Discuss
Dryer continues to spin when door is opened!!
 in
Dryer Repair
About a week ago, my dryer continued to spin when I opened the door. Now, the dryer won't turn on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer continues to spin when door is opened!!
  #1 (permalink)
Old 10-07-2009, 01:52 PM
Member
badtothebone is on a distinguished road
Default Dryer continues to spin when door is opened!!
Model Number: LER6611LQ0   Brand: Whirlpool   Age: 5 - 10 years
About a week ago, my dryer continued to spin when I opened the door. Now, the dryer won't turn on at all. Can you please assist me in trying to diagnose the problem. THX.
Related Models
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Whirlpool LER6638DW1 ELECTRIC DRYER
Whirlpool LER6638DZ0 ELECTRIC DRYER
Whirlpool LER6638DZ1 ELECTRIC DRYER
Whirlpool LER6644DQ0 ELECTRIC DRYER
Whirlpool LER6644DQ1 ELECTRIC DRYER
Whirlpool LER6644DZ0 ELECTRIC DRYER
Whirlpool LER6644DZ1 ELECTRIC DRYER
Whirlpool LER6646BN0 ELECTRIC DRYER
Whirlpool LER6646BN1 ELECTRIC DRYER
Whirlpool LER6646BN2 ELECTRIC DRYER
Whirlpool LER6646BW0 ELECTRIC DRYER
Whirlpool LER6646BW1 ELECTRIC DRYER
Whirlpool LER6646BW2 ELECTRIC DRYER
Whirlpool LER6646DN1 ELECTRIC DRYER
Whirlpool LER6646DW1 ELECTRIC DRYER
Whirlpool LER6646PW0 29" ELECTRIC DRYER
Whirlpool LER6646PW1 29" ELECTRIC DRYER
Whirlpool LER6848AN1 ELECTRIC DRYER
Whirlpool LER6848AN2 ELECTRIC DRYER
Whirlpool LER6848AQ2 ELECTRIC DRYER
Whirlpool LER6848AW0 Residential Dryer
Whirlpool LER6848AW1 ELECTRIC DRYER
Whirlpool LER6848AW2 ELECTRIC DRYER
Whirlpool LER6848AZ2 ELECTRIC DRYER
Whirlpool LER7620KQ0 RESIDENTIAL DRYER
Whirlpool LER7620KQ1 ELECTRIC DRYER
Whirlpool LER7620KT0 DRYER
Whirlpool LER7620KT1 ELECTRIC DRYER
Whirlpool LER7620LG0 RESIDENTIAL DRYER
Whirlpool LER7620LG1 29"ELECTRIC DRYER
Whirlpool LER7620LQ0 RESIDENTIAL DRYER
Whirlpool LER7620LW0 RESIDENTIAL DRYER
Whirlpool LER7620LW1 29"ELECTRIC DRYER
Whirlpool LER7646AN0 ELECTRIC DRYER
Whirlpool LER7646AN1 ELECTRIC DRYER
Whirlpool LER7646AN2 ELECTRIC DRYER
Whirlpool LER7646AQ0 ELECTRIC DRYER
Whirlpool LER7646AQ1 ELECTRIC DRYER
Whirlpool LER7646AQ2 ELECTRIC DRYER
Whirlpool LER7646AW0 Residential Dryer
Whirlpool LER7646AW1 ELECTRIC DRYER
Whirlpool LER7646AW2 ELECTRIC DRYER
Whirlpool LER7646AZ0 ELECTRIC DRYER
Whirlpool LER7646AZ1 ELECTRIC DRYER
Whirlpool LER7646AZ2 ELECTRIC DRYER
Whirlpool LER7646DQ0 ELECTRIC DRYER
Whirlpool LER7646DQ1 ELECTRIC DRYER
Whirlpool LER7646DW0 ELECTRIC DRYER
Whirlpool LER7646DW1 ELECTRIC DRYER
Whirlpool LER7646DZ0 ELECTRIC DRYER
Whirlpool LER7646DZ1 ELECTRIC DRYER
Whirlpool LER7646EQ0 DRYER
Whirlpool LER7646EQ1 DRYERS
Whirlpool LER7646EQ2 ELECTRIC DRYER
Whirlpool LER7646EZ0 DRYER
Whirlpool LER7646EZ1 DRYERS
Whirlpool LER7646EZ2 ELECTRIC DRYER
Whirlpool LER7646JQ0 DRYER
Whirlpool LER7646JT0 DRYER
Whirlpool LER7648KQ0 RESIDENTIAL DRYER
Whirlpool LER7648KQ1 RESIDENTIAL DRYER
Whirlpool LER7648KQ2 RESIDENTIAL DRYER
Whirlpool LER7648KQ3 29"ELECTRIC DRYER
Whirlpool LER7648KT0 RESIDENTIAL DRYER
Whirlpool LER7648KT1 RESIDENTIAL DRYER
Whirlpool LER7648KT2 RESIDENTIAL DRYER
Whirlpool LER7648KT3 29"ELECTRIC DRYER
Whirlpool LER7648PQ0 29" ELECTRIC DRYER
Whirlpool LER7648PQ1 29" ELECTRIC DRYER
Whirlpool LER7648PT0 29" ELECTRIC DRYER
Whirlpool LER7648PT1 29" ELECTRIC DRYER
Whirlpool LER7848DQ0 ELECTRIC DRYER
Whirlpool LER7848DQ1 ELECTRIC DRYER
Whirlpool LER7848DZ0 ELECTRIC DRYER
Whirlpool LER7848DZ1 ELECTRIC DRYER
Whirlpool LER7858AN1 ELECTRIC DRYER
Whirlpool LER7858AN2 ELECTRIC DRYER
Whirlpool LER7858AW0 Residential Dryer
Whirlpool LER7858AW1 ELECTRIC DRYER
Whirlpool LER7858AW2 ELECTRIC DRYER
Whirlpool LER8620PG0 29"ELECTRIC DRYER
Whirlpool LER8620PG1 29"ELECTRIC DRYER
Whirlpool LER8620PW0 29"ELECTRIC DRYER
Whirlpool LER8620PW1 29"ELECTRIC DRYER
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
  #2 (permalink)
Old 10-08-2009, 05:46 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LER6611LQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203979703.pdf
Sounds like the door switch has failed.
Remove it and check it with a meter.
Remember to mark where the wires go.
Only other possibility I can think of is that you had a short on one of the wires to the frame/case and that has now burned up opening the connection.
__________________
  #3 (permalink)
Old 10-08-2009, 10:54 AM
Member
Default
I changed the door switch and the fuse. Still won't work.
  #4 (permalink)
Old 10-08-2009, 02:44 PM
Senior Expert
APP Volunteer
Default
Did you check the old switch and fuse with a meter.
A meter will come in handy in trying to figure this one out.
__________________
  #5 (permalink)
Old 10-12-2009, 11:39 AM
Member
Default
The dryer will work after changing switch and fuse. However, the outlet seems to be bad. Thanks for your assistance.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
will not spin and drain until lid is opened and shut jimmyb1966 Washer Repair 15 03-27-2012 02:23 PM
Micro starts when door opened gwburkey Microwave Repair 16 03-08-2010 08:24 PM
Matag will spin but not pump unless door opened and closed Ken Fitzgibbon Washer Repair 1 11-01-2009 06:53 AM
Door sags 1/4 inch when opened gnewhart Microwave Repair 5 03-08-2009 06:36 PM
Buzzes when door is opened or any button pushed rudyclf Microwave Repair 0 10-22-2008 06:48 PM
