jrogers
#1 Posted : Thursday, July 4, 2013 11:55:26 AM(UTC)
jrogers
I have tried drying a load of clothes, 3 timed cycles, and the dryer runs and shuts off and clothes are not drying. It does not feel like there is any heat.
#2 Posted : Friday, July 5, 2013 3:32:25 AM(UTC)
Parts for GE DWSR483EG3WW Dryer - AppliancePartsPros.com
Confirm that there is no heat.
Try different heat settings to see if there is heat on any setting.
If there is no heat on any setting then check your power first.
The motor etc. uses half the line (120 volts) but the heating coils require the full 240.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
GE Electric Dryer won't heat up (Dryer Repair)
by lizt 12/27/2009 12:07:30 PM(UTC)
