whirlpool LEQ8800JQ1 DRYER
Whirlpool LEQ8800JT0 DRYER
Whirlpool LEQ8800JT1 DRYER
Whirlpool LEQ8857HQ0 DRYER
Whirlpool LEQ8857HQ1 DRYER
Whirlpool LEQ8857HZ0 DRYER
Whirlpool LEQ8857HZ1 DRYER
Whirlpool LEQ8857JQ0 DRYER
Whirlpool LEQ8857JQ1 DRYER
Whirlpool LEQ8857JT0 DRYER
Whirlpool LEQ8857JT1 DRYER
Whirlpool LEQ8858HQ0 DRYER
Whirlpool LEQ8858HQ1 DRYER
Whirlpool LEQ8858HZ0 DRYER
Whirlpool LEQ8858HZ1 DRYER
Whirlpool LEQ8858JQ0 DRYER
Whirlpool LEQ8858JQ1 DRYER
Whirlpool LEQ8858JT0 DRYER
Whirlpool LEQ8858JT1 DRYER
Whirlpool LEQ8858JZ1 DRYER
Whirlpool LEQ9030PQ0 29"ELECTRIC DRYER
Whirlpool LEQ9030PQ1 29" ELECTRIC DRYER
Whirlpool LEQ9508KQ0 RESIDENTIAL DRYER
  #2 (permalink)
Old 07-05-2013, 04:18 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool LEN2000KQ0 Dryer - AppliancePartsPros.com
Start by checking the power.
The motor etc. uses half the line (120 volts) but the heating coils require the full 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 07-06-2013, 11:26 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
If OK
If OK
I checked the power at the terminal strip. The terminal is connected to 3 wires (black, white, red). Black/Red-240 volts, Black/White-120 volts andWhite/Red-120 volts. I checked with the dryer both on and off. There are 2 red wires going to the heat coils. I checked for voltage to the heating coils with the dryer both off and on. There was no voltage going to the heating coils. Should I have a voltage reading there at the heating coils? Could I have a bad switch or control? If so, which one? Thanks for your help.
  #4 (permalink)
Old 07-06-2013, 01:21 PM
Senior Expert
APP Volunteer
Default
See the following post it has a wiring diagram as an attachment.
Dryer wont heat
A lot depends on how/where you are measuring.
Yes.
The safest way to check for it is to unplug the unit and use resistance.
Use your most sensitive resistance scale. Also short the meter leads together before starting, This will tell you that the meter is working and also if there is any zero offset.
One way is to measure across the components in the heater circuit.
Another way is to attach one meter lead to L1 (black) and leave it there.
Set the timer to mid scale of a heating cycle type.
The red side of Timer Switch 2 should be 0 ohms.
Both sides of the Thermal Cutoff should be 0 ohms.
Both sides of the Operating Thermostat should be 0 ohms.
Both side of the Hi Limit Thermostat should be 0 ohms
One side of the Heater should be 0 ohms, the other side should be about 10 ohms.
There you now have measured everything in the heater circuit other than the centrifugal switch on the motor.
If so, which one?
See above.
Note that if the Thermal Cutoff is blown get back to us as there are other things you should check before replacing it.
__________________
  #5 (permalink)
Old 07-10-2013, 01:16 AM
Junior Member
Default
Dryer wont heat
Yes.
If so, which one?
See above.
I checked the Thermal Cutoff Switch for continuity and it was open. I ordered a new one and installed it and now I have heat. Thank you so much for your help. I really appreciate it.
  #6 (permalink)
Old 07-10-2013, 02:16 AM
Senior Expert
APP Volunteer
Default
You may want to do the following
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut)
Part number: AP3094244
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Dryer stops after a few minutes with heat on - will run continuously with heat off somegeek Dryer Repair 0 05-27-2010 01:35 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
