Hello, need some help. I already replaced the thermostat and thermal fuse, but I'm still getting intermittent heating. The only way I can get the dryer to heat is if I keep cycling the timer to the call for heat position and then move it up to 60 min - I usually have to do this many many times to get the coils to come on. I have also looked at the coils and it appears that half of the coil box is stained black while the bottom half is still metal colored. Also I noticed that the thermal cutoff at the bottom of the heating element is kinda loose, I was wondering if that was normal as well.
Thanks for any help.
