Discuss
kenmore elect dryer dead
 in
Dryer Repair
this kenmore elect dyer model 110.87081601 wont do nothing have checked thermo cut off i am gettinh 220 to machine
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore elect dryer dead
  #1 (permalink)
Old 06-24-2013, 09:22 AM
Junior Member
gregaguilar is on a distinguished road
Default kenmore elect dryer dead
Brand: Kenmore   Age: 1 - 5 years
this kenmore elect dyer model 110.87081601 wont do nothing have checked thermo cut off i am gettinh 220 to machine door switch okay what is next?
  #2 (permalink)
Old 06-26-2013, 02:05 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Kenmore Dryer 11087081601 - AppliancePartsPros.com
See the attachment for the tech sheet
Where atr you measuring?
You should not see 220 at the door switch.
It should be 120 volts if uoy are using ground/Neutral as the reference.
Does the drum light work?
Have you checked for 120 volts from Neutral to L1 and to L2?
__________________
  #3 (permalink)
Old 06-26-2013, 05:17 AM
Junior Member
Quote:
Originally Posted by denman View Post
i am not getting 220 to door switch i said to unit 120 on each leg and 220 across both legs belt switch okay thermo okay it is either the ui power bard, the circuiet board or the houe electronics assembly according to the tech sheet they tell you to replace on if no good replace the other and last if no good replace the last board what is this??????
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore dryer display dead wizardmax Dryer Repair 0 12-05-2012 06:27 AM
GE Elect. Dryer overheats smeglasson1@gmail.com Dryer Repair 0 09-22-2012 08:18 PM
Matag Dryer want come on. Elect. jackssib1 Dryer Repair 2 06-10-2010 07:43 AM
Whirlpool elect dryer motor rick539 Dryer Repair 4 01-16-2010 08:56 AM
elect dryer not heating, coil looks ok robingb1999 Dryer Repair 3 03-18-2009 04:15 AM
